Question about Whirlpool Duet GHW9150P Front Load Washer
Food regularly dried onto dishes, particularly bad on top shelf
  • 74 Answers
Try rinsing off your dishes before putting them in the dishwasher. also go to a hardware store and buy Dishwasher Magic it will clean out the dishwasher
Posted on Sep 05, 2009
After a full cycle the dishes are covered with pulverized food on top shelf only.
Most (if not all) dishwasher have a food grinder in them just like a "garbage disposal" in your sink. (It's NOT really meat to be a garbage disposal)
In any case if the ground food is ending up back in the washer it means its not being flushed out when the washer empties.
You will need to remove the bottom rack and the bottom spinner. Open the pump and clear any debris The round tank tat the lower arm sits on should also be cleaned out. If the washer is over 5 yrs old consider replacing the impeller and all the pump hardware also.
Without specific Make and Model I cannot give you detailed instructions or parts #s. When asking about things like this alway have the make and model # Good luck
Jan 22, 2017 | Dishwashers
Dishes and glasses on the top rach are not getting clean-bottom rack is fine.
Check that the arms spin freely when spun by hand, then check the outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it with the result is that the upper dishes do not get enough water and chemicals. It may also cause water to continue dripping onto dried dishes after the the drying cycle has stopped.
Jun 14, 2011 | Kenmore Dishwashers
The dishwasher is not washing the dishes on the top rack.
Check that the arm outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it with the result is that the upper dishes do not get enough water and chemicals. It may also cause water to continue dripping onto dried dishes after the the drying cycle has stopped.
Apr 05, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
No water going to the top arm of the dishwasher
Apr 02, 2011 | Kenmore 16764 Dishwasher
Our Asko dishwasher no longer cleans the top shelf of dishes properly. Fine white and black grit is left on the dishes after every wash, and if there is any food residue on the dishes it does not come off....
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Check also that the arm outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it.
Feb 04, 2011 | Asko 24 in. D3350 Dishwasher
Regular cycle no longer cleans well
Thanks for the clarification (we get a lot of people on here that don't know how to really use a dishwasher).
Sounds to me like the DW may need a through going over.
Confirm the make and model of the DW so I can see how it's built. I am suspect that with all the food particles and film you mention, that the spray heads are clogged in the spray bars, and, check that the drain hose is not kinked, and it's attachment into the garbage disposal is clear. I've had these clog before, limiting the ability of the DW to get rid of the dirty water.
Dec 17, 2009 | Whirlpool 24 in. DU930PWP Built-in...
Rinsing agent not dispensing
the problem is hard water. go to www.dishwasherfilter.com. they have a filter designed specifically for this problem. it filters the water going into your dishwasher leaving your dishes crystal clean with every load. it is very affordable and guaranteed to work.
Mar 18, 2009 | Dishwashers
Dishes on top rack don't get clean
The following suggestions will greatly enhance the ability of your dishwasher to clean all of the dishes thoroughly:
1. Rinse all of the food off of the dishes before you put them in the dishwasher.
2. Run the hot water into the sink until it is as hot as it gets before you start the dishwasher.
3. Do not pack the dishes into the dishwasher, just put in a reasonable number without crowding or stacking them on either shelf.
4. Pull the top shelf all the way out to be sure that the water connection at the rear of the top shelf is connected. Sometimes, this connector comes disconnected preventing the water from entering the top spray assembly.
THese things should make a huge difference.
Good luck with this and please rate my answer. Thanks. Joe
Feb 03, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Kitchen Aid dishwasher - top shelf not getting dishes clean
Is the top sprayer clean and not clogged so that the water can flow through? The top may not be functioning properly.
Jan 16, 2009 | KitchenAid Dishwashers
Whirlpool Duet GHW9150P Front Load Washer Logo
66 people viewed this question
Dan Webster
Dan Webster
Sal De
