Question about O2 Xda IIs Pocket PC
    Problem Solver:
  • 8 Answers
NO it is not knackered i am trying to fix mine as soon as i know how to fix i will post on here try the link in the post above
Posted on Feb 01, 2009
0 characters
3 Points
Power cut during rom upgrade upto 73%
Hi Kumar,
Nice to find u here . Do u have upgrade of XDA II Mini. I m on original version. Havent used this set in a while as i m on Iphone. So i was wondering if u can help?? Hoping to hear soon, Thnx
Jul 24, 2009 | O2 Xda II mini
Touch diamond stuck in airplane mode, gwes error
try updating your ROM, you find everything on HTC website in support section
Jun 27, 2009 | HTC Touch Diamond Smartphone
HTC Touch was stucked up after an error while upgrading to WM 6.1
i think u have tried to upgrade thru custom rom bcoz this pda came with WM 6 only so u tried to upgrade to 6.1 thru custom rom procedure and it seems like something went wrong and u get a boot loader screen tri color with code written SPL 1.XXX on it dont worry i can help u in this go step by step as soon as ur problem is resolved leave other step
first try this
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if ur pda boot normally after reset procedure it will take some time to boot dont panic if it is ok then good luck
if it doesnt help then try this
download Hard SPL 3.1 from here
install it as described in the instructions inside the zip file
and then Rom Lite version for ELF from here
first install hard spl 3.1 as directed on ur pda and then update to custom rom from the the file downloaded
pls rate me FIXYA if it helps
Mar 14, 2009 | HTC Touch P3450 Smartphone
O2 xda formatting
Quite possible the upgrade failed and has corrupted something.
You will need to find out how to perform a Cold reset as this should return it back to factory defaults.
See here for some assistance.
Apr 24, 2008 | O2 Xda IIs Pocket PC
My o2 xda II mini have a problem... i try to upgrade my rom but have ar error for the software,after that I tried to restart it but it only displays the word "serial v 1.02" and doesnt boot please help.
Try to bring your O2 XDA II mini to it's own service center because the problem is in it's program itself or it's memory containing it's program. The service center has their own orignal software utilities for that.
Mar 12, 2008 | O2 Xda II mini
My o2 does not boot.
have you tried to reset all the settings? some of the application has corrupt. if it persist reformat you xda
Jan 26, 2008 | O2 Xda II mini
visit the link  for complete info on updating ROM and upgrading operating system.
Oct 13, 2007 | O2 Xda IIs Pocket PC
O2 rom upgradation
I think the upgrade, when finished would give the instructions to reboot the handheld. Upgrading mine did. It explained I must hit the (On) button and the reset (hole) at the same time.
Sep 06, 2007 | O2 Xda II mini
O2 Pocket Pc stopped working after upgrade installation
flash arom directly from bootloader mode (by pressing camera ****. and keep press. then press with sylus the soft reset ****. ,
then the 3 colors shows with usb in left bottom site of screen of device then run the flash utility normally .
May 06, 2007 | O2 Xda II mini
E740 pr3170u-1p052-model? and tomtom 3
As far as I know there is no PPC2003 upgrade. Normally there should not be any problem with TomTom3. If you want try to install a last image Check please Toshiba download site. I have found info that TomTom5 can not be used with Toshiba PDAs. Not yet. Since October that should be possible. Check TomTom web page.
Sep 07, 2005 | Toshiba e740 Pocket PC
O2 Xda IIs Pocket PC Logo
391 people viewed this question
Top O2 PDAs Experts
Martin Murray
xxxxxx xxx
Jax Planet
Jax Planet
Are you an O2 PDA Expert? Answer questions, earn points and help others
