Question about Technics SL-PG480A CD Player
How do I get a belt to open the cd drawer?
How do I get a new belt to open the cd drawer? All spare part shops, (it seems to be original Philips??) are sold out. Is there a way to fix it?
it is a cd SLP 212 A
    President:
  • 3,130 Answers
You will need to take out the belt and have it sized for the correct one.
Techman
Posted on Sep 05, 2009
Drawer to load dvds will not open. Needs a belt for the drawer. where can I get one
Hello
Loading belts can be bought from most of the electronic spare part selling shops at your town. Keep the broken belt in hand for sample and size.
Mar 08, 2012 | Harman Kardon DVD-22 DVD Player
The driving belt of my Philips HTS3500S is broken. How can I get hold of spare parts?
Take the original one into a shop that sells spares for washing machines or vacuum cleaners and just match the length and width to the ones they have available. It is just a reinforced rubber band- you just need to get one that fits. Washing Machines and Vacuum cleaners use belts as well and these tend to be stronger so they last longer.
Jul 13, 2011 | Philips HTS3500S System
I have a Teac PD-495 CD player. The door will not open - just makes a 'noise' as if it's trying to open the door but can't for some reason. Any thoughts?
Sounds like the door may have something sticky around the edges. Even a little sticky stuff (like from candy-coated fingers...?) can prevent the door\drawer of any CD player from opening.
Try gently "assisting" the door during the few seconds it's trying to open. If it seems like it's not sticking to the housing try the manual eject button.
Depending on your specific device, there should be a very small hole near the door\drawer (Refer to your owners manual for the exact location). It will be just big enough to stick the end of a large paperclip into. Insert the end of a paperclip into the hole and push firmly (make sure nothing is blocking the door\drawer from opening) and the door\drawer should open slightly. Then pull the door\drawer open the rest of the way. If you have to do this, make sure the power is off as the unit might try to close the drawer automatically while you're trying to pull it open.
Once you have the drawer open, inspect the inner surface of the drawer and the area it contacts for anything sticky. Clean with a damp cloth only. Do not spray any cleaner on the unit. If you need to use any cleaners, spray them on the cloth. Clean the area around the inner drawer faceplate and surrounding areas. Let dry for a few minutes then power up and test for operation. It should work fine now.
If not, it may be time to replace this old unit with a new one as repair costs generally exceed the cost of replacement.
Hope this answers your problem. Good Luck!
Dec 04, 2010 | Teac RW-D200 / RW-D250 Dual-Deck CD Player...
Need drawer belt for Yamaha CDC-805 CD changer - the one needed that opens and closes the changer's door - not sure where to get it or the part number. I thought I ordered the right one and got the 'drive'...
Any decent repair shop should have a large supply of replacement belts. The Part number isn't necessary. Just take the old one in and get a new one just 2mm smaller than the original. Some repair shops won;t sell them because they don't want you repairing your own property but a decent shop should sell you one.
Apr 07, 2010 | Yamaha CDC-745 5-Disc CD Changer
I need a new belt for my Yamaha cdc-615. The belt controls the opening and closing of the drawer. How do I go about purchasing a bet for such an old player?
Jusy had the same problem. The player worked fine until one day I went to use it and the tray would not open. The belt had streched and was too loose. Since the player is quite old finding a replacement belt was next to impossible. So I went to the local hardware store and bought a Danco #56 rubber O ring (Stock# 35770B, 1 1/2 O.D. x 1 3/8 I.D.) I replaced the belt with the O ring and it works perfectly. The original belt is a V belt but the O ring seems just fine. Important that you do not get one any smaller because it may stress the motor drive shaft and bend it.
Oct 24, 2009 | Audio Players & Recorders
My dvd/vcr combo won't open any drawers on a magnavox combo, i press open and nothing opens, nothing seems to work except the lights
You need to change the drive belt. Attempt only if you know how to replace electronic parts. Open top cover and see drive bay to locate any belt that opens the door. Replace it with a new one. Also apply a little grease to the drive's edges.
Jul 26, 2009 | Philips Televison & Video
CD Rom drawers do not open or close, drive belts have popped out
Unfortunatly, these belts are not availible for consumer purchase and, most service centers will just replace the entire device. i have used regular rubber bands that are identical in size to run many rom drives. this method seems to work just fine.
Its very unfortunate when these original belts break and, there is no replacment belt on the market. the only option is to purchae a store bought rubber band that matches the same size as the broken original band. this will work.
Jun 10, 2009 | Dell Dimension 8400 PC Desktop
CD drawer not opening
mechanisum problem.
please you have to check the belt of loading mechanisum.can you open the cover.
nuwan
Jan 12, 2009 | Philips FWC577 CD Shelf System
CD drawer will not open or close
Hi, The CD drawer mechanism needs a new belt. They have a motor that drives the tray mechanism, and there's a small belt that drives the main gear so that pushing the drawer in gently to close it doesn't damage anything. However, once that belt breaks/wears out, the drawer will stay in whatever position it was last in.
Jul 24, 2008 | Audio Players & Recorders
Technics SL-PG480A CD Player Logo
114 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
