Question about Vivitar ViviCam 8025 Digital Camera
When i go out in the bright sun i canot see anything in the view finder
    Brigadier General:
  • 11,967 Answers
Welcome to the club! I've heard a company makes a shade that fits around the screen for bright sun viewing.
Posted on Sep 05, 2009
Fujifilm FinePix S1600 The monitor display is not working. Can it be replaced and if so how easy is it?
It could be that you have it set for EVF which means that you are using the tiny view finder instead of the LCD screen? It should have a button close to the view finder labeled EVF/LCD, you can alternate between the LCD screen or the tiny viewfinder? This function if mainly to conserve battery power or if you are out in the sun and cannot frame a shot and so you use the view finder like the old cameras, hope this might help you?
Dec 09, 2014 | FUJIFILM Cameras
Epl2 black screen
I can't think of much. Perhaps you pressed the button, to change the view from monitor display, to extra view finder display?
Try pressing that again.
I don't thin it has anything to do with the brightness settings of the screen.
Jul 22, 2014 | Olympus PEN EPL2 Digital Camera
I cant view anything from the finderscope in relation to the telescope
They must be lined up, and if you are using a higher power eyepiece, this must be more precise as your field of view is smaller.
There will be some type of adjustment on the finderscope, probably 3 thumbscrews around the holder tube.
Put in a low power eyepiece and point the scope at a local feature such as a streetlight or distant building. Get this centered in the eyepiece. Then adjust the finder only so the feature is centered in the finder as well.
Put in a higher power eyepiece and center the feature again in the telescope EP, and readjust the finder centering by itself, if needed.
Then choose a bright star and by moving the scope mount, place this in the center of the finder. Check if the star is properly centered in the EP as well and if not, move the scope mount until it is. Then finally adjust the finder centering by itself.
Feb 07, 2012 | Celestron Optics
Cant see anything through the view finder
1. During the day, use the 17mm eyepiece on a object outside (telephone pole, water tower, etc) then align the finder to what you see in the scope.
2. Put in the 7.5mm eyepiece and fine align the red dot finder.
3. At night, point the finder at the moon (less than half moon or the image is too bright without a moon filter) Use the 17mm eyepiece.
4. Once you see the moon, switch to the 7.5mm lens and enjoy.
5. Download Stellarium or any free astronomy software and see what is in your sky tonight. Your scope should be able to see Jupiter and its moons easily.(Saturn, Mars and Venus when the time is right) Open clusters like Pleiades will be nice is this fast scope.
5. If stars are not sharp, you may need to collimate the scope. Look online for general instructions.
Nov 14, 2011 | Optics
I have a fugi fine pix, when using it in bright sun light i cant see anything
Geofchaam,
You could be experiencing one of two issues:
1) You are having a difficulty viewing the image on the back of the camera (not the view finder). This is common on cameras out in the sun, try cupping your spare hand over the screen to cast a shadow on the screen.
2) You cannot view anything in the view finder. Since the view finder has its own tiny LCD display inside of it, it is displaying what image the camera will take if you press the shutter release. I would double check to see if the camera is set correctly for shooting in bright sunlight (check your owners manual, or set the camera to Automatic), and if there is a difference between what you're seeing in the viewfinder, and what images the camera is taking, consider calling Fuji, as it sounds like a hardware issue.
Mar 01, 2011 | Fuji FinePix S5000 Digital Camera
Almost impossible to compose a picture i can hardly see anything. no problem on a bright day or even indoors
you showed me that there is an adjustment ob the view finder.thank you for your help I have already recommende you to several friends,
May 27, 2009 | Cameras
Blurry view finder
this may occuer if you are trying to expose the camera to sudden temperature changes/differences.
Eg: From your Air Conditioned Bed Room to Day Light Under Sun Light
Sep 23, 2008 | HP Photosmart 945 Digital Camera
No picture
he CCD (charge coupling device) went kaput like all those others who are complaining about no picture in the view finder. My technician told me that this happens when 1) on exposure to hot climate 2) if we focus too far, like into the sky or by mistake at the sun or some bright flourescent light. This fact is not mentioned in the accompanying instruction manual, atleast i did not find it. I hope all current users take these precautions, it is too late for me, I am not spending any more money on this digital camcorder. I sincerely request Canon to withdraw this product. i found this info hope it is helpful
Jul 08, 2007 | Canon ZR65E Mini DV Digital Camcorder
FD-88, viewing LCD in daylight, too bright
You're not doing anything wrong. Sometimes it's just hard to see to LCD. You could try turning down the brightness, or turning off the backlight, but that doesn't work very well either. There are sun shields for sale. I have a FD-88 also, And so far I've been able to see the screen ok in sunlight. But It's winter in Minnesota so the sun is low in the sky, and I can normally shade the screen with my body. Hope this helps.
Sep 11, 2005 | Sony Mavica MVC-FD88 Digital Camera
Vivitar ViviCam 8025 Digital Camera Logo
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
