Hi, my tv suddenly is in child lock mode, do you know how to unlock it? I have pressed and hold the display button for long time but it does not work. Thank you so much.
Is there a contact for the distributors or manufacturer in Australia?Same problem.
Remote is lost.
Cannot tune in any other remote.
I don't have the remote and was about to tune in the channels when I accidently hit the wrong choice and now its in child lock. How do I get out of the child lock?I don't have the remote and was about to tune in the channels when I accidently hit the wrong choice and now its in child lock. How do I get out of the child lock?
You can't post conmments that contain an email address.
I had the same problem with an AIKO TV. The childlock was on and initially I couldn't find the remote after moving. Unfortunately the only way I got it unlocked was with the remote. So I turned the TV off with the remote. Then turned it back on and then had to go into MENU and change child lock from on to OFF. Sorry no other handy suggestions if you haven't got the remote.
Unfortunately, you can't disable the child lock (front panel lock) without a working remote for the TV. If you can find a universal remote that will match the Menu function of the TV, then press menu and find the child lock option. Then press Volume + or Volume - to toggle it to off.
hi,
Check the following two procedures to unlock the tv.
1. Press and hold the display button on the remote for 5 seconds for unlocking the tv.. if doesnt help then,
1. Press VOL -- button on the frond panel of the tv and Child lock button on the Remote together. (remote should be faced to tv when you press the buttons)
2. Press MODE button on the remote
3. Using channel +/-- select chid lock
4. Enter New code
5. Press the mode button
OK
i think but im not sure but its worth a shot. turn the tv on then press and hold the power and action button on the set for 5 or 6 seconds this should reset the television and run a diagnostics test proceedure
The solution is so simple! Press the POWER (RED) button and the TV/AV button simultaneously - hey presto! the child lock will switch off and you will have your TV back working properly.
my AKAI tv is locked. All i see is a blus screen with a little red lock on the bottom left corner! the only button that works on the tv OR remote is the power button on the remote. PLEASE HELP i have tried pushing every button but nothing happens
i had same problem with telefunken ttv2931 child lock, tried turning off power,holding power button on and pressing each button, found by accident that holding down the display button for 5 to 10 seconds worked.
Press and hold the TV/AV button and then press the red on/off button, the TV screen will become black, and any buttons on the main unit or the remote control become inoperative. If you want to switch on the TV, press and hold the TV/AV button and then press the ON/OFF button again, the TV will return to the normal TV reception
It sounds to me like a child lock function, which is usually what the screen + padlock is on TVs. Usually your original remote would have a button / sequence to unlock the mode. If you still have your original remote, look for a child lock button or refer to your remote manual (and/or TV manual for the child lock feature) to unlock the mode.
We have a Aiko tv and cannot get the child lock off Any suggestions?
how do I unlock Child lock 54 cm for Maxdorf TV
Same my tv did the same thing i have no remote and am not sure wat to do
Same problem.
Remote is lost.
