Question about Ovens
Moffat monaco gas cooker. the hobs work but the oven won't work
Moffat monaco gas cooker. the hobs work but the oven will not work. No cooker light coming on or gas coming through - this might be something to do with the timer switches being interfered with & now we don't know how to reset them so the oven will work. Any help appreciated. .
4 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Beko D533 cooker only half working
Is the cooker a new one? I fit is then it does sound like an internal wiring problem, in which case you should contact the supplier. Make sure it is wired correctly from your circuit breaker first, There should be a diagram showing the connections.
Hope this helps.
Please leave feedback.
Posted on Dec 07, 2008
barkencoa
  • 3463 Answers
SOURCE: fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Posted on Dec 27, 2008
SOURCE: have a new electric cooker but the oven and 1 of
hi chances are that the internal thermal cutout fuse has gone this fuse is situated on the right hand side of the cooker when you have taken the back plate off about half way down it has two wires attached to it and is screwed with a self tap on the right hand corner of the body of the cooker near the middle of the cooker. You can buy this part and have it delivered for about £6 so is a very cheap fix.
Posted on Dec 03, 2010
The grill and ovens on my Jackson Topline cooker have just stopped working, the rings work but none of the lights above the switches are on when they are working, any Ideas please? thanks.
I am not familiar with your model of cooker but I assume it is a gas cooker.
Gas cookers have safety devices in the oven and grill the hob rings do not need. I speculate even the domestic oven hasn't escaped the interference from the electronics industry and I expect the aforementioned safety devices depend on (low voltage) electronics and electronics depend on electricity - that the lights aren't working would suggest there is no (low voltage) electricity.
Even in the case of an electric oven the thermostat could be electronic and need (low voltage) electricity to work.
I suspect the internal power supply has failed.
Jun 17, 2016 | Ovens Ovens
Gas hob will not light on my leisure gas hob
At the rear of the oven is a gas cut off valve. Try twiddling it
Nov 24, 2013 | Ovens
Oven won't turn on because someone played with timer
Try turning the mains supply off and it will probably reset everything.
Feb 01, 2018 | Moffat Ovens
Hi there, I have a belling gas oven cooker, which when you try to ignite the oven or grill it keeps ticking but wont spark up. The gas is fine as you can light them manually and the hobs light fine so...
why would they be trying to light an electric oven ( see which product do you think they mean ) You need to check that the spark being produced is close enough to the gas outlet
Oct 03, 2012 | Ovens
Where can I get a manual? Can it be downloaded? Thanks
.pdf user manuals can be obtained via steve.richardson@fisherpaykel.co.uk Quoting the exact model number located on the rating plate located on your appliance as detailed below.
Range Cookers
Behind the Drop Down Storage Panel beneath the oven door or on the Oven Chassis behind the door
60cm Freestanding Cookers and Ovens
On the Oven Chassis behind the door
Hobs
On the underside of the hob (any oven or hob situated underneath the hob may need to be removed to gain access.).
Feb 15, 2011 | Stoves Ovens
PRIMA FAN ASSISTED COOKER - FAN WORKING BUT NO HEAT?
Hi.
You will need to check the oven element, it probably needs replacing.
Please rate my solution.
Thanks.
Apr 27, 2009 | Bosch HBL 5032 Electric Single Oven
Oven does not work
its just your heater element you will need to wright down your model number and go on ebay or go to your local appliance shop they might order you 1 there about £35 pound
Jan 07, 2008 | Ovens
Problem with oven on Moffat Program Gas Cooker
Sounds to me like the oven thermostat has gone.
Dec 30, 2007 | Moffat Ovens
Hob broken
It sounds like the wiring has broken down inside the cooker at the terminal block or a leg of power is missing if the cooker is supplied by three phase electricity. Then there may be a problem in your service panel. Is it a 3 segment circut breaker or 3 fuses in the panel?
Dec 29, 2007 | Ovens
Ovens Logo
166 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
