Question about Philips GoGear HDD6330 MP3 Player
Philips go gear dozn't play anythng
It dzn't respond da compu.........
displays a msg-connect 2 d device manager 2 repair!!!
plz plz plz hlp me out!!!!
    President:
  • 392 Answers
You muat have gotten a cd alongwith the player...install philips device manager from the cd and connect the player to system.the program must detect the player and repair it by itself.
Posted on Sep 05, 2009
How to unfreeze Philips GoGear SA3021 Digital Media Player
To unfreeze, there is a "reset" option on the bottom of the unit near the usb port -- you'll need a pin or paperclip to reset it. To unshuffle, on the main menu go to the tools option (icon looks like a gear near the bottom of the screen), select "music play mode" then select "off." Took me forever to figure this out.
May 28, 2010 | Philips GoGear SA3021 Digital Media...
My player displays a message
Connect player to pc and power, restart player while holding the volume + key, as soon as the player shuts off, press and hold the volume - key, your device manager will pop up and tell you the player needs repair, let it do so.
Jul 18, 2009 | Philips GoGear HDD6330 MP3 Player
Not Detecting Go Gear IN Xp
Connect your Go Gear to the computer
Open the Philips Device Manager - it came on the installation CD
Click on the Repair tab and follow the instructions
When in doubt, follow directions.
-Tha (Mean Grinch) Mp3 Doctor
Dec 21, 2008 | Philips GoGear SA178 MP3 Player
Memory repair
Did you get a pop-up that said the repair was successfully completed? If not, then try the following repair instructions:
1) Open up Philips Device Manager (Start --> All Programs --> Philips) - if you don't see it, then re-run the installation CD or grab the "Device/Firmware Manager" from the Philips website
2) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
3) Disconnect the GoGear from the computer and turn the GoGear off (if you haven't done so already) - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new.
After this, you may be able to go back into Device Manager and click the Update tab to get the firmware upgrade which solves the memory corruption problem.
-Tha Mp3 Doctor
Feb 02, 2008 | Philips SA5125/37 MP3 Player
My MP3
The rule for this device is first reset (hold power on/off and volume + simultaneously and continuosly while the player is turned on; reset works when the power turns off), and then Repair if that fails. The problem with Repair is that it deletes every file from the GoGear. Here are better instructions for repair than the manufacturer's:
-Tha Mp3 Doctor
Jan 30, 2008 | Philips HDD1630 MP3 Player
Mp3 problems
With the SA4010, it is sensitive to downloading large amounts of information all at once. As painful as this might be, try downloading one song at a time.
If this is a problem that didn't exist before, try resetting the player once by re-inserting the battery. If single song downloads fail, and this is a new problem Repair the device (WARNING: this will delete all songs off your player):
2) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button (on this model, you will actually use the play/pause button instead of the volume + button)
3) Disconnect the GoGear from the computer and turn the GoGear off (if you haven't done so already) - hold in the play/pausebutton and continue to hold it as you reconnect the GoGear to the computer; after holding the play/pause button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the play/pause button); after the repair is successfully complete, your GoGear will be good as new.
-Tha Mp3 Doctor
Jan 29, 2008 | Philips SA4010 MP3 Player
Sa33 will not turn on
I would be interested to hear if you have Windows XP or Windows Vista.
Regardless,
If player is off and disconnected from PC,
You will now be able to load the firmware upgrade by clicking on the update tab in Philips Device Manager. The firmware upgrade should resolve the issue permanently.
-Tha Mp3 Doctor
Jan 24, 2008 | Philips GOGEAR SA6045 MP3 Player
Cant play files on my philips go gear 512mb windows media player
There could be several things going on:
1)Your music service subscription could have been cancelled
2)The device itself is not faulty. This is Microsoft's fault, not Philips'. Some of the songs may have Digital Rights Management (DRM) encoding that the SA178 will not support. You can right click on the trouble music file, select "Properties," and select the License or Digital Right tab - look for the msg: This file is not copyright protected. Find out if the songs that CAN'T be transferred have this message. If so, then click on acquire digital rights (or some variant of that phrase). If the files tha CAN'T be transferred DO have Digital rights protection, then you must save the files in a different format that is stripped of DRM encryption.
Otherwise:
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Aug 30, 2007 | Philips GoGear SA178 MP3 Player
My go gear
Make sure the player is on BEFORE pressing the volume+ and play/pause button. If the player shuts off, the rest was successful. If that fails:
-Tha Mp3 Doctor
Aug 20, 2007 | Philips HDD1630 MP3 Player
My philips 30gb wont play my songs!!!
-Tha Mp3 Doctor
Jun 20, 2007 | Philips HDD1630 MP3 Player
Philips GoGear HDD6330 MP3 Player Logo
136 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
