Question about Gaggia Titanium Espresso Machine
Gaggia titanium System stuck on 'machine is rinsing open knob'. Obviously tried turning knob, as well as machine on and off. Checked the stem pipe and it runs freely. Could the knob switch be broken? If so how do I fix it? Cheers, John
    Problem Solver:
  • 7 Answers
John, The duration of the rinsing cycle is equal to the amount of water you have in the water tank. I don't believe they tell you this anywhere in the manual! I own a Titanium SS and it rinsed and rinsed and rinsed the first time I performed it! I figured out it will just keep going until the water tank sensor tells the machine it is out of water which is equal to saying to it: "Thanks for using all the water i wanted you to use to rinse, now you're finished." Hope this helps, Tony.
Posted on Jan 04, 2008
Gaggia Titanium: stuck on 'rinse'.
Try first unplugging power cable for five minutes, see if this reset machine.
Aug 20, 2008 | Gaggia Titanium Espresso Machine
Tip
Gaggia Titanium, cycle is stuck on rinse and does not complete.
This problem is common on Gaggias. Sometimes if you wait 30 minutes or more, the machine will complete the cycle and go back to normal functions.
Just wait to allow time for the rinse cycle to complete, when machine is stuck it can take over 30 mins.
You can do this by continuing to fill up the water resovoir four or five times to see if the machine completes the rinse cycle on its own.
If that doesn't work contact Gaggia, US number is 888-389-4123, for contact number in your area consult your user manual.
Gaggias may give you some trouble of this kind from time to time, but they are good Italian brand coffeemakers, and the coffee is usually really great.
on Aug 26, 2008 | Gaggia Titanium Espresso Machine
After decalcifying our Gaggia coffee machine and it going through its rinse the messages says rinse finished close knob. The knob is closed but the message stays and the machine cannot be used as its...
A frequent problem with some of these is that the internal switch loosens up. It is a micro switch positioned so that the steam knob contacts the switch when you close the knob fully. You can try pressing in on the knob while you turn it closed and that will usually cause it to contact the switch and get you going again.
It will likely happen again and if it does you may want to open up the machine (if you are very handy with that sort of thing) and get the switch securely positioned so the steam knob closes it reliably.
Dec 13, 2010 | Gaggia Titanium Espresso Machine
Gaggia Titanium that continues to Steam.
You need a new valve. Try getting the stainless steel valve assembly.
May 03, 2010 | Gaggia Titanium Espresso Machine
Gaggia Titanium - lack of water/steam!
I have a Gaggia Titanium and the steam valve is leaking can I get repair parts for it
Mar 12, 2010 | Gaggia Titanium Espresso Machine
Steamer on gaggia titanium
a. Possible air in the system. Switch to hot water iso steam, let warm water pas for a minute by turning the knob fully open. Stop tapping warm water (close the knob) and switch the machine to steam iso water. Try to get the steam by fully opening the knob (pump should start running).
b. Solidified milk in the system blocking internal tubes. To avoid this always purge the system (shortly open the steam to an empty cup or a towel) after you steamed milk to avoid milk being sucked back into the system due to condensation of steam (this creates a vacuum and reverse flow). To resolve the blocked tubing: clean the nozzle and try flushing the system (tapping warm water).
Aug 24, 2008 | Gaggia Titanium Espresso Machine
Ventilate problem
need to go through menu to factory reset. This gets machine to ready. You now need to decalcify with a citric acid descaler, not vinegar. With the water tank filled with descaling solution go through the menu to rinse option and rinse machine. When finished rinse cycle and with remaining descaling solution push water button open side knob and rinse the steamer system with descaler.
Jul 24, 2008 | Gaggia Titanium Espresso Machine
My machine was stuck on rinse cycle now on ventilate...
Try first to continue filling up the water resovoir (UP TO FOUR times) to see if the machine completes the rinse cycle on its own. If that doesn't work contact Gaggia Customer Service in the US at 888-389-4123. Sally there was VERY helpful and should be able to resolve your problem.
Dec 31, 2006 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
361 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
