Question about HP Officejet 5610 All-In-One InkJet Printer
I can not get my printer to connect to my comupter. When it comes time to connect the cable from the printer to the cmoputer it fails.
  • michael937
    michael937 May 11, 2010
    you need to be more specific. where are you when it fails? what is failing?
    Problem Solver:
  • 19 Answers
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
aber3
Posted on Sep 06, 2009
  • 53 Answers
1st make sure the printer is turned on.try installing the driver without connecting the printer first..then connect when finish installing... if still can't connect it must be a problem with your usb port (commonly its the usb driver) or a faulty cable itself
Posted on Sep 05, 2009
HOW DO I CONNECT MY SEIKI TO MY COMPUTER. MY COMUPTER ONLY HAS AGV
QUICK GUESS IS A VIDEO ADAPTER CABLE OR NEW VIDEO CARD, BUT WHAT COIMPUTER MODEL (TO DETERMINE IF IT IS UPGRADEABLE AND TO WHAT EXTENT) AND HAT MODEL SEIKI tv TYO DETERMINE AVAILABLE INPUTS
hdmi INCORPORATE VIDEO AND AUDIO, BUT OTHER VIDEO CABLES DO NOT AND YUOU WOULD NEED TO CONNECT THE AUDIO SEPERATE TO THE TV INPUTS.
NEED TO BE SPECIFIC WITH SUCH A LOADED AND IMPORTANT QUESTION:
CONNECTING CIMPUTER TO TV Google Search
Sep 04, 2017 | Computers & Internet
Describe your bizhub 350 All-In-One Laser Printer Problem I can't connect computer with printer through LAN cable. The LAN connection failed every connection time
check the green light near LAN cable connector is glowing. if not replace the cable. if glowing go to the properties of printer & check if IP address is correct? many printers have unique IP address which u will find in manual of printer. try reinstalling printers installation software from CD.
Aug 25, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
My laptop is great but once im away from my router i use a internet usb device that alows me to use my internet, one day i come home and my comupter does not want to allow me to connect. it finds the...
I have had exactly the same problem, and although I didn't suspect it, all my troubleshooting including reinstalling of drivers, trying a different USB port and changing the channel on the router failed to cure the problem, pointing to a hardware issue. Indeed, a new Wifi USB dongle proved to be the full solution. I confirmed my old dongle was faulty by plugging it into another PC. Original problem was transferred to new location, confirming donglewas bad.
Nov 11, 2017 | ASUS G71Gx (G71GX-A1) PC Notebook
Just replaced the ink cartridges. Printer keeps telling me to turn it off then on. However, it fails every time I turn it on again.
With the power cord connected and the unit on, disconnect your data cable(s) from the printer (USB, parallel). Press the power button to turn off the unit; wait 15 seconds and then turn the power on again.
Check if the error comes back. If it doesn't, reconnect your data cable(s) one at a time, checking for the error message between adding each connection. If you see the error, replace that cable.
If the error did come back after cycling the power when no data cables were connected, you have to look at your power cable. If the cable has a power module (box that you plug another cord into), make sure that you have the correct one for the printer.
In either case, unplug the power cord from the back of the printer (first) and unplug it from any surge protector or power strip (second). If you have a power module, unplug the cord from that and reconnect. Wait 30 seconds. Plug the cord directly into the wall outlet and then into the back of the printer. Then turn on the printer.
Check for issues. If the printer turns on, you may have overloaded the power strip. If it doesn't turn on, you should check the outlet for problems. Try using an outlet in a different room (preferably a different circuit breaker). (Move the printer and its power cord.) If the printer still doesn't work, replace the power cord or module.
If none of the above works, the printer needs service.
I hope this helps.
Aug 02, 2010 | HP Photosmart C6180 All-In-One InkJet...
My creative zen is not charging or docking on my PC..please help
Try another usb port, or you'll need to check the cable. Borrow a friend own and see if you get the same problem or connect it to another cmoputer.
Aug 17, 2009 | Audio Players & Recorders
Which firewire cable do I use with my Digi 002 console?
If you are using a desktop comupter, you will need any 6-pin to 6-pin connection. If you are using a laptop, you will need any 6-pin to 4-pin connection.
Jan 12, 2009 | Digidesign Digi 002 Rack FireWire Pro...
I have misplaced or lost my connection cable to, the cable that connects the Kodak EasyShare camera CX7330 to the comupter so I can download my photos. Wher can I get one, please. Thanxs
By looking at the pictures of your camera. seems you need a stardard usb cable
Click here for a standard usb cable, same that is used in printers.
If you have such cable at home test does the other end fit to the camera if its too big then you need a smaller one.
possibly like this one - click here
if that doesn't look right either look for other cables on ebay.
click here
Just need to find the right shape and type of cable, there are not that many diffrent possibilities, theres no need to buy a brand new over priced one from kodak directly. in the end, its just 4 wires inside a black cable.. noting special.
Jul 23, 2008 | Kodak Cameras
Hd3
1. install the drivers from cd which came along with the player
2. check the USB adapter cable
3. Check the message dialong whenever you connect your USB cable to ur computer on the taskbar.
4.if you get message " one of the usb device connected cannot be recongised" then the problem with the Player adapter controller
5.your computer USB may be malfuntioning
6. check for the drivers installed. if not install drivers from the installation diskette
thank you
Nov 09, 2007 | Sony Network Walkman NW-A1200 MP3 Player
HP Officejet 5610 All-In-One InkJet Printer Logo
62 people viewed this question
Seeker5211
Seeker5211
