Question about PNY Verto GeForce FX 5200, (256 MB) PCI Graphic Card
I have an S-video cable ran to my tv and it only shows I have one moniter installed. I have my moniter as well as the S-video cable plugged into the pny card. should it be that way? I have also just bought a new tv, philips lcd wide screen...but it is not reconizeing it.
  • 33 Answers
Your connection are right. All you have to do is to configure it with the graphics software. You can select if you want to do a mirror or extended mode.
Posted on Sep 07, 2009
  • 3,153 Answers
First thing to do is to lower the resolution to say 800x600
call up the Nvidia control panel by right clicking on an empty part of the desktop and click the Nvidia CONTROL PANEL
there are two methods one is the MULTIPLE DISPLAY WIZARD (Just follow it through and it will do most of the work for you)
OR
Use the SET UP MULTIPLE DISPLAYS option. (my choice)
It is better to select the "CONFIGURED INDEPENDANTLY" option often knows as dual view.
Below that are two boxes the first sets the order of the display. Set it so your regular monitor is first on the list.
the box below that selects the PRIMARY display normally leave this to your default monitor until you have finished setting up both displays.
when you have two displays then go to the "CHANGE RESOLUTION" (still in the Nvidia panel not the regular display panel)
click on the display you want to change and alter to suit your taste.
now do the same for the other display.
If you get an "out of range" error drop the resolution as you are trying to do more than the display can handle
There are similar procedures for other makes of graphic cards.
Try avoid the VGA to component leads as they are hit and miss in this type of application.
S-Video is quite good
your best option is DVI and it the one I use to drive a 50" sony
You have to let your card know about other displays using the steps above or similar
Posted on Sep 05, 2009
Not reading monitor
please isolate the monitor. try using other good monitor and plug it into your desktop. if the monitor you use doesn't display it means the video card adapter is defective. you have to replace that one. otherwise vice versa.
Mar 27, 2010 | HP Compaq DC5800 Small Form Factor PC...
My video sound cords make a noise when plugged in. Also there is a line traveling up and down when the AV cords are in.
get new cords
prefferably hdmi
or if possible you could maybe even get the fail safe s-video cables
as long as your tv/moniter is compatible with it
Oct 19, 2009 | Sony Playstation 3 (PS3) Console
When I hook up my moniter it does not work like other moniters.
ok sounds like you have a broken pin on your cable if you look in the end of the cable plug the part thet goes into the box but also check both ends if they are there
failing that take monitor to roof and heave ho away it goes
Jul 25, 2009 | Compaq P 1220 22" CRT Monitor
No tv picture - only audio - after pc to tv box hook-up
Hi I am a silver surfer but this is how I got it working
First off get the program tou want to watch up on PC Moniter(screen) Then connect 3 cables
Yellow cables / One end to tv other end to yellow hole rear of PC/TV Box
Grey cable small end goes in PC/TV Box just behind the wirds "kworld" other end goes into back of your Computer ,you need to check your Computer manual to see the which one is the connection to your Computer screen(moniter),mine was blue with 2 screws , disconnect this and screw in Grey cable
Black cable narrow flat end into front bottom of Computer ,other end intoPC/TV Box end hole next to yellow cable
Switch on TV and change AV until you see your program, sound will be thu your Computer Speakers NOT your TV
THIS IS FOR A DESKTOP COMPUTER
Jun 15, 2009 | KWorld PC to TV (0872880887527) Video...
Hanspree monitor says,''No signal input check video cable''
ask the shop for a replacement cable. it could be broken.
Mar 26, 2009 | Computers & Internet
Asus v7100/64
i think the output for this vga is s-video cable...in my experience, if you connect the s-video cable to the TV with the support of s-video..it will automatically open at the same time with the monitor...is this what you mean? or else,try to explore in the bios setting if theres an option for video output enabling..jz try only my solution..if the same problem,give some more details.
Oct 19, 2008 | ASUS V7100 Pro (64 MB) Graphic Card
Male moniter plug on both moniters(every one in the world) and motherboard
That Male connector is a serial port not video, you need to get a video card and plug the monitor to this card.
thanks for rating
Jan 10, 2008 | ASUS K8N-E Deluxe nVidia nForce3 250...
How do i connect my computer to my tv
you shuld have s-vedio out from your vga card
if have it now you can connect it from the cable coming with card
Dec 16, 2007 | Compaq Deskpro 2000 PC Desktop
Connect Playstation 2 to computer monitor
try going to your local radioshack and asking for a cable to do it. Tell them it needs to be "double male" infering that the piece sticks into another part instead of bieng stuck into. Then tell them one end needs to be "RCA cables" (the red white and yellow ones) and the other end needs to be a computer moniter cable. There are several types of moniter cables you can use, look in the back of your moniter to see what you have. There should be writing that says any 1 of the following "s video in", "dv in" "video in" etc. ask the radioshack man to get the non RCA side of the cable to have one of these on it. If you need to, it helps to take a picture of the back of the moniter where all the input plugs are, and show it to the radio shack man, he can probably help decide which cable to use. Once you buy the cable, plug the red yellow and white side into the red yellow and white holes respectively on the PS2, and the moniter cable into the moniter. Turn on the moniter and the PS2 and... Voila. PS You may need to take out the cable connecting the moniter to the PC to put in the new radioshck cable. I hope this works for you-BCA
Aug 26, 2007 | Sony PlayStation 2 (PS2) Console
PNY Verto  GeForce  FX 5200, (256 MB) PCI Graphic Card Logo
153 people viewed this question
Top PNY Computers & Internet Experts
David
David
pankaj rautela
pankaj rautela
Alun Cox
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
