Carrier Air V in RV not working - 5 green blinking lights error
We have the same problem as of this morning . . . don't have the fixyet, but have located (2) manuals that I will enclose the links for. The 5 flashing green lights is mentioned in the ''Service Manual'' inSection 2 ''Troubleshooting'' with 5 possible remedies. Manualhttp://www.transportaircon.carrier.com/Files/Bus/Local/US-en/T298.pdfand Parts Listhttp://www.transportaircon.carrier.com/Files/Bus/Local/US-en/T298PL.pdf We're under warranty so will take our RV in ASAP
  • 6,674 Answers
Call 1-866-464-2478, Mon-Fri, 8am-5pm. Have model numbers of lower (inside control box etc) and upper unit ready, and I'd ask for technical assistance. Good Luck.
Posted on Sep 16, 2009
Green blinking light
my carrier ac won't start and the green light was blinking with the timer light
Aug 02, 2013 | Carrier 36KCARMS Air Conditioner
How do you know remote is working?
Fresh batteries in remote? Will AC turn on by manually at ceiling assembly? Little green or red light on at ceiling assy? Have you checked Carrier site for manual to download?
Feb 23, 2013 | Dometic Rooftop RV Air Conditioner
We are in a 5th wheel RV. We have a factory installed Carrier a/c in the kitchen. Lately, it shuts off during the night and we have to reset it in the am in order for it to work. It works fine during...
If the outdoor temps are cooler than inside, AC's are not made for this and will not work well if that is the situation, it floods liquid to the compressor which will overload. will it reset within 20 mins of going off? if so the board/stat are suspect, if not the compressors the villain and its tired and cant handle the other than design condition of 95 F outdoor/80F indoor.
Sep 09, 2011 | Dometic Rooftop RV Air Conditioner
Fan Runs, AC Doesnt, Blinks 5 times
Need to look around and should have an error code and give more detail of what the problem is. If you post that i can maybe help you more. I need to know......
Aug 19, 2009 | Dometic Rooftop RV Air Conditioner
Carrier A/C in RV won't run
check your breakers make sure when running unit this is the only thing on the breaker 15 to 20 amp be sure to keep a window cracked as well unit does freeze over so don't have all the way on cold
Jun 23, 2009 | Dometic Rooftop RV Air Conditioner
My carrier A/C turns off by itself but the light blinks
Switch OFF the circuit breaker of ac, after 5 seconds. Switched ON the circuit breaker. If this will appear again try to check the wiring connection of ac.
Jun 17, 2009 | Carrier 36KCARMS Air Conditioner
Carrier Air V roof mount with remote. Does not cool. On light blinks 5 times then repeats blink code. What does the 5 blink code mean?
We have the same problem as of this morning . . . don't have the fix yet, but have located (2) manuals that I will enclose the links for. The 5 flashing green lights is mentioned in the "Service Manual" in Section 2 "Troubleshooting" with 5 possible remedies. Manual http://www.transportaircon.carrier.com/Files/Bus/Local/US-en/T298.pdf and Parts List http://www.transportaircon.carrier.com/Files/Bus/Local/US-en/T298PL.pdf We're under warranty so will take our RV in ASAP
Mar 03, 2009 | Heating & Cooling
Can't get airconditioner to work
Hi
Try to reset the unit by disconnecting the power supply for 10sec. and operate the unit. If wont work then there are some safety device that work or defective. Try counting the blink of your green light so that I can convert the error code.
Dec 25, 2008 | Heating & Cooling
I need to know what 5 blinking lights mean on a 15000 keystone outback rv 5th wheel
Owners manual should be located in one of the cabinet draws. The manual should explain the meaning of the lights.
May 21, 2008 | Carrier Heating & Cooling
The unit won't turn on an green light blinks
Reset the error by unplugging the power or turn off the circuit breaker for 10 seconds and power the unit again and operate. If it wont work then you need a qualified technician to correct the error.
Mar 01, 2008 | Carrier 52PQ307 Wall/Window Air...
Heating & Cooling Logo
2,057 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
