Question about Kenmore Dryers
The plug hook up
I just moved for the third time in 3 years and the plug is back to the original but i don't have the manual to hook it up. any help?
  • 110 Answers
If you are talking about a dryer, this is what to do
if you are changing a 3 prong to a 4 prong
as long as you have the white in the middle terminal the red and black can go on either sides.just make sure the white in the middle and the red is on the right or left. the green is ground so hook that up to a screw
if it is from 4 to 3, just make sure the middle of cord is in the middle
thanks
Posted on Sep 11, 2009
Asus 401a rev.2.0 bios password reset
You will probably need to 'default' the mainboard. There should be a 'jumper' (set of 3 pins with a small cap spanning two of them) may say CLR or similar in silkscreen on the board next to the jumpers. Definitely get a manual for your computer to help you find this jumper - hopefully it will be as simple as moving the cap to the third pin (move from pins 1 and 2 to pins 2 and 3) This will short the CMOS and clear it. If everything else is default settings - then you are good to go. Move the jumper back to original position and try to start.
Dec 30, 2013 | ASUS Computers & Internet
I need a spark plug wiring diagram for a 4.6l Triton V8. 2001
Your shouldn't have any spark plug wires on your vehicle. There should be a coil on top of each spark plug. The firing order is 1 3 7 2 6 5 4 8 if that helps. I went back a year incase you had a late model 2000 but that 4.6 also has a coil on plug. If you do have spark plug wires, I don't think that's the original engine then.
Nov 21, 2011 | 2001 Ford Expedition
We just recently moved and the original house had a 4 prong dryer connection which my Matag neptune has. The new house has a 3 prong outlet. I have purchased a 3 prong cord. How to do I hook up the...
DON'T DO IT!!! Get an electrician to install a 4 prong outlet for you. Your exposure is DEATH, be safe and get the correct outlet.
When some types of failures happen, you can charge the CASING of the washer. then you can become the connection to ground.
Get the correct outlet, return the three wire plug.
Jun 24, 2011 | Dryers
Don't have the model #s, but had bought a lg sump pump a year ago or so, it float failed - did not go off. now bought another one yesterday, a smaller model, but we have to lift the float manually,...
I would make sure that the pump is setting securely in the pit so that it can not move and hang the float up on anything.If you have a lot of trash or debris in the pit then unplug your pump and remove and clean regularly I have used bricks or wire to hold the pump in place to keep the float free.
One of the best pumps that I've sold for over 25 years is a little giant. They have a 1/3 H.P. model with the float secured on a rod hooked to the pump casing so it can only move up or down. Hope this helps. Thank you.
Apr 19, 2011 | Flotec Electrical Supplies
Where do i hook up my x box 2 the computer
It's quite simple actually. All you need to do, is buy one eithernet cable and have a router. (continued below)
Step 1. If it's an Xbox 360 it would've come with one ethernet cord. If it's an original Xbox, then you'll need to buy 2 instead of the intended 1.
Step 2. Make sure the ethernet cable from your modem is in the back plugged into the router, also make sure that another cable is plugged into the back of your computer and also to the back of your router (thats what one of the cables is for).
Step 3. Now take the second cable (the one that you bought) or the cable came with the xbox system and plug that into the back of your system into the ethernet slot.
Step 4. Plug the cable you just plugged into your system into a third open slot on the back of the router and Voila! you are ready to "Pwn The Noobs" on a 'lil XBL. Mind you that Xbox Live does cost money ($50 or so a year). Now you can play with friends, transfer pictures or movies or music, depending on if its an original or xbox 360!...I hope this helps
~Mr. Lonely~
p.s. - You will need to do a few more things: go to system setup on the xbox dashboard (all the way to the right on the screen where your profiles are kept) then go to computer setup. Then you will get a code to enter at www.xbox.com/pcsetup
The above will only hook up the Xbox 360 console to the INTERNET by routing the internet to it, a router just splits the internet and assigns internal IP addresses in order to allow internet use by both the computer and the Xbox console. If you meant how to hook up the console to "Browse" its hard-drive/DVD drive/etc., it is not quite as easy. You should look up "Xbox 360 hotswapping" in google or something and that will show you how to view the hard drive contents.
Have a nice day and do not forget to rate please...!
Dec 24, 2010 | Computers & Internet
I was sewing all was going fine and suddenly it wont pick up the bobbin thread everything seems to be moving what do i do i tried to reset clutch but when i push the button it wont move back ???? help...
perhaps you had a little jam of fabric or thread and threw off the timing of the hook that helps pull up the bobbin thread. the manual shows you how to loosen the screws and move the hook back. Might take a couple of times and be sure to tighten the 3 set screws well when you get it right. They are under the machine, so you have to loosen the belt and lay it on it's side.
Can't remember where I downloaded the manual last year, but on page 13 it shows the instructions. The photos are bad, so watch carefully. Try consew.com and download 206rb-5 manual. looked the same to me.
Not easy to do, use a flashlight and follow exactly and it will work. I did it the first time and I am not a guy and not a mechanic.
HS
Nov 05, 2010 | Consew 226R-1
Is third time a charm. Again several years ago I
Here is the owner's manual for your DVD machine. This is a VHS recorder but not a DVD recorder. To record VHS tapes to DVDs, you will need a DVD recorder.
You will plug the yellow video out connector on the VHS to the yellow 'Video in' connector on the DVD Recorder. Do the same for the red and white audio connections, out on the VHS, IN on the DVD Recorder. Connect your TV to the DVD recorder so you can see the picture you are recording.
Mar 31, 2010 | Televison & Video
Just purchased a new sony cable (av). The original one had bent connections. Properly hooking it up, I have sound but no picture.
try moving the connection wires around a bit. make sure they are in all the way, and also try turning the plug in the back of the tv around a lil. hope this helps
Mar 24, 2010 | Sony Playstation 3 (PS3) Console
Red light flashes 10 times - Panasonic TH-42PX6U
hey there! i finally figured it out!! If you have a computer hooked up with the HDMI cable in the back of the TV and the computer is either on screen saver mood or sleep mood then it is trying to make the television go to sleep aswell. So the only way you can have a computer hooked up to the TV is if you use the front HDMI hook up. pretty weird but thats what was wrong with mine. Hopefully that was the problem :):)
Nov 02, 2007 | Panasonic TH-42PX60U Television
Dryers Logo
27 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
