I cannot log on to network address 192.168.0.227
  • 60 Answers
Try 192.168.1.1 or 192.168.0.1
Posted on Sep 21, 2009
  • 1,272 Answers
I believe the product that you have is WG602.
Correct me, if I am wrong. To login to this AP, please reset it once and follow the steps below:
1. Click start button (extreme bottom left corner of the screen).
2. Click Control Panel from the list.
3. Click on Network Connections.
4. Right click on Local Area Connection icon and click on properties.
5. Select Internet protocol TCP/IP from the list of components and click on properties.
6. Select use the following ip address.
7. Assign ip address as: 192.168.0.30 ; subnet mask as: 255.255.255.0 then click on OK
Open the Accesspoint's web interface using the following way:
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the Accesspoint (usually http://192.168.0.227).
3. Login to the Accesspoint (username = admin password = password unless you have changed it).
Posted on Sep 05, 2009
Netgear fs516 default ip address
switches do not normally have ip addresses as they are layer 2 network devices. They work on the MAC address of each network card attached to it to direct the network packets of data to the correct Network card.
Cisco Switches have an IP address but it is a virtual ip address used to remotely log into a Cisco Switch via IP but has nothing to do with the switching function however this is not a cisco switch.
Routers have IP addresses and use them to switch IP addressed packets to other Networks that have Routers connected to Switches.
Jun 30, 2014 | NetGear FS516 Networking Switch
How do I change my new email address to my FB acct- I log in with that
go to facebook account setting and change were your old email is typed in
Apr 19, 2013 | Facebook Social Network
Need the network key
  1. Type http://192.168.2.1 into your web browser address line to log into the 5461. (If you have changed the default IP address, please enter your own)
  2. Enter your user name and password.
  3. Once logged in, select the Wireless tab.
  4. You can see the wireless security from there or network key
Jul 10, 2011 | U.S. Robotics USRobotics USR5461 Wireless...
How do I determine actual threats to my network while reviewing my wireless/network Router's Event Log?
Logs are meant to see the activities handled by your router. However, to determine any threat you can check for the IP address of the devices you have connected to your router. You can determine if any one else is trying to access your router by their ip address only.
Note down the IP address for all the devices that you have connected to your router. Than match the your devices IP addresses with IP addresses you found in the logs.
Matching IP address: Means your devices accessing the router. Unmatched IP Address: Someone else's devices trying to access your router.
You can always add security by using WEP/WPA2 key security. For further security you can encrypt the keys.
Jul 06, 2011 | NetGear WNDR3700 Wireless Router
My friend used my phone to log into her facebook account..now when i try to log in wit my email address and password it takes me bck to the log in page shown her email address and askn for her password.
try clicking on the the emial address bar to change it to yours or try logging in with her own and it will give you an error message and log in as a different user
Aug 07, 2010 | Facebook Social Network
I have a yellow machine p400t and i need to give it a static IP address and do this through a linksys router. how do i go about this? do i need to attach it to a computer?
Yes, it must be attached to the network 0. Install the yellow machine software on the PC 1.Log on to the Yellow Machine Manager. Go to “Logging On To Yellow Machine Manager” on page 8. 2.From the Yellow Machine Manager, click Network > Network Interfaces. The Network Interfaces window appears. 3.Click Edit. 4.Select Yes to Enable LAN Interface. Default: Yes (Enabled) • If you select No, all other LAN option fields are blocked. • If you disable the LAN Interface, the only access to the Yellow Machine appliance is through the WAN port. Anthology Solutions does not recommend this configuration. 5.Check Enable DHCP Service if the DHCP service is needed for the PCs attached to the Yellow Machine appliance’s LAN ports. This setting makes the Yellow Machine appliance the DHCP server for your LAN (or sub-network), providing IP addresses dynamically for the clients connected to the LAN ports. Default: Checked (Disabled) 6.Select either Obtain IP Address Automatically from DHCP Server, or Static IP Address. Default: Static IP Address • Choose Obtain IP Address Automatically from DHCP Server if your Yellow Machine appliance connects to either a router that has DHCP service enabled or to a cable modem. This setting makes the Yellow Machine appliance a DHCP client on your network. • Obtain IP Address from ADSL provider is greyed out. • Choose Static IP Address if your network is locally defined and controlled and does not use DHCP services. Type the IP address manually. 7.Specify IP address and Subnet mask if you selected a Static IP Address, and click Apply. 8.Click Yes to confirm, No to abort. The changes takes affect within five seconds after the network interface change notice appears.
Jan 26, 2010 | Anthology Solutions Yellow Machine P400T...
Logged off
The LAN should not ever log off but either you are talking about the Internet, which can, microwave devices (ovens, wireless phones) that intermittently interfere or dynamic ip addressing cycles that assign you the 169.xxx.xx.x from within Windows attention deficit disorder manager. You can assure static assignments of ip addresses for your LAN (write down the ip address and default gateway when you are logged on to see what they should be) or log on to your router (Start>Run> type http://192.168.1.1 for Linksys, user name linksys, password is admin and you can configure your LAN and WAN. Select DHCP for cable modems, PPPoE for DSL or STATIC for ensuring LAN ip address assignments. ~Steve
Oct 17, 2008 | Linksys WUSB100 Wireless Adapter
Need an IP address?????
yes you can create the ip address of the network to make sure the security and to access the network functionally.
Jun 10, 2008 | Belkin Wireless G Plus MIMO (F5D9010)
Networking the intellinet 503181
There are a couple things to check. Make certain that you have port forwarding enabled for port 80/80 to the IP address of the camera. Make certain that you have port forward for port 8080/0 to the IP address of the camera. Find your IP address for your Internet connection - you can go to ipchicken.com and it will display your IP address for you. Then open your browser, type in your Internet IP address on the address line and hit enter. That should bring up the guest log in window and you can log in to view the video stream. If you want to log in to the camera console to change configurations, just type the camera user name and password instead of the guest user name and log in.
Hope this helps!
Dec 31, 2007 | Intellinet Active Networking 550703...
Computers & Internet Logo
762 people viewed this question
David Payne
David Payne
