Question about Craftsman Garden
Sears LT3000 won't start/crank
I have the same problem as BryanWhite70. I have the Honda engine. Battery is good, oil and plugs are good. It just stopped working on 9/3/09. I do NOT know how to short it to test. Also, I cannot locate my owners manual to ID the starter solenoid, let alone know what I'm looking for to get a replacement part from the friendly Sears parts department. Any help would greatly appreciated. The grass is getting taller by the minute.
bbtoast
  • 319 Answers
SOURCE: 1981 Corvette will not start
The neutral safety switch is located in the shifter housing.
Here is a link to a good article on this topic, that would beat an explanation from me.
Brian
Yes, it sounds like the NSS is the culprit.
Posted on Aug 04, 2008
  • 16 Answers
SOURCE: Husqvarna LT2042
the soneloid switch sends power to starter . check power on red wire on starter when key on full .if no power must be soneloid switch problem even though it clicks
Posted on Nov 11, 2008
SOURCE: replacing a 97 honda accord starter
i haven't fixed the problem but I don't have any money to pay for a plan on here. thank you anyway.
Posted on Jan 15, 2009
  • 508 Answers
SOURCE: 1966 Mustang 289 V8 auto 2b new battery and solenoid-won't crank
Check the battery terminals. If they have become corroded you could be getting a bad connection. When the starter is engaged it creates such a power load at the connections that it will arc and loose power. Or, you could have a bad ground wire off the battery. Also check the positive cable leading down to the starter. Most of the mustangs had the battery cable leading to the starter between the engine and the exhaust manifold. Eventually they melt through and can cause a short. This would require replacing the cable. Good luck.
Posted on Mar 15, 2009
  • 376 Answers
SOURCE: Engine won't Start
If you have 3 qts. of oil in your mower, drain it immediately. It only holds 3 PINTS or 48 ozs or 1 1/2 qts. Next, remove your spark plug and put the end away from the hole (to prevent possible arching and fire) and crank the engine over. Probably, a lot of oil/gas will blow out, clearing your cylinder. Clean the plug and try to restart. If it still reaches a point where the engine will not turn past while trying to crank, the valves need to be readjusted. Also check by smelling the dipstick that there is no gas mixed in the oil. That would mean your carb needle and seat are leaking.
Posted on May 24, 2009
My honda ran well until I hooked tail lights up and now I have neutral light and oil light no other lights work also it don't fire when I crank it lights come on as long as its cranking
Hi, Steve and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Faulty fuel pump fuse or relay.
11. Security alarm needs a reset.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
82 Honda Goldwing 1100 won start
Bike Will Not Start GL1100 Information Questions goldwingdocs co
1983 GL1100 Aspencade won start
https://onedrive.live.com/?id=978916B005999849%21109&cid=978916B005999849 manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 23, 2016 | 1983 Honda GL 1100 Aspencade Gold Wing
2001 honda s2000 cranks but won't start. Just
see the diagram attached. by pass the starter and try IT. God bless you
Jul 18, 2013 | 2001 Honda S2000
Changing the gear oil ?
see this instruction. God bless you
    • 1
      Park the Honda Foreman on flat ground and leave the engine running for 5 minutes to allow the engine to warm up. Place the oil drain pan under the crank case drain plug. Turn the engine off.
    • 2
      Remove the drain plug from the under side of the crank case using the ratchet set. Allow the engine oil to drain into the oil pan. Replace the plug to the bottom of the crank case and tighten the plug using the ratchet set.
    • Sponsored Links
    • 3
      Remove the small screw from the side of the crank case using the Allen wrench. Remove the cap labeled "OIL" from the top of the crank case. Insert the funnel into the hole where the oil cap was.
    • 4
      Pour Honda 4-stroke engine oil into the funnel until the oil starts to come out of the hole where the small screw was on the side of the crank case. Once the oil starts to come out of the hole, stop pouring and replace the screw. Remove the funnel and replace the oil cap to the top of the crank case.
Read more: http://www.ehow.com/how_6512146_change-oil-honda-foreman.html#ixzz2ZPlA2Cu0
Jul 18, 2013 | 2004 Honda VT 750 Shadow Aero
1995 honda civic won't start even with a jump
Well the battery and alternator would not have anything to do with the engine starting.
You would need to check the ignition system to see if you are getting the correct spark at the plugs when the engine fails to start.
Jul 17, 2013 | 1995 Honda Civic
Car would start sometimes and sometimes would not. now it will not start at all,there is no crank but there is a clicking, lights on dash n stereo etc. works.Two days before there was oil in the spark
First thing you need to know is if the starter has voltage, and if the engine crankshaft can turn. If the starter has voltage and a good ground, the battery is fully charged, and the crank can be turned by moving the alternator belt, the starter may have died.
If the oil was on the outside of the spark plugs your valve cover seals may be leaking.
Feb 02, 2013 | 1991 Honda Accord
Motor will not turn over. Checked air filter compartment to find 2 oz. of oil and filter soaked.
Not sure if you mean engine will not turn at all (locked) or engine will not start. The engine may have been on its side causing this condition. Clean carb and filter of excess oil. Remove spark plug and clean cylinder and plug of oil that may have entered causing locked condition. Replace oil lost from crankcase. With spark plug removed and kill swith on off, pull rope to blow out oil and verify that motor will now turn. If it still does not turn could be lock rod to crank or faulty pump. If engine had very little or no oil in crank and was run, suspect locked crank, however if your engine has oil senser, this condition would have prevented engine from starting. If you mean that engine will not start, low oil senser most likely preventing start due to low oil. Good luck
Apr 04, 2011 | Honda 2500 PSI Gas Pressure Washer
Craftman lt3000 lawnmower just stop running and can't get it to start. have tested battery and spark plugs both r good.
The ignition module on the engine may have gone bad. it may need to be replaced. Plus check air filter to make sure it is clean.
Sep 26, 2009 | Craftsman Garden
1994 honda accord will start fine for weeks then all of a sudden won t start but if i turn on the key put it in gear an pop the clutch it will start but sometimes it will start ok sometimes it won,t
Hi,from the clues you give I guess that the starter motor is in need of a service (worn brush gear) I presume that when it does not start that the engine does not make a cranking noise.
If the engine is cranking but failing to fire up, then it could be anything from the fuel pressure pump to the engine control system. there is a lot of clever stuff going on when you start your engine. Some simple things you should try first. Check visually that all vacuum hoses and wiring is secure and in good visual order( dodgy looking wires are prone to intermittent failure!... Do this next time it fails to start and recheck after gently adjusting ? wd 40 may ease problem temp. Also check service of spark plugs especially correct gap.
Make a note of engine temp/ and air temp. loose wires are usually more loose in cold mornings!.. starting enrichment may not be sufficient with a wide plug gap. Check battery for full power output on starting. will it pull the car on the starter /
Aug 27, 2009 | 1994 Honda Accord
Engine won't start
in the engine.
1. you may be low in oil
2. poor electric flow. (spark plugs, high tension wires, etc)
3. bad compression
4. bad fuel-air mix
have a mechanic check.
hope it helps.
Aug 05, 2008 | 1994 Honda Accord
Garden Logo
258 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
