Question about Welding Tools
Have a linde hda 300 welding machine when in the tig mode with remote control foot pedal the current control goes from 0-100 no in between control
    Problem Solver:
  • 17 Answers
Your foot pedal should adjust the current, just like a sewing machine. If it is not working either the foot pedal is broken or your welder isn't compatible for the foot pedal. Some welders are only strike starting with no variable control amperage (usually your lower end models).
Posted on Sep 05, 2009
When using foot pedal for tig welding,does foot control ,increase voltage,and control the argon valve
The flow of the gas will be initiated and terminated by the use of the pedal, but it does not change the flow rate, just on and off. You will adjust your desired flow rate at your flow meter or regulator. I prefer a flow meter as I find them to be more accurate and easier to use.
The foot pedal will initiate and terminate the arc when used on a HF start tig welder. It works like a gas pedal. For example, if you have your machine set to 100 amps, by pushing all the way down on your foot pedal you'll get 100 amps. Some guys will set their machine wide open and just control the amperage with the foot pedal. I don't do it like that, although there is nothing wrong with doing it that way. I like to have a bit more sensitive amperage control. I will set my machine a little higher than I think I need and feather the foot pedal from there. This allows me to start at a low amperage and also taper off a bit smoother at the end.
Jan 18, 2016 | Welding Tools
Dynasty 350 tig welding machin
When the display shows RMT it means that the torch trigger is depressed. If that is not the case then the trigger might be bad or shorted.
http://www.millerwelds.com/om/o245729c_mil.pdf
Jun 08, 2013 | Welding Tools
Hi, starts to weld fine after a few seconds hi
It sounds like you need to change out your SCR chip on your motherboard; Miller makes one that i have installed on all our 350xl's, I don't have the number on hand but i can get it for you tomorrow.
Oct 20, 2009 | Welding Tools
Linde welding machine when welding in tig mode foot pedal will not control amphere output it goes from 0- 100 no in between
Check to see if the remote switch has been set, or if you have broken wire in your pedal lead. You might even want to open the pedal housing and take a look see. I've had more than my fair share that the contacts inside the pedal housing were worn or cooked. Good luck, hope it helps
Sep 03, 2009 | Welding Tools
LINDE HDA 300 TIG WELDER HIGH FREQ. PROBLEMS
The contact should have a gap .008 .
Mar 21, 2009 | Welding Tools
Lost temp control on foot pedal & thumb control
If you have both a foot pedal and a thumb control and neither is working, the problem could be in the 14 pin remote connector on the welder. The pins inside the connector can get worn out and/or broken with regular changing of the remote.
You could also have a bad PC2 board, the front panel control comes after the interface to the remote control.
Regards,
Carl
Jan 09, 2009 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Bad tig weld job
Wow you have a lot of variables here. Let's go over some of them.1.AC current 2.100%argon shield gas 3.Check your Tungsten, it must be the recommended 1or 2% and the right size, clean and the tip rounded by meting 4. High freq. turned to continous-not just "START"
5. CLEAN,CLEAN,CLEAN your Alum. with a S.S. brush that has touched NOTHING else in in it's life!
Start here and GOOD luck
Dec 18, 2008 | Welding Tools
Welding Tools Logo
296 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
