Question about Dryers
Drive belt gone slack and worn, now seems too long! Aslo it's frayed. how is it removed and replaced
  • 867 Answers
Make a drawing of the loops, remove by pulling it off pully ,you will see a spring tensioner, thats what keeps it tight. also you will see a safety switch that is activated if belt breaks. easy to replace.
Posted on Sep 05, 2009
How to replace drive belt
Unplug it from the electrical outlet.
Remove the back panel.
Look for the "idler-wheel" -- it takes-up the "slack" between the drive-motor and the rotating tumbler.
Loosen it, to put enough "slack" in the drive-belt that the drive-belt can be removed.
Take the belt to a dryer-service store, and get them to match it.
Connect the new belt to the drive-motor and the tumbler.
Adjust the "idler-wheel" to take-up the slack.
Replace the back-panel.
Add power.
May 31, 2015 | Asko T712C Dryer
Tip
How to replace a drive belt
The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
- Loosen the bolt on the motor bracket and move the motor to put slack in the belt.
- Remove the old belt and stretch a new one into place on the pulleys.
- To put tension on the new belt, use a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. The belt should have about 1/2 inch deflection when you press on it at the center point, midway between the pulleys. If the belt is too loose, it will slip on the pulleys, causing the machine to malfunction. If the belt is too tight, it will wear very quickly and will probably become so hot that it will start to smoke or smell.
on Jan 16, 2010 | Washing Machines
Loud, low (bass) noise, not coming from the vent or the heating element
Most probably caused by one of the belts being frayed and about to break. You might want to replace the small drive belt (00096426) first as it does the most work of transferring the motor power to the shaft causing the drum to rotate. A worn belt can cause a low frequency hum and potentially slow down drum rotation as it slips on the hubs. Replacing the large drum belt requires a lot more work than the drive belt because you must remove both the front and side panels of the dryer; whereas, the drive belt is accessed by removing the right side panel.
Apr 25, 2015 | Bosch Axxis WTA 3510 Electric Dryer
Drum seems to be hard to turn and sqeals ?
Probably the motor and belt alignment, or a loose belt. Remove the access panel to expose the drum and the motor. Check to make sure the belt is not worn, frayed, or showing cracks. You should be able to purchase replacement parts online from the OEM website by referencing the appliance model number.
Oct 20, 2014 | Dryers
How to change dive pulley for 944602660?
This is likely due to a worn and slipping belt. Replacing the belt should solve the problem
Aug 03, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Have a craftsmand 24" snowthrower
If the motor runs well, the two most common causes of this are the drive belt is worn and/or the shear pins are broke.
If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belts.
Your operator's manual will show you how to remove the cover and check/change the belts.
If you don't have a copy you can get the manual through managemyhome.com
You will need the model number off the snowblower. It is usually located on the bottom right hand corner of the frame (from the handle side)
The model number looks like 247.123456.
The belt closest to the blower assembly drives the auger/blower and the belt closest to the engine drives the transmission. It sounds like you need to inspect the blower belt.
With the engine not running, have someone depress the drive lever and check the belt.
You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced.
On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt) It may be torn and broke completely.
Replace the belt if it is worn, stretched or frayed
The shear pins are located on the auger in the front of the machine. Your newer Craftsman has four. If you don't now about them look in your operator's manual for the location. You need all four for the snowblower to work well. Replace the missing ones.
You can get parts for you Craftsman and most MTD made models through searspartsdirect.com. With other makes you can get parts through jackssmallengines.com
If you are unfamiliar with repairing machines you can get your snow blower repaired by taking it to your local Sears.
They will have a technician troubleshoot and repair the unit.
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Craftsman Garden
Is it possible for the belt to stretch out so much that it won't engage the blades. It worked last year and now it doesn't. I have looked at all the obvious possible problems and it appears that none of...
your belts will stretch out and only have a life span of 1 or 2 seasons. There should be nearly no slack once the blades are engaged. Make sure it didn't slip off any of the pullys and the belt tensionor is on correctly. Check belt for cracking or fray makrs on edges as these are clear signs of a worn belt.
May 11, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Just got alternater replaced a couple of months ago and its starting to squeel again like last time and the battery light keeps flickering on and off
The alternator drive belt is loose or worn out. If the alternator is driven off a serpentine belt then replace the belt. Inspect the serpentine belt tensioner and replace if necessary. On an 18 year old car it is more than likely defective. If it is driven off a standard drive belt then adjust the alternator to tighten the belt. Inspect the belt for fraying and or cracks and replace if you see any.
Dec 17, 2009 | 1991 Honda Civic
Belt is slipping
your macnine needs some maintenance. slippage on the proform is usually due to a worn out front roller and a worn motor driving the belt. both can be replaced. or you may want to find a good used one as many get no use before the optomististic owner decides to sell.
Aug 17, 2009 | Proform CrossTrainer Treadmill
Top loading whirlpool leaks during drain cycles. Back hoses are ok. Of the two visible drive belts at the bottom, one is fairly slack (not the belt coming off the motor, the other one). Should both...
Hi mate the answer to your question is that all belts should be tight but could be a clue to your fault where the belt is slack check to see if there is bushing is worn see if there is play on the shaft if so replace the unit
Jul 18, 2008 | Whirlpool Washing Machines
Dryers Logo
Top Dryers Experts
