Question about Sunglo Black Portable Liquid Propane Gas Patio Heater
Pilot light will not stop on plenty gas will not fire up.
    Champion:
  • 274 Answers
If the pilot lights, but goes out when you try to turn on the main burner, then you most likely need a new regulator. If the pilot will not light at all, even manually, then there is most likely a blockage in the pilot jet. You will need to take apart the head to clear the blockage. If you are not comfortable with this, here a service tech.
Posted on Jan 10, 2010
I can get the pilot light to stay on but main gas burner won't fire up
If the pilot is lighting and the thermo couple is in the fire and turned red and the pilot still does not stary on change the thermo couple. They are available in any home improvment store.
Nov 04, 2014 | RTO Suburban Rv Water Heater Dsi Gas Valve...
Heater stopped firing up to achieve temperature. No gas release
when firing see if voltage to gas valve brown wire should be 24 volts ac if voltage bad valve if no voltage check safety circuit
Aug 31, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
Baxi Bermuda 5 bbu has just stopped firing up ,pilot light good
The unit is clogged up. Pull it apart and blow it out. If nothing is cracked or damaged it will fire right up
Oct 11, 2012 | Heating & Cooling
Pilot light won't ignite
Wait 30 minutes; press reset button. Repeat if necessary. 4. Pilot light out. 4. Relight pilot. 5. No gas. 5. Make sure gas valve to furnace is fully open. Not enough ... home.howstuffworks.com/how-to-repair-gas-furnaces1.htm
Just checked this site. I am sure you will find it useful - Good luck
Feb 07, 2012 | Heating & Cooling
Why does the pilot light keep going out?
Make sure your pilot flame is hitting the thermocoupler. If not then use air to clean pilot port and try again.
May 05, 2010 | Water Heaters
My oven want light its gas and the the pilot light islit
Is this a standard gas cook-top there maybe some small particle blocking the area where the gas comes out and lighting with the pilot. If you feel comfortable try lighting it with a match. First make sure there is not a lot of gas build open, so if there is a window near the stove open that and make you have plenty of ventilation before striking said match.
Mar 13, 2010 | Kenmore 30 in. 32384 / 32385 / 32389 Gas...
Relatively new wall furnace suddenly stopped working.
if you are by passing stat at the gas valve and it is still not working,i would assume a bad control valve.
Jan 13, 2010 | Heating & Cooling
After a few minutes of burner heating the water, gas shuts off.
A couple of things to check:
If possible, remove the pilot gas assembly and clean the gas jet and thermocouple - they can get carboned up and stop working properly. Make sure the pilot flame and deflector is aimed properly and making the thermocouple glow red hot. If the problem persists, you may want to replace the thermocouple and also check the propane regulator.
Apr 20, 2009 | RTO Atwood Water Heater - 6 Gal LP
Sunglo Black Portable Liquid Propane Gas Patio Heater Logo
100 people viewed this question
Top Sunglo Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Sunglo Pool and Spa Expert? Answer questions, earn points and help others
