My printer is canon IP 1900 Series. my canon problem is error messege display ''the following ink may run out.balck.. the function for detecting the remaining ink level will be disabled since the ink level cannot be correctly detected..'' help me please.
    Sergeant:
  • 217 Answers
It would appear that the black ink cartridge is either out of ink or running out soon.Change the cartridge.If your need to print now and don't have a new cartridge try this open the unit pull out the black cartridge shake it and the reinstall it you may get a little more out of it.If this is a new printer the cartridges install are always limited in use,so you'll buy more.If you must print know try changing your font color to dark blue avoiding black.Good luck.
Posted on Sep 05, 2009
Pixma 2200 series all in one
Don't use refill kits, they are no good in quality printers. Also the cartridges in the newer models have a chip in them that knows when the cartridge is empty. When it becomes empty, the chip has to be reset, and this is what those mall cartridge fillers do.
E, 1, 3 The ink may have run out. The function for detecting the remaining ink level will be disabled since the ink level cannot be correctly detected. If you want to continue printing without this function, press the machine's Stop (Reset) button for at least 5 seconds. Canon recommends to use new genuine Canon cartridges in order to obtain optimum qualities. Please be advised that Canon shall not be liable for any malfunction or trouble caused by continuation of printing under the ink out condition. Checking the Ink Status Checking the Ink Status with the Ink Lamps on the Operation Panel The ink level detector is mounted on the machine to detect the remaining ink level. The machine considers as ink is full when a new FINE cartridge is installed, and then starts to detect a remaining ink level. If you install a used FINE cartridge, the indicated ink level of it may not be correct. In such case, refer to the ink level information only as a guide. When remaining ink cautions or errors occur, the error code will be displayed on the LED (Light Emitting Diode) to inform you of the error. Check the error code and take appropriate action. -> [ An Error Code Is Displayed on the LED ] See[Checking the Ink Status ]
Oct 27, 2015 | Canon PIXMA Office Equipment & Supplies
Tip
Canon Pixma MX320 - How To Disable Ink Cartridge Error Detection..
How to fix the printing problem when Canon PIXMA MX320 series detected the errors in your cartridge?
I have a canon Pixma328 and have been refilling ink for black and color cartridges for quite sometime now. The cartridges are close but after I drilled a small hole on the top part of the cartridge using a small screw, there I find a way to refill the ink that I bought from an ink refill store. The procedure needs extra care, not to touch the contact point (copper) because its sensitive and not to damage the inner part of the cartridge when I insert the needles of the syringe used for transferring ink.
After refilling the cartridge, the next thing to do is to reset the cartridge. This will clear your printer from displaying common printer errors like U053, U051 and U052. The importance of the "reset the cartridge" procedure is to avoid the printer from detecting your cartridge as reused one. The steps below is recommended to do after refilling an ink cartridge.
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
What happened when ink ran out from a refilled cartridge and the printer detected it?
The printer will display an error U162 or U163. All functions of the all-in-one printer will stop and your printer will not work. The next thing you will know is you are in the front of a computer shop and buy a genuine canon cartridge.
But wait, there is still a way to fix this. Reset it again using a different procedure. Reset the detections of reusable cartridge.
1. Turn off your printer an turn it on again
2. After the printer initialize try to copy or print. The error will appear.
3. When the error is displayed on the display panel of the printer, Press and Hold the STOP/RESET button and wait until it self restart.
4. Release the STOP/RESET button the the printer is restarting.
5. Wait for a few seconds and the pending print jobs will commence.
You can print as long as you want, refill the ink as long as you want and save a lot of money from buying a genuine canon cartridge by just following this simple tips for Canon Pixma MX320 and/or Canon Pixma MX328 all-in-one printer
For those who have replaced their ink cartridge before try to use that again and do follow this tip to make that work again.
on Jun 29, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Tip
How To Use Refilled Cartridge When Canon Pixma328 Detected Cartridge Errors!
How to use refilled cartridge when Canon PIXMA MX320 series detected already errors in your cartridge?
on Jun 27, 2010 | Office Equipment & Supplies
Replaced new color ink and getting a u162 error code on my cannon pixma mx340 wireless office all in one inkjet printer
he ink may have run out. Replacing the ink tank is recommended.U162
The Ink may have run out.
If you want to continue printing without this function, press the Stop/Reset button for at least 5 seconds.
NOTE
If the function for detecting the remaining ink level is disabled, the ink cartridge
in grey is displayed in the remaining ink volume screen on the LCD.
Feb 04, 2015 | Cannon Office Equipment & Supplies
Error e16 - cannot print even in black or white
Hi Follow the below steps .
E16 -E19 Failed to scan head alignment sheet
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
Jan 16, 2010 | Canon PIXMA MP160 All-In-One InkJet...
My cannon printer pixma ip1800 cannot detect ink pls help me...
If after you install the cartridge you get a yellow light and error message:
“The following may have run out of color. The function for
continue printing with out this function, press the printer’s
start button. Canon recommends using new genuine Canon
cartridges in order to obtain optimum quality.”
Do not click “cancel printing”. Press printer start button
to start printing. This action will bypass the ink level
detection from the recycled cartridge. It will not damage the
printer! With a recycled cartridge this action needs to be
done one time.
A full recycled cartridge ink level may not display correctly.
It may show empty.
If you want to check the ink level, you can do a “Nozzle
check” by follow the directions below:
Go to menu File select print click on “Property” click
on “Maintenance”
Click on “Nozzle check” to print out the color check.
Click on “Cartridge Alignment” to align the cartridge.
See pictures for above process at Inktelligent ip 1800 topic
Also the refills refered to above are at the IP 1800 inkfilling page
Sep 23, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Cannon IP1880 Cannot detect Cartridge
press the resume button 5seconds(this disable ink cartridge monitor..
Mar 20, 2008 | Canon I990 InkJet Photo Printer
Error messages: U150 + Ink tank errors have occured
ON THE CHIPS, TRY CLEANING THEM WITH ALCOHOL (70%)
SOME BRANDS YOU CAN SHAKE THE CARTRDGES TO RESET THE INK COUNTER
Feb 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
460 people viewed this question
k24674
jasbo
jasbo
