Question about Humax Televison & Video
I have a Humax 9200T 160GB. It freezes after being powered up for 1-2 minutes. I removed the Antenna cable and SCART to TV and it powered successfully for hours. Connecting it back together it freezes again. I removed the Antenna cables and it continues to function for hours which enable me to watch the recorded programmes. Why is the antenna feed freezing the unit and can it be fixed?
Removed the aerial cable which enable the unit to operate.
In installation menu selected "Default settings". Once this had completed, I powered down the unit, I added the aerial cable and powered on the unit. Unit then searches for channels and stores them "save" tab. Issue resoved.
Posted on Sep 06, 2009
Testimonial: "I posted my own solution to the problem which was successful "
  • 4 Answers
Something I read somewhere - delete any 800+ channels. These are duplicate channels received from a different transmitter. You can delete these in the SETUP - but might be better to re-scan in the hope that the 800 channles don't reappear.
Also HUMAX know about problems related to MUX changes for the digital switchover and are working on software updates.
Posted on Jan 05, 2010
I only have one scart outlet on my tv my ariel is in the wall and mthen into my tv but its just picking up tv programmes on my humax recorder and not through my tv
The aerial should first go to the Humax, then from the Humax to the TV. Make sure power-saving is turned off on the Humax, otherwise it will not pass the aerial signal to the TV when the Humax is in standby.
If ypou want to use Humax power-saving, the aerial must be split so that one feed goes to the Humax and another to the TV.
May 19, 2016 | Humax Televison & Video
Need Simple User Guide for Humax 9200T
If you Google 'Humax' you can get a manual on line, but they are all the same. What is it that you want to do? I have the 9200T, so if you email me at Paul.Brooksbank@londonmidland.com I will try to help you.
Jan 09, 2012 | Televison & Video
Can you please tell me how to connect my Humax 9200T PVR to my Onkyo TX-SR608. The Humax does NOT have HDMI connections and the manual does not mention the connection of a PVR. The Humax Manual is of no...
You will need to purchase a scart to HDMI converter - available in the UK for about £40.
If you Google 'Scart to HDMI converter' you should find several options, which will be cheaper if you are in the US!
Unfortunately the Humax box you have only supports Scart A/V I/O, which is of course now obsolete.
Jan 17, 2011 | Onkyo TX-SR608 Receiver
How to connect an LG26LE3300 TV to a Humax PVR-9200T and to an Inventive DVD video player? These worked fine with my old TV using scart cables but not with the LG.
You will see the colored jacks on tv. There should be a print by them that says out. Match the colors from the jacks on the tv to the same colored ones on the Humax. The ones on the Humax should say input or a/v or dvd, or phono. From the dvd player, match the colors from here to the tv. The tv should have another set of 3 colored rca jacks that say imput on them.
From DVD Player out to tv in From tv out to Humax in/av/dvd/ ect.
Yellow is video Red is Audio Right Channel White is Audio Left Channel
Jan 14, 2011 | LG Televison & Video
My Humax Duovisio PVR-9200T often freezes completely and has to be switched off at mains for a few seconds. Or commands from remote (eg subtitles, menu, channel change) take minutes to respond. Or...
Remove the Aerial.
Switch on or if it's frozen switch off at the mains and on again.
Press Menu
Installation and enter password - 0000
Select 'Default Setting' and OK
Select 'YES' and OK to restore all settings to factory default.
Confirm again to start loading, enter the password again and it will start scanning for channels but won't find any.
Replace the aerial and press OK to rescan and now it will find channels. On completion press SAVE then EXIT on your keypad.
You won't lose any saved programmes but you will have to re-schedule your recordings.
May 03, 2010 | Humax DRT400 DVD Recorder w/ 40 hr Tivo
Humax PVR 9200T nolonger responding to controls on machine or remote.
1. Power off at the rear
2. Disconnect Aerial
3. Switch ON
4. If the unit can then be switched on carry out a Default setting
5. When the unit restarts insert the aerial cable so there is signal when the auto search appears.
Also, believe it or not, check your batteries in the remote control (seriously).
Apr 27, 2010 | Televison & Video
PVR freezes and nowt will work
I'm in the US and am not completely familiar with the digital conversion in your area, but the following information may be helpful to you.
Humax released a software update earlier this year which adds the full range of ‘Group 2' Freeview Playback. For details see Trusted Reviews
Aug 14, 2009 | Electronics - Others
Humax PVR 9200T freezing picture and will not turn off.
Unplug the aerial; switch the PVR On; if you have control via the remote do a reset to default settings thus:
1. press Menu on the remote
2. select Installation and enter default password of 0000 unless you have changed it
3. select Default settings and okay on YES
4. then turn if off again via the remote
5. plug the aerial back in and it will scan for channels, save them of course.
I got help on this from other forums but saw your request for help. This worked for me.
Oct 25, 2008 | Televison & Video
Humax pvr 9200T
Hello Fixya Team,
I did solve the problem with the EPG not updating quick enough when you power on.
If once you power on you switch channels to BBC1 youwill find the EPG updates quite quickly.
Hope this helps out.
Lomp.
May 31, 2008 | Humax Televison & Video
Televison & Video Logo
776 people viewed this question
Top Humax Televison & Video Experts
Andy Fraser
Andy Fraser
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
