Question about Hozelock Garden
My Hozelock Cascade 3000 has recently operated only for a few minutes. After switching off, it can be restarted again after about 5 minutes, but then soon stops again. It has given excellent service for some years. I have taken it out of the pond for checking but the operation is still the same.
I have bought a replacement pump
Posted on Sep 09, 2009
My pmp 3000 will switch on and run ok for a minute or so then cut off it will restart ed of and on again but repeats the PROCESS THERE IS NO BURNING AND I CAN SEE NO DRY JOINTS
IS yours a AUDIO MIXER?? If so start here:
20 Most Recent Behringer Pmp3000 16 Channel Audio Mixer Questions Answers
THEN TRY HERE:
Questions Answers for behringer pmp3000 problems
This Link is NOT for your MODEL, BUT it has good troubleshooting hints (for Behringer)! I hope it helps you.
Behringer Mixer Issues
Dec 20, 2017 | Dryers
I drive a 2004 Golf 5, GT import. The engine had been recently worked on, and after doing some 1500km, the EPC light came on, and lost power. I switched off the engine and restarted again after a few...
First of all you need to access the Engine Control Module (ECM) using suitable diagnostic equipment connected to the data link connector of the car, in order to pull out all DTC's memored. DTC = Diagnostic Trouble Code. Then you will bu full informed about the root cause of the problem, and you will be able to repair & replace bad pieces and reset the ECM. Then the EPC (Electronic Pedal Control) yellow light will turn OFF.
Jul 11, 2011 | 2006 Volkswagen Golf
My cascade pump 1500 is clogged and do not have instructions to take it apart
Hi Cheryl,
Before you take it apart try this.
With the pump off, attach the outlet to a garden hose and run water backwards through it. If it's being stubborn flip it on for a sec. every once in a while.
The process has worked well for me.
Best regards,
Aug 21, 2010 | Garden
No Sound Dell Dimension 3000
1)Check whether sound is enabled in bios.
2)Install Latest drivers from support.dell.com
3) Boot From the ResourceCD to Run Dell Diagnostics
1. Insert the ResourceCD in the optical drive, and restart the computer.
2. Tap the <F12> key during startup until the One Time Boot menu appears.
Note: If the One Time Boot menu does not appear, restart the computer and try again.
3. Press the <Down Arrow> to highlight Boot from CD, and press <Enter>.
4. In the ResourceCD menu, select Run the 32 Bit Dell Diagnostics, and press <Enter>.
5. The Dell Diagnostics screen appears.
Run sound test
Jan 10, 2010 | Dell Dimension 3000 PC Desktop
How to set up a Hozelock cascade 1500 pond pump
if there are no markings, check each opening for a vacuum with a small piece of paper, the one sucking in is the inlet, the other is the outlet
Jul 25, 2009 | Cascade 1400 Gph Pump
1992 LEXUS LS400 STALLS WHEN HOT & IDLE SURGING
Sounds like a fuel problem or a clogged catalytic converter. Check your filters for the fuel system. Make sure you can hear the fuel pump kick on. If that doesn't work you need to separate the header from the catalytic converter. Then try to stall it again. Hope this helps.
Jun 12, 2009 | IBM ThinkPad T30 2366 Notebook
Vapor lock?
keep the fuel tank at least half full.....it may helps cool the pump
Jun 19, 2008 | 1991 Volvo 240
Phone regularly cutting out
This is due to malfunction of battery,
i have also experienced same kind of problem with nokia set which is other model. i have also done same what you have done. Change or replace your mobile battery. so it 'll finally solves your problem.
Apr 21, 2008 | Nokia 2310 Cellular Phone
Garden Logo
564 people viewed this question
Top Hozelock Garden Experts
J Walsh
Level 1 Expert
Bill Boyd
Vernon Taylor
Are you a Hozelock Garden Expert? Answer questions, earn points and help others
