Question about Lexmark X5470 All-In-One InkJet Printer
My printer will print all colors except black why is that
  • 430 Answers
The problem you are all having is with the print head (The black tray that your ink cartridges sit in).
Most of the time a simple cleaning of this will correct the problem, if it does not then you will have to call support and they will send you out another print head.
But lets try and see if we can get your troubled one to work again by following these steps...
1 - turn printer on and open the lid as if you were going to change the printer ink cartridges.
2- when the ink tray moves into the center and stops, remove both the black and color cartrdiges from the print head.
3- To remove the print head simply place your left thumb inside the head all the way to the left facing up and pinch the upper left lip of the print head to release it, then pull the entire tray out with your other hand ( there is a release inside the tray above the sticker of a finger and bullseye to the far left in the upper left corner inside the tray)
4- With the tray now removed be sure to look at the bottom and you most likely will find a build-up of black ink... clean this off using DRY paper towel as much as you can.
I used rubbing alcohol but if you do this make SURE it is completely dry before reinstalling.
5- Once you have cleaned the print head reinstall it in reverse fashion than you removed it, if you installed it right you will hear a solid CLICK noise.
6- replace the ink cartridges you removed if they still have ink in them and then close the printer lid.
7- You may get a notice that there is a new printer head and or cartridges and it will want to align and or calibrate the printer...be sure to do this!
8- Once the printer is recalibrated hit the menu tab on the printer and choose " clean ink head"... Do a deep cleaning 2 times!
9- Now try to print something that contains something black like a text document. If it works you are all set, if it did not then you will need a new print head . simply explain that you did the above steps and it did not work so that you can avoid support trying to run you through all this. They will send you a new one in 2 days.
Hope this helps and good luck!
Posted on Sep 05, 2009
My mp610 Canon printer will no longer print email documents (black)- leaves page blank, except for email address (in blue print)., But printer will still print satisfactory color pictures (Photos). B
Get the latest driver from Canon's web site. Then uninstall the printer. Remove the driver from your computer. Use regedit to remove any traces of your printer from your registry. Install the new driver. That should do it.
Jan 10, 2015 | Canon MP610 Photo All-In-One Printer
Will the Epson stylus office bx635fwd print if only the black has ink in it ?
Since 2005 Epson and all other inkjet manufacturers use a little of the colors to print black. so ,no,you will not be able to print just clack.
Even color laser printers use the colors to print black.The exceptions since 2009 have been the Canon color lasers and the HP color lasers units they provide print engine for.
Mar 29, 2014 | Epson Stylus NX400 InkJet Printer
Kodak esp 5210 wont print black
I figured it out. If you are low on (25%) on either colors or black, then it won't print. Even if you load a new black cartridge and it reads as 100% black, it won't print because it will only print when BOTH cartridges have been replaced and reads 100%.
Same thing happens reversed with color being replaced.
So basically, ALL printers short you 25% ink and FORCE you to buy their ink more often. Kodak is no exception.
I have 100% black and 25% color and a BW only needed text paper won't print. I been through this before. *facepalm*
Apr 16, 2012 | Kodak ESP 7250 All-in-One InkJet Printer
My HP Officejet 7410 All-in-One Inkjet Printer is doing the following: 1) It prints in color even when the document is black and white (using up the color ink) 2) It prints much more slowly than it did...
go into your driver and change your color preferences to black and white. that way when you want to print color you actually have to tell it to do so. which will save your color ink, and will print much faster. full color printing of a black and white document uses all ink colors except black to make what is called process black.
Dec 18, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Ran out of color ink on cnnon mx310 ... want to
If when you attempt to print only with the black cartridge installed but it won't print, then this specific printer requires that color ink also be installed. Typical with most inkjets.
Jul 07, 2009 | Canon MX310 Office All-In-One Printer
Replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
MP730 prints all colors EXCEPT Black
I had the same problem. After replacing the Cyan and Black the Black would not print. I deep cleaned the cartridges about 8 times, interchanging cleaning and printing test pages. Eventually the cartridges began working properly again. I know this is not much help, but it has worked for me.
Mar 01, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Canon i560s prints all colors except black
I had a similar problem and found out that you have to specify printing on plain paper. If you choose paper other than plain paper, it will make the black from other colors. Check also that all of your cartridges are seated properly. My magenta was not pushed all the way down so I got green instead of black ink when it mixed the colors to make black.
Jan 31, 2008 | Canon BubbleJet i560 InkJet Printer
Wont print
some printers share the ink from color to black but you can select if you wants to use only black just go to printer than properies than select to use only black but you probably have to remove the empty color one
Dec 18, 2007 | HP DeskJet 3940 InkJet Photo Printer
Lexmark X5470 All-In-One InkJet Printer Logo
46 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
