Question about Toshiba 62HMX84 62" Rear Projection HDTV
Need to install a replacemen lamp in a Toshiba 62" HD DLP Projection TX. How is it installed?
    Problem Solver:
  • 12 Answers
After replacing the lamp per the instructions:
  • You should first check to make you sure you have the TV plugged into the wall outlet. Make sure that you have the lamp door put back on securely. Next, you should unplug the TV and leave it unplugged for 1 minute. After 1 minute, plug the TV back in. Following the previous procedure resets the control system of the TV. If your TV still does not turn on, continue to the next step.
  • First, make sure the lamp is properly installed in the housing and it is fit and screwed in the TV completely. If the TV is still doing this, the problem is usually one of two things.
  • It could be the lamp or the ballast. The indicator lights on the TV may be flashing a code that means the lamp is defective, but the TV is flashing that code only because the lamp did not strike. The TV has no way of knowing if the lamp is good or bad. If you have replaced the lamp and it is still doing it, you should contact who you bought the lamp from for a warranty claim.
  • If you eliminate the lamp as the problem then it usually is the ballast. The buzzing sound is the ballast trying to start the lamp. The ballast may not be producing enough voltage to start the lamp. A ballast is a part you will likely not want to replace yourself, we recommend that you contact a trained/certified TV technician for servicing.
Posted on Sep 10, 2009
  • Max Quattromani Sep 10, 2009
    Clarification:
    This video shows how to replace the DLP lamp, this specific video is for Samsung, but the process is the same in your Toshiba
    President:
  • 3,130 Answers
What is the model number??, There are just way too may Toshiba sets to try and guess the one you have!! or try here. http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/TVom.asp
Good Luck
TECHMAN.
Posted on Sep 05, 2009
I replaced the lamp on my toshiba 42HM66 and that worked for about 2 weeks. I ordered a new lamp and replaced it. Now the lamp light blinks amber and then the power light blinks green at about 30 second...
You will need to check if the output supply going to the lamp is good. If not the ballast will need replacement. That model is actually famous for haveing ballast issues. You can get the replacement ballast from www.tvcircuitboards.com they also assist with installation assistance if you require it.
Nov 07, 2012 | Toshiba 62HM95 62" DLP HDTV
The buzzing sound on back burn 2 d95 lamps and red and gren light on the front
If you have not done so:
Inspect Lamp
inspect color wheel
inspect Ballast that powers lamp
May 13, 2012 | Toshiba 62HM95 62" DLP HDTV
I have a 62" DLP
Replace the lamp, model # is TB25-LMP. Good luck
Jul 24, 2011 | Toshiba 62HMX84 62" Rear Projection HDTV
I have the toshiba 62"
The tv projection Lamp shutdown 3-4 mins,than u hear alot of clicking noises sound too?Yes,than the board that call the Ballast board it is dead too.The Ballast board only job are to help to ignite the projection Lamp only.
Jun 07, 2011 | Toshiba 62HM95 62" DLP HDTV
My 62 inch Toshiba DLP keeps getting the timer rec error. I even bought a brand new bulb for it, what can it be?
have you reset the lamp timer I think that is all you need to do
here is the link
http://www.ehow.co.uk/how_7259862_reset-toshiba-dlp-lamp-meters.html
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE!!!
Oct 18, 2010 | Toshiba 62HM95 62" DLP HDTV
Hi: My Toshiba starting showing the symptoms (as it has in the past) that it needed a new bulb. The red light comes on, is steady, but then the green light comes on and flickers. I have now put in 2 new...
I think that you have a problem with your ballast board this is the power source to the lamp if for any reason it starts to wear out or weak it will not be able to turn on your lamp check this link out it is about Toshiba lawsuit
http://www.avrev.com/home-theater-rear-projection-hdtvs/dlp-rear-projection-hdtvs/toshiba-ordered-to-pay-out-in-dlp-lamp-lawsuit.html
Sep 21, 2010 | Toshiba 62HM95 62" DLP HDTV
Humming Noise at the back of my Toshiba 62 dlp lamp is working but no picture
You probably should have the TV looked at by a technician. if your lamp is lighting up then most likely the noise is the color wheel itself.
Nov 17, 2009 | Toshiba 62HMX95 62" HDTV
Picture loss after picture begins to flash. blue and yellow light
Most likely the lamp is dying. Try replacing the lamp before calling a repair tech. What does the Owners manual say about the blink lights?
Oct 01, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Toshiba 62; DLP 720P- Alot more red and green
You have probably have installed the wrong lamp or you installed a third party/off brand Lamp. If that is the case anything other than a Factory replacement Lamp will have a different color temprature. Install a Lamp that is listed from the manufacture.
Jul 14, 2009 | Samsung DLP HL-P5663W 56" TV
Toshiba 62HMX84 62" Rear Projection HDTV Logo
224 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
