Question about ASUS A7N8X-E Deluxe NForce 2 Ultra 400 Motherboard (90M7A770GOUAYOZ)
PC is dead after clear the BIOS
I've just cleared the CMOS as it's described in the manual, and now the PC is dead. When I power it up the lights on the keyboard are flashing once and that is all. No beeps or anything else. I'm using an external videocard, so I removed it. The memory also - no a beep at all. Pressing the NumLock key doesnt lit the light. The mouse is powered up. Can anyone help me somehow?
  • iliyan_mat Sep 05, 2009
    Finaly, after one hour without batery and jumper set to clear CMOS, I was able to start it. The funiest thing is that this MB is "talking" instead of beeping. Thanks to the guys from another forum I put a headset in! Now it's time to perform some hardware tests - memory first, then the rest.
    Thanks for your advices, eventhough I already tried all of them before my post.
  • 3,153 Answers
Put the memory back in the computer first. (only one stick if you have more than one)
You are going to have to start with basic troubleshooting first.
TAKE notes as to where cables were etc. (digital camera would be useful here)
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the on-board)
Disconnect all drives
Power u the computer and make sure you can at least get into the BIOS.
If you hear any beeps these can indicate where the fault is.
Power up the PC and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
If its not the PSU and your fans are working it may suggest a problem with either the motherboard or CPU
Posted on Sep 05, 2009
  • 53 Answers
If you dis assembled your pc, make sure you have assembled it correctly. 1 cause for this is that it is grounded
On my e-machines t3418 motherboard what pin setting should the jumper be for clear cmos
1. Usually there are 3 pins, and you put the jumper on 2 of them to clear CMOS, then return them to the other 2 for normal function.
2. What you're describing seems more like a dead motherboard battery. Replace it and the computer should hold the time and date.
Nov 11, 2011 | E-Machines T3418 PC Desktop
Changed cpu multiplier from 17 to 19 now have blank screen on foxconn a88gmx, cant reset as cannot access bios
Try clearing the CMOS --- the down side is your lose all your setting --- the up side is you should be
able to access your BIOS
Clear CMOS Jumper: CLR_CMOS1 ( Located near CMOS battery )
The motherboard uses CMOS RAM to store the basic hardware information (such as BIOS data,
date, time information, hardware password...etc.). Clear CMOS data is the fast way to go back to
factory default when the BIOS settings were mistakenly modified.
The steps to clear CMOS data are :
1. Turn off the computer, unplug the power cord from the power outlet.
2. Remove jumper cap from pins 2-3, put it onto pins 1-2 to short them.
This will clear CMOS data.
3. Return the setting to its original with pins 2-3 closed.
4. Plug in the power cord to your computer and turn it on.
5. Go to BIOS Setup to configure new system as described in next chapter.
Clear Jumper on pins 1 & 2
1 ----
2 ----
Normal
(Default)
3 ----
CLR_CMOS1
  • Disconnect the power cable before adjusting the jumper settings.
  • Do not clear the CMOS while the system is turned on.
WARNING!
Jumper Diagram Definition Description
1-2 Set Pin 1 and Pin 2 closed
2-3 Set Pin 2 and Pin 3 closed
Feb 10, 2011 | Foxconn A88GMX AM3 AMD 880G HDMI Micro ATX...
I forgot my bios password, i want to reset my bios password
A. By Removing the CMOS Battery:
cmos_battery.jpg Almost all motherboards use a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
If it fails, then try to remove the battery for at least one hour.
B. By Using the Motherboard Jumper:
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
Jan 30, 2011 | Acer Aspire (AST180-US340B) PC Desktop
VGC-RB42G flashig power light and won't power
I have had this problem if power is removed by disconnecting the power cord (in cases where nothing else works). To fix the problem:
1) remove the power cord from the back of the unit
2) disconnect the large power connector from the power supply to the motherboard
3) apply power to the power supply
4) reconnect the motherboard power connector
5) turn the unit on
- dedndave
Apr 13, 2010 | Sony VAIO VGC-RB42G PC Desktop
ACER ASPIRE 4730Z. How do I clear the CMOS (password)?
Below is the steps for clearing the password. Below that is the link for the manual, the picture of the jumper tabs is on pg. 153, good luck
Steps for Clearing BIOS Password Check
If users set BIOS Password (Supervisor Password and/or User Password) for a security reason, BIOS will ask
the password during systems POST or when systems enter to BIOS Setup menu. However, once it is
necessary to bypass the password check, users need to short the HW Gap to clear the password by the
following steps:
• Power Off a system, and remove HDD, AC and Battery from the machine.
• Open the back cover of the machine, and find out the HW Gap on M/B as picture.
• Use an electric conductivity tool to short the two points of the HW Gap.
• Plug in AC, keep the short condition on the HW Gap, and press Power Button to power on the
system till BIOS POST finish. Then remove the tool from the HW Gap.
• Restart system. Press F2 key to enter BIOS Setup menu.
• If there is no Password request, BIOS Password is cleared. Otherwise, please follow the steps and
try again.
NOTE: The steps are only for clearing BIOS Password (Supervisor Password and User Password).
http://tim.id.au/laptops/acer/aspire%204730z%204730zg%204330.pdf
Oct 11, 2009 | Computers & Internet
How to remove cmos/bios password ?
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Aug 23, 2009 | HP (350030-001) for Compaq dc7100...
GA-EP43-UD3L Having problems installing motherboard. Will not boot. Phase Led lights flash on then off. Help
CLR_CMOS (Clearing CMOS Jumper) (next to the battery)
Use this jumper to clear the CMOS values (e.g. date information and BIOS configurations) and
reset the CMOS values to factory defaults. To clear the CMOS values, place a jumper cap on the
two pins to temporarily short the two pins or use a metal object like a screwdriver to touch the two
pins for a few seconds.
• Always turn off your computer and unplug the power cord from the power outlet before
clearing the CMOS values.
• After clearing the CMOS values and before turning on your computer, be sure to remove
the jumper cap from the jumper. Failure to do so may cause damage to the motherboard.
• After system restart, go to BIOS Setup to load factory defaults (select Load Optimized
Defaults) or manually configure the BIOS settings (refer to Chapter 2, "BIOS Setup," for
BIOS configurations).
Jun 20, 2009 | Gigabyte GA-945GZM-S2 Motherboard
Clear bios settings on m963gv motherboard
You have to shut off the power and then move the clear CMOS jumper on the motherboard to the clear position for just a few seconds. Apparently the manual that shipped with m963gv may not have the right information as to the location of the CMOS driver. Try going to PCCHIPS's website and download their manual in PDF form:
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=354&DetailName=Manual&MenuID=7&LanID=2
You'll find the CMOS jumper location on page 11 of the PDF file (or page 6 on the printed format). On Page 15 is the instruction on where to place the jumper (again, when it's printed, it's labeled page 10).
Nov 04, 2008 | PC Chips M963GV (V3.3A) Motherboard
No response from Monitor, Mouse and Keyboard
Definitely a "faulty" motherboard. If fans on PC do not turn, no lights come on and dead screen.
If lights come on, and fans turn, try to reset the BIOS by removing your CMOS (and setting the jumper to clear for about 5 minutes, then put the jumper to normal again) battery for 5 minutes.
Sometimes the bios just "stuffs" up and you'll get no response from your pc at all. So all you do is "CLEAR THE CMOS/BIOS"
Apr 16, 2008 | Dell Dimension 3000 PC Desktop
ASUS A7N8X-E Deluxe NForce 2 Ultra 400 Motherboard (90M7A770GOUAYOZ) Logo
106 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
