Question about Mitsubishi WT-46807 46" Rear Projection Television
The picture would not come on now when we try we get multiple colors in a pattern of curved lines that pulsate.
  • lsrart247 Sep 07, 2009
    Here is the correct model number (WS65857) Let me know if your previous recommendations are applicable before I start taking the tv apart or your suggestions are different for this model.
    Thanks,
    Dan
    The model number is ws65857 and only has at the most 5000 viewing hours. After hitting the power on button the relay clicks the normallength of time but there is no picture displayed then after a couple of minutes there is pulsating curved multi colored lines
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
1.)It sounds like a convergence problem.
2.) This site currently has a problem--I can only answer a question 1 time and currently not able to reply further--been going on here for a day or two--you can also get me at: etower.766@netzero.net
3.) If picture looks 3d you have a convergence problem--Let me know via email or here exact model number and brand and I will tell you what needs to be done. I have repaired hundreds of sets with this kind of trouble.
4.) Do not rate this post here until we are sure what your problem is.
5.) IF the set should shut down and it is Mitsubishi engage the self check feature--hold both the MENU AND INPUT BUTTONS ON THE FRONT OF THE SET IN FOR 5 SECONDS AND RELEASE BOTH OF THEM.
6.) Power light should blink a two digit code---for example--2 blinks, a pause and 2 blinks---it will repeat it about 10 times.
7.) IF set comes on and red or blue out of place with the original remote go into the customer menu and try to adjust----if either red or blue will not adjust in some direction--you found your trouble---a bad convergence ic--most models use two and they both need to be replaced.
Contact me with more information or any questions you have.
Regards, SD TECH
Posted on Sep 08, 2009
  • SD Tech
    SD Tech Sep 08, 2009
    Yes, self check should be the same for this model---first made in 2000. It is a V17 chassis. let me know what you find.
  • 585 Answers
If the colors are wavy and will not move using the remote convergence menu your convergence ICs are most likely bad.
You can only adjust the red and blue in the customer menu,
If the ICs are bad (probably are) after you solder new ones in you may not need to do any adjustments , so leave the adjustments alone if . If you would prefer a repairman fix the set the ICs can be replaced for between $300 and $400
this model HD PTV has two convergence ICs on the large deflection module. taking it apart will require philipsand 1/4" bits and involves unplugging cables that should are marked with two letters each for easy reinstallation
I will not go into detail about how to take the circuit board out, but know this there are alot of screws holding it down after removing the back disconnecting and all connectors. The ICs are clipped to a large heatsink and when replacing make sure there is some heatsink compound on the metal to metal surfaces. also look carefully at the resistors near the ICs, replace any that look burnt (discolored) and do not measure the same ohmage as is written on them. The two ICs are part # STK392-570 and the sell online for around $30-$45 each
after replacing the ICs adjustment needed can be done in the customer menu , muti color adj, save the adjustment by pressing menu when done
hope this helps
Eric
Posted on Sep 05, 2009
I have a 8 year old 57in Sony projection HDTV,when the picture is dark you can see faint blue lines in a curved arch like pattern across the screen.Any ideas? Thanks
The tv problems is call a convergence picture problems,it is just starting to developing.This problems when it is fully developing into a convergence picture problems to the tv eventually.Tv will develope into a colors lines R,G,B mis alignments,have a colors shadow pictures or into a picture 3D look alike.Eventually the tv convergence board will dies,have to have it parts replaced like 2 STK convergence ICS and some or all of it resistors too.This problems the tvs shops will cost u like $300-350 for parts and lobors.
Aug 13, 2011 | Sony KP-57WS500 57" Rear Projection...
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
Words have shadows and yellow is also blue ex football game yardage lines are yellow and then there is a blue line words are not sharp
Not familiar with this particular model but it should have a convergence menu. If so, try using the convergence menu (which is basically a cross pattern (possibly multiple ones) that you use as a reference to align your colors and make the cross pattern white. When you go to this menu and see the cross patterns, if you see the shadowing of the colors, you will know what I'm talking about. If this adjustment(s) don't work, you may have a problem in your convergence board circuitry. Wish I could be of more help but try the menu.....I've fixed 2 or 3 sets like this now. Good luck!
Jan 25, 2010 | Pioneer PRO-520HD 53" Rear Projection...
MP830 Canon - NOZZLE CHECK does not print light cyan line
You will need a new printhead, QY6-0061-000, runs around $60.00 well worth it for your machine.
Sep 08, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Sony KP-46WT500 Red, green and blue lines appearing on screen
your convergence IC;s are out, they cost about $40, if you know how to solder, you can do it your self, if not , I would try to find somone that can, service centers charge about 4 or 5 hundred, after you get the new ones, there easy to find on the board in the back of the tv
Nov 26, 2008 | Sony KP-46WT500 46" Rear Projection...
Faint red lines in a curved arch like pattern
Is there a cheaper solution? $600 sounds like you just throw it away to me...
Aug 02, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Distorted picture on RCA LCD TV
your set has convergence problems i dont have the answer yet ,i do know that convergence broad is not what is causing this! I have one in my shop now with same problem as soon as i find out problem i will post it !!!!!
Jan 09, 2008 | RCA HD52W59 HDTV Projection Television
Lines
are the lines multiple colors? ie; reg, green, blue? If so you need convergence repair, not really something a lay person can do.
Nov 29, 2007 | RCA P52939 52" Rear Projection Television
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Picture Pulsating
I have the same set. I solved this by turning off the dynamic contrast or adjusting the contrast and brightness settings down.
Dec 30, 2006 | Philips 60PP9202 60" Rear Projection...
Mitsubishi WT-46807 46" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
