Question about Kodak EasyShare V1073 Digital Camera
I have the same problem
When i zoom in 3/4 way outit stops and shuts off
    President:
  • 2,761 Answers
It could be something more serious, or as simple as inserting fresh/fully charged batteries, but this problem is frequently due to corroded battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, clean the contacts at both ends of the batteries, and reinsert them in the camera. This cleaning cures the problem about 90% of the time, and I hope it works for you.
Posted on Sep 06, 2009
Camcorder zooms by itself.
this is some problem with the panel of buttons is your unit.
this will need some service from the company directly.
Jul 24, 2008 | Sony Handycam DCR-TRV330 Digital Camcorder
When I letmy clutch outit makes a strange noise when i pull it In it stops? Why? O3 625 sxc
You could have worn down all the friction material on the clutch and what you are hearing is the rivets on the clutch rubbing on the flywheel in the absence of sufficient friction material.
Oct 02, 2013 | KTM Motorcycles
Re: Kenmore Plasmaire air conditioner; suddenly stopped working during night. Motor will initially turn on but no air coming through, then will stop
Most likely you have a bad fan,did you have a storm or lighting strike or power drop / outage .
These type of things can cause trouble with a weak electrical part - not know the age of the Unit - you claim it happen in the middle of the night - if the fan Humms and cut outit could be a cap. that helps you fan start - but the fan is damaged if it tryed to start time and time again . Call service if the unit is worth it .
Jul 17, 2009 | Heating & Cooling
Sony DSC-P3 Zoom stopped working
i had that same problem. check your image size, the camera cant zoom if the image size is set to 3.1M or 2.8M(3:2)
how to change image size:
turn on camera and leave it in camera mode (picture taking mode)
press the delete/image button
change image size until camera zooms again
VGA gives the biggest zoom range
i hope this helps
it worked on my camera
Jul 27, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
Need to set the date and can't find manual--
Try this:
1. With power off, press the MODE button to select the DATE mode.
2. Press the zoom out (three trees) button for more than two seconds to enter the date/time set mode.
3. Press the zoom out (three trees) button to select year, month, day, hour, or minute (selected number will flash).
4. Use the zoom in (one tree) button to advance the number.
5. Repeat steps 3. and 4. to set each value.
6. Press the zoom out (three trees) button until the colon (in the hours:minutes) is flashing. When the colon stops flashing, date and time setting is completed.
7. Press the MODE button and the power will switch off.
Dec 22, 2007 | Canon Sure Shot 115u II Date 35mm Film...
OlympusD535 zoom
It sounds like a silly question but are you putting the batteries in the right way round. I can't think of anything else which would stop them fitting. BMW
May 11, 2006 | Olympus D-535 Zoom / C370 Zoom Digital...
Kodak EasyShare V1073 Digital Camera Logo
61 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
