Question about Maytag Heating & Cooling
Maytag home ac, 2 units, 2nd floor is 2500 btu and seems to freeze up at times. But, now weatehr is cool, and no power. I chewcked fuses. Went into attic saw a red light on..which I know means something, but no power. You cannot just turn the fan on.
  • 20 Answers
Sounds to me like it's either overcharged, or you have airflow issues. Either way, the compressor could be burned up (shorted to ground) now that it is not working at all. Get a good, competent service tech out there to check it out. If it is a blown compressor, make sure that he flushes out the system with a product called Nu-Calgon RX11 Flush and that he changes the filter driers. If it isn;t blown, a good tech will know what to do. This is a serious thing, so please do not try and fix it yourself.
Posted on Sep 10, 2009
I have a Maytag window unit and i am trying to find out how many btu is has. right now it is in a small room and i want to know if it will work in a bigger size room. MODEL M6Q1OF2A SERIAL CR 264327...
that is a 10000 btu unit and a good rule of thumb to go by when 'sizing' a unit is 12000 btu for every 600 sq ft of cooling space (if the place is well insulated) or 400 sq ft (if not well insulated).
So, you have a 10000 btu unit which is 5/6th of 12000 btu - so - can reasonably expect that unit to cool approximately 500 sq feet.
In other words the room it's in now could be only - say - 300 sq feet (and well insulated) - in which case the AC unit is cooling it - well.
However, if you try to cool a 800 sq ft room - it will not work as well.
Hope this has helped.
Aug 05, 2011 | Maytag M6Q10F2A Air Conditioner
I have a Goodman AC unit that isn't working. I believe its the fuse. My power went out and the ac unit stopped working. the first time the repair guy said it was the fuse. I don't want to spend...
Generally, the fuses are located in a box outside by the outdoor unit. The box has a door on it and you will probably have to pull a cartridge out and the fuses will be behind the cartridge. If you don't have an ohm meter to check the fuses , just go to home depot, lowes or another hardware store where they can check them for you. Be sure to check the circuit breakers too.
Jul 11, 2011 | Goodman CKL36AR36 Air Conditioner
My landlord installed this brand new out of the box. Our apt is 900 sq ft tops. This unit can't even cool down our living room and kitchen. If the whole 2 bedroom apt is 900 sq ft, you can imagine how...
The AC your landlord installed is rated at 8000 btu which is way too small for 900 sq ft. You need at least a 15000 Btu Air conditioner and a 'well insulated' house to be cool.
A good rule of thumb in the AC business says you need 1 ton (12000 btu) of Air conditioning for every 600 sq feet (if the house is well insulated) - if not - then you will need 1 ton (12000 btu) for every 400 sq feet.
So, if you have 900 sq feet and the house is well insulated you should have at least a 15000 btu unit.
If it's not well insulated you will need 24,000 btu.
Jun 07, 2011 | Maytag M6X08F2D Air Conditioner
AC was cooling fine. Now, won't cool room even though cool air comes out. Exhaust hose is extremely hot.
Check filter, if you have a 5000BTU unit (small) and it is extremely hot, then it wont work great for a big room. BTU is the rate of what the AC will put out. 5000 BTU is good for a small single room. 10,000 will cool a bigger room and 18,000 btu is meant to cool a home.
Jul 07, 2010 | Whirlpool ACP102PS Portable Air...
Can I mix brands/tons when installing AC unit to existing coils?
First off - the 'rule of thumb' is 600' per ton of Air Conditioning. In other words your old unit is a 2 ton unit. So - 2 tons x 600' = 1200'. As you can see if you install the 2.5 ton unit - you will be installing a AC that 'could' cool a 1500 sq ft house (2.5 x 600' =1500 sq ft.). Slightly more than what you need; and the 3.5 ton unit is 'way to big,' (3.5 x 600' = 2100 sq ft.).
Note: fyi - many in the AC business will sometimes refer to tonnage in btu's, i.e. 1 ton = 12000 btu - hence a '2 ton unit' can also be referred to as a 24000 btu unit and vice versa.
So... from the above - you can easily see that "2 tons" of Air conditioning is what is required to cool the 'average' home of 1100 sq ft. "roughly speaking."
Note: it is always best to have a professional 'size' your cooling/heating needs.
One of your questions was could you 'mix tonnage?'
The answer is 'usually you don't mix the tonnage of your outside/inside units.' However, professionals sometimes do (mix the tonnage) in certain situations, and installing a 2.5 ton outside unit with an existing 2 ton inside unit is often done, however, there are some 'tech issues' here and - I would "again" recommend that you call a Service Tech to help you with the sizing/mixing of your cooling/heating needs.
hope this has helped
Jun 20, 2010 | Carrier 38CKC036 Air Conditioner
I am getting alot of water leaking out of the unit.
I live with my husband and three sons in a house that we almost never succeed in cooling enough every summer. But a few months back, my uncle mentioned that he had recently purchased a new model of air conditioner by Plasma Cool called Plasma Cool Portable PC-14E that required no draining and came equipped with technology to remove most of the humidity from the air. We checked this ac out at his home, and the next thing we did was researched all the no drain acs with evaporative booster out there in the market to see if there was anything better than the one my uncle had. But the only one that met our needs and budget was Plasma Cool Portable PC-14E. At 14,000 BTU, this ac is 40-50% more powerful than similar acs in the market and covers upto 500 sq. ft. Look for this product on www.plasmacoolportableac.com which lays out the features and specifications in easy and comprehensible fashion without coming across as trying too hard to sell you the product. We just finished the 30 day trial period, and now own the ac. We are very satisfied and are considering purchasing another unit soon.
Jun 25, 2009 | Frigidaire FAP094P1Z Portable Air...
LG ac M483CS not cooling
It is possible that the contactor points have carbon or dust deposits causing an intermittent condition or bad connection. Why not try replacing the contactor?
Feb 02, 2009 | LG LSC183VMA Split System Air Conditioner
Ac compressor not working
This unit is a 220 volt ac unit. 12-2 wiring is usually for 120 violt circuits?
  • Amps: 22.2 / 20.0
  • Watts (Heat): 4900 / 4000
  • Watts (Cool): 1650 / 1625
  • Amps (Cool): 7.7 / 8.3
  • Voltage Rating: 230V / 208V 60Hz
  • Power Cord Length: 5' (6')
  • Horsepower (Cool): 2.49
  • Plug Type: LCDI 6-30P
  • http://www.frigidaire.com/Home-Comfort/Air-Conditioning/Window-Mounted-AC/FFRH1822R2
    hope this helps?
    Jun 05, 2017 | Frigidaire Heating & Cooling
    Unit freezing up and shutting off
    Ordinarily air conditioners do this when they are too big,(BTU wise), for the area being cooled. They will shut off to prevent system damage. There has to be enough warm air drawing back to the unit to keep the coils from freezing up. A more rare scenario would be an overcharge from the factory and manifest itself immediately.
    Thank you,
    Dave E. (Illeagle)
    Jun 15, 2008 | Maytag NMPEB08F2A Air Conditioner
    Heating & Cooling Logo
    46 people viewed this question
    Top Maytag Heating & Cooling Experts
    Rick Johnson
    Rick Johnson
    Bill Long
    Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
