Ink system has failed, error 0xc18a0206
I have a problem with HP D7163, the printer's error is ink system has failed, error 0xc18a0206, would you please help me?
  • omrantech Sep 27, 2009
    0xc18a0206 how to solve this problem hp photosmart d7163
I have a HP C5180, receiving error message 0xc18a0206 Ink System Has Failed. I have replaced all cartridges, unplugged power supply and USB cable for reset and am still receiving error message. Help! ...
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Mar 09, 2011 | HP Photosmart C5180 All-In-One InkJet...
I have error 0xc18a0206 HP Photosmart D7163 Printer i am not solve problem i need help me
Check out for the black sartridge and colour cartridge and face on the small circuit on it. Run smoothly with a piece of paper and also rub off the ink paste on the circuit. Then place it again on to the printer. Close the door tray. The printer will detected as normal.
Nov 22, 2010 | HP Photosmart D7160 InkJet Printer
Hp 8250 ERROR 0xc18a0206
Peggy,
This is an ink cartridge problem.
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 19, 2009 | HP - HP Photosmart 8250 printer
Ink system has failed. Unable to copy, receive
normally in this scenario the whole printer needs to be replaced..
Oct 22, 2009 | HP Photosmart 3310 Printer
Hello, my HP 3210 printer has an ink system failure...error: 0xc18a0206 , i have followed almost every possible solution on the net...replacing ink cartridges, re-installing drivers and programs, unplug...
Follow steps below to reset Hewlett-Packard (HP) All-in-one Printer. Resetting your printer will reset your printer to its original state.
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold “# and 6′ keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
** Give me your feed back
Oct 02, 2009 | HP Photosmart 3210 Printer
My printer says ink system has failed. Refer to
My HP Photosmart c5183
printer says ink system has failed. Refer to printer documentation. Error: 0xc18a0406. Please help.
Sep 24, 2009 | HP Photosmart 3210 Printer
1,300 people viewed this question
k24674
jasbo
jasbo
