Question about Whirlpool LER4634J Electric Dryer
Whirlpool electric dryer did not turn off automatically when set to time dry. Removed panel over wire connections and found black wire fused to cover of white wire and disconnected from screw - connection loop burned. Can this be replaced? Is there a deeper problem that would have caused this?
  • Whirlpool Master
  • 19,396 Answers
If you had an internal short (white and black wires shorted), then try first replacing the wiring harness.
If replacing the wiring harness does not fix the problem, then you may have damaged the control board or a different part connected to the wiring harness in question.
Enter the model number here to get parts and diagrams for your appliance.
Posted on Sep 05, 2009
My Whirlpool duet dryer isn't drying on automatic or timed settings. I replaced the ther-o-mister, but the dryer isn't heating up. How do you run a diagnostic on this dryer. Model GEW9250PWO
You should know that dryer has a thermal fuse located along exhaust Of heat... When You over load the machine the flow of air is not enough... Then thermal fuse is damaged ( open due security condition ) and the flame is turn off all the time... Just replace the thermal fuse. I hope this can help You. Sincerely
Jul 10, 2013 | Dryers
Duet dryer problem - GEW925PWO control panels do not automatically set. When they do give lights and time like they are accepting, they are not matching up with what the control is set on. The whole left...
hi The dryer timer, located in back of the control panel, controls several things: the drying time of the clothes in the drum, the flow of electricity to the heating element, and the flow of power to the timer motor and the drum motor in the dryer cabinet. Timers are driven by synchronous motors. Although the contact part of the timer can be cleaned and adjusted on some dryers, this is a job for a professional repair person. Timer motor repairs should also be handled by a professional, but you can replace a faulty timer yourself. Here's how to test and replace a dryer timer:
Step 1: To access the timer, remove the front of the control panel. On some dryers, the timer can be removed without removing the panel. In either case, pull the timer knob off the shaft and slip off the pointer. The pointer is usually keyed to the shaft by two flat surfaces to keep the pointer from slipping when it's turned.
Step 2: Test the timer with a VOM set to the RX1 scale. Turn the timer to the NORMAL DRY setting and disconnect one of the timer power leads. Some timers may have several wires connected to them: The power leads are usually larger than the other wires, and this size difference can be spotted under close examination. Clip one probe of the meter to each timer terminal. If the meter reads zero, the timer is working. If the needle jumps to a high reading, the timer is faulty and should be replaced. Replace the timer with a new one of the same size and type.
Step 3: To replace the timer, have a helper hold the new timer close to the old one, especially if there are several wires to be changed. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram detailing the proper connections. After all the wires are connected, check the connections again for accuracy.
Sep 13, 2008 | Whirlpool Dryers
Whirlpool AWZ7303 condensing tumble dryer . Drum not turning although it is heating
If your Whirlpool dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers, thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F. Thankfully, troubleshooting the thermal fuse in a Whirlpool dryer is easier than it sounds. Instructions:
  • Clean out the lint screen in your Whirlpool clothes dryer. Lint buildup can cause your dryer to overheat, triggering the thermal fuse to disrupt power to your dryer's heating mechanisms. Take the lint screen out of your Whirlpool dryer and wash it in warm water. Dry the screen thoroughly before replacing it.
  • Look behind the dryer to check its flexible exhaust hose for kinks or obstructions. Disconnect the exhaust hose from the back of your dryer and clean out any lint that has built up.
  • Go outside and check your Whirlpool dryer's exhaust vent for obstructions. Lint buildup, bird nests or other obstructions in the outside exhaust vent can trigger your dryer's thermal fuse.
  • Disconnect your dryer from its power source before attempting to access its thermal fuse.
  • Access the thermal fuse in your Whirlpool dryer by removing the back panel. Remove the screws that hold the back panel in place and it should easily come free.
  • Look between the dryer's blower housing and exhaust to locate its thermal fuse. The thermal fuse in a Whirlpool dryer looks like a white plastic strip that has two wires connected to it.
  • Bypass the thermal fuse in your Whirlpool dryer while you perform a quick diagnostic test. Use electrical tape to tape together the two wires connected to the thermal fuse. Reassemble your dryer and plug it back in. Set the dryer to a timed heated drying cycle and press "Start." If the dryer produces heat with its thermal fuse bypassed, it means the thermal fuse needs to be replaced.
  • Replace a blown thermal fuse in your Whirlpool dryer. Disconnect the power and remove the back panel. Remove the electrical tape that you used to perform the diagnostic test and disconnect the wires from the thermal fuse. Remove the screws that secure the thermal fuse to the dryer and discard the blown fuse. Attach the replacement thermal fuse by replacing and tightening the screws. Attach the wires to the new thermal fuse.
  • Apr 20, 2011 | Whirlpool AWZ7303 Electric Dryer
    No heat when drying clothes
    Hello there
    Please investigate the following
    Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. you can test them with a meter usulaly tested between 20-40 ohms anything else means replace it Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
    Jan 26, 2011 | Whirlpool AWZ7303 Electric Dryer
    No heat , drum turns and wont shut off
    Hi, On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
    May 05, 2010 | Whirlpool LER4634J Electric Dryer
    Whirlpool dryer wont turn on
    Hi Joe,
    Your thermal fuse has blown. It's a cheap little part, here it is.
    To get to it, Pull the dryer out and unplug it. Remove the rear panel. As you're viewing the dryer from the rear, look just to the left of the dryer exhaust... you'll see it there. It has 2 blue wire connected to it.
    Remove the wires, remove the old fuse, install the new one, install the wires and replace the back panel.
    There ya go! FixYa! Please take a moment to rate this as "solved".
    Thanks,
    SG
    Mar 28, 2009 | Whirlpool LER5636P Electric Dryer
    Whirlpool Gas Dryer keeps running on auto dry setting
    When you moved the sensor wire on the moisture sensor may have fallen off.
    Remove the front panel and locate the wire and the connection. It will be on the right side near the lint filter vent. If it is still connected your timer has gone bad.
    Mar 26, 2009 | Whirlpool Dryers
    Dryer not heating
    It it blows cold air it is a faulty element or a faulty thermal fuse, this parts should be tested and eventually replaced.
    See There's no heat
    Dec 02, 2008 | Whirlpool LER4634J Electric Dryer
    E-2 error code on whirlpool duet dryer
    “E2” flashes if the thermistor has shorted.
    The thermistor monitors the exhaust temperature
    and cycles the high-limit thermostat on
    and off to maintain the desired temperature.
    1. Turn the dryer off but keep the electrical
    supply connected.
    2. Make sure that the dryer is empty and that
    the lint screen is clean.
    3. Close the dryer door.
    4. Select Heavy Duty, Timed Dry, More Time
    or Less Time, End of Cycle Signal (Louder)
    and Start.
    5. If error codes E1 or E2 flash on the display
    after 1 minute and the dryer turns off,
    the thermistor, or the wire harness, is either
    shorted or open. Check the wire connections
    at the thermistor or the machine
    control electronics board. If wiring checks
    okay, replace the thermistor.
    6. If the dryer seems to operate normally, remove
    the exhaust vent and start the dryer.
    7. Select the desired temperature cycle to be
    tested, and select 20 minutes of Timed Dry
    heat using the More Time or Less Time
    pushbuttons.
    Feb 25, 2008 | Whirlpool GEW9250 Electric Dryer
    Whirlpool Dryer Model GEW9200LW0-Shutting off
    Guest. Your thermistor has opened, it's very easy job and inexpensive. You will have to remove the lower panel. Right behind the vent housing will be the themistor and thermal fuse. The thermistor will be the black one on the right of the thermal fuse. Kill the power, Two quarter inch screws holding it on, two wires going to it. Here's your tech sheet if the link works, http://www.servicematters.com/docs/wiring/wiring_main.htm Catriver.
    Jan 13, 2008 | Whirlpool GEW9250 Electric Dryer
    Whirlpool LER4634J Electric Dryer Logo
    23 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal DeAngelo
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
