Windows vista registration has stopped working, windows states that it is searching for a solution, but doesn't.
    President:
  • 2,600 Answers
Have you tried booting from the vista disc and selecting repair from the menu? Try that, Vista is pretty good about fixing start up problems.
Posted on Sep 05, 2009
Windows Vista Ultimate x64 disc stopped working. product key still valid. do i need to buy a new one or can i get the disc only somewhere?
When you say it is not working, is it none functional? or is it stating that windows vista is not genuine? because there may be another issue.
May 02, 2012 | Microsoft Windows Vista Ultimate Edition
Windows vista ultimate doesn't recognize my labtec lcs 2424 speakers but it does my sound card
Being windows vista is most likely is a driver problem. Is it internal or external sound system, not the card that works. If the manufacturer does not have an updated driver by now you can set the device to work like windows xp and it should only effect that device. Also search the web there are driver packs out there for windows vista, keep in mind its all the drivers for everything on one large compressed file so it should be a large file size.
Ultimately I would say upgrade to windows 7, its how windows vista should have worked. I have devices from windows 98 that work on win7 no problems. Vista was just very premature in its release. Hope this can help. Sorry for my bad spelling.
Oct 20, 2011 | Labtec LCS 2424 Computer Speakers
Lost registry files, OEM software so I don't have the disk to reinstall Windows. Operating system is Windows Vista Home Premium, 64 bit.
http://thepiratebay.org/torrent/4477672/window_vista_home_premium_64_bit_sp1_NOT_CRACKED
in this location you wil be able to download the vista and after that burn it on a disk using Nero ...remember to double click on the image ..and let nero make it bootable ..do not open nero and try to burn by adding ..
You will need a torrent client to be able to download use uttorent is tha fastest ..and it is available on google search for free
But ..if you do not want the 64 ...there are available more vista on 32...and they are even without need for registration ...But if you do have the opriginal registration from the previous..this will do the job cause it is the exact one that you had..
Aug 01, 2010 | HP Computers & Internet
I connect the inter net its working well but this month is not working and show the note malicious or malfunctioning add on caused internet Explorer to closed this web page its my computer is not working...
mcdevito75 here, Many people sending adds of all types over the net, It"s not your computer but the internet itself, You can try to up-grade your windows vista type into search from your home page, windows vista upgrade This may help block un wanted adds windows doesn"t allow.
Jun 29, 2010 | Microsoft Windows Vista Home Premium with...
When i am starting my laptop always coming on screen that vista registration has stopped working so, please give solution
Click on the Start and type msconfig in the Start Search box. Msconfig will appear at the top of the Menu. Rightclick on it and choose "Run as Administrator". Click on the Startup Tab and uncheck the below startup.
[Toshiba Registration] C:\Program Files\Toshiba\Registration\ToshibaRegistration.exe
Reboot and you shouldnt have anymore problems. Make sure that you give Toshiba a call though and register your computer. This may be a requirement to validate your warranty.
Apr 25, 2010 | Computers & Internet
Webroot Firewall Stops working (Windows Vista)
Hi there!
Try re-installing the software. Also, there maybe registry or windows related problems but there's a solution to that: run TUNEUP UTILITIES and run a full system check on your computer.
Also, make sure your activation key or registration has not expired.
Hope this helps
-levibit-
Apr 01, 2009 | Webroot AntiVirus with AntiSpyware &...
I waNT TO stop the registration reminder window
If you are on Windows 7, go into "regedit" and navigate to "HKEY_LOCAL_MACHINE\SOFTWARE\LexmarkInkjet\IjPrtSettings\OFN1" and then delete the following two keys:
CustomerConnectInstallTime
InstallTime
You can also manually do this in Vista, just its under "HKLM\SOFTWARE\LexmarkInkjet\IjPrtSettings\OFN1".
Mar 09, 2009 | Lexmark X2350 All-In-One InkJet Printer
Is my canoscan 8000f vista compatable On the site of canon they state that the same driver can be used as for Windows XP. This is not true. Untill now, I found no way to get it working again.
You may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Jan 24, 2009 | Canon CanoScan 8000F Flatbed Scanner
Scanjet 5400c won't scan in Vista Home Premium
Unfortunately, your scanner is not compatible with Windows Vista and there are no drivers available to make it compatible. I found the following message on the HP website when I searched for Vista drivers for your product:
We are sorry to inform you that there will be no Windows Vista support available for your HP product. Therefore your product will not work with Windows Vista. If you are using the Windows Vista operating system on your computer, please consider upgrading to a newer HP product that is supported on Windows Vista. HP has numerous products on the market that support Windows Vista. If you are in the US, see http://www.hp.com/united-states/tradein/home_flash.html . If you are outside the US, click the How to buy link at the top of the page.
Apr 22, 2008 | Computers & Internet
Can i use windows vista
Do a search on the internet for the dll file. Download and install it to your system folder. If you run across a site that asks you to pay or fill out some long laborious registration keep searching. There are sites that have them with minimal hassle (free). Given it at least asked for the dll it is probable it can be run on vista.
Jan 31, 2008 | Roxio PhotoSuite 4.0 (200500) for PC
Computers & Internet Logo
383 people viewed this question
David Payne
David Payne
