I recently purchasded and set up a new Z-5400 5-1 speaker system to work with Sony KDL-32D3000 tv and HXD870 dvd recorder. Tv is connected via optical and dvd via co-axial cables.
System works well and sound very impressive. However every so often (about 22min) there is a disturbing 'pop' sound that can be quite startling. This occurs when using tv or dvd. Could this be due to a static discharge or what. Any ideas as to solve the problem would be appreciated.
No problem with earthing system so unlikely this causing problem. It may be due to other appliances cutting in/out ie freezer etc. Frequency of 'popping has much reduced after plugging amp into different socket. Will try connecting via surge suppressed terminal block next. Thanks for your help. Regards, J
I have two month old Bose Lifestyle 28 Home Theater system installed by the Geek Squad and wired into my home. All worked perfectly until a few days ago when a "poppiong in the speakers began. Only occurs on AUX wheather the TV is on or not. Is this a failure of some component inside ?
I have eliminated interferance from outside sources by turneing everything in the house off. What gives ??
