Question about Refrigerators
Condensation collects under the crisper drawers and needs to be cleaned out every few days. What is causing this?
  • Refrigerators Master
  • 3,361 Answers
Without a model number I can not be as specific as I would like.
If this is a top freezer model your defrost drain hole is clogged with ice or trash.
Remove the rear panel inside the freezer to access the drain hole. You should see a slab of ice in the back portion of the freezer. This will have to be completely thawed out. A hair dryer will help in thawing. Turn the fridge off. Melt the ice. Pour a 1/4 cup of bleach into the drain hole. Re-assemble the freezer components and turn the fridge back on.
This process will take an hour or more time.
If you have someplace to keep your food,you could unload the fridge. Turn it off. Leave the fridge off and the doors open overnight and it will self defrost.
Posted on Sep 05, 2009
  • 3,600 Answers
First be sure all door gaskets are clean then check the drain hole in the bottom of the refrigerator and clean the hole with a wire popping it into the drain hole in the bottom under the crisper boxes. Since you did not mention brand I don't know if it has a drain in the upper section of the unit.
There is water collecting continuously at the bottom of my fridge under the crispers. Do you know how I can fix?
Most frost free refrigerators take water from the freezer so you do not have to defrost the freezer. That being said there should be a drain under the crisper. Check to see if it is clogged.
you may need to put something under the refrigerator to collect the water..
Jan 03, 2015 | Refrigerators
What would cause a refrigerator to collect water under the fruit and vegetable drawers?
hi there, refrigerators have condensation that forms and generally goes down a little hole that is usually under the fruit and vegetable drawers. This water should go down this whole into a condensation pan that is under the refrigerator and then evaporates. Sometimes food gets in the hole under the drawers and keeps the water from being able to travel where it needs to. Try to run a pipe cleaner of something through the hole to clean it out and maybe a very small amount of HOT water. If there is no hole there, it is unusual and it is possibly something else. This is usually the problem I have. Hope this helps!
Jan 15, 2011 | Kenmore Refrigerators
Model 363.9668513 water collects under the fruit
this is because the plastic is shiny and attracts condensation,only "cure "is a piece of kitchen towel under drawer to mop up as/when.(when you open door all the cold air drops to the floor and is replaced with warm moist air from the kitchen.hence condensation.
Apr 13, 2010 | Refrigerators
WE have an older fridge. Water is now collecting
Good day,
On some of the older models when the refrigerator went thru it's automatic defrost cycle, the condensate water ran down the back wall, under the crispers and out that drain plug you described.
You can verify if that is your model by looking at the back wall of the machine. If there is no drain tube running down the back, then that is the model you have.
If that is the case, just remove the plug. The water should run directly into the drain pan.
Clean the plug and opening and that's it.
Apr 05, 2010 | Maytag Admiral Top-Freezer Refrigerator
I have Kenmore refrigerator,leaks water inside.
Is there an ice maker in the freezer? If so, check all fittings, otherwise, this is condensation, which is VERY common & is actually expected, especially in summer months. There should be a small hole in the bottom, center, under the crisper drawers, make sure that it is not blocked up. The condesation (water) that builds up goes through that hole into a condensation drain pan & gets cooked off by a little boxy thing (golly I forget the correct term & my husband is a refrigeration tech) that warms up or simply evaporates in to the air. The water you see is NORMAL, but your drain may be plugged up, so go have a peek to make sure it's clear, if not, just clear it out & you'll be good to go. Good luck.
Aug 29, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water collects under crisper drawers
Does it have darin at the bottom to drain out the bottom of the frifge into the drip pan? if it does push a wire threw the hole with the unit unplugged.
Aug 28, 2009 | Refrigerators
Water standing under crisper drawers
small drain hole/tube inside (behind crisper pans) is stopped up. Clean out with flexible wire, etc.
Jun 21, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Refrigerator has water under the crisper drawers
There is most likely a plugged drain in the freezer section. The easist solution can be to empty the refrigerator and unplug it over night. If this is not possible then the back or bottom should be removed to allow access to the drain and a hair dryer can be used to make defrosting go faster. still takes a while, if there is access in the back of the unit that can be the cause of the plug.
Jun 19, 2009 | Refrigerators
Water is gathering under the crisper drawers. We have to mop up every 2 or 3 days
Frost-free refrig. have a condensation drain on the inside back wall . Check for a blockage. Use a pipe cleaner (pipe tobacco) to clear it.
May 13, 2009 | Refrigerators
Heavy moisture collect under crisper and moister collects in crisper drawers up and down
Check this thread by Catriver - think this answers your problem; http://www.fixya.com/support/t137810-water_dripping_inside_fridge Hope this helps :)
Mar 16, 2007 | Whirlpool ET1FTKXK Top Freezer...
Refrigerators Logo
130 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
