I get a message - The folder 'itunes' cannot be found and is required. I moved my music files (outside of the itunes app using Windows Explorer (Doh!) and now can't open the itunes app to change the folder location via the top toolbar. I've tried uninstall and fresh install - any ideas?
  • 66 Answers
I would suggest using Windows Restore (Start/All programs/Accessories/System Tools/System Restore to restore your computer back to the way it was before you moved the files. Then you can move the iTunes libraries from within iTunes itself.
If you are not familiar with System Restore, note that when you go back if you won't lose data but any other programs you've installed will need to be reinstalled.
Posted on Sep 05, 2009
How do I download what's app on an ipad
Hi, you can if you follow these instructions.
1. Download whatsapp on your itunes in your computer.
2. Locate the .ipa file by right clicking the app in itunes then select "show in finder" or if pc, "show in explorer"
3. Download ifunbox, plug ipad then select install app, then install whatsapp.
4. You will need an iphone with a freshly downloaded whatsapp
5. Enter the number you will use and then activate
6. When youre done, plug the iphone in the pc and use ifunbox again
7. Copy the documents and library folder in the whatsapp folder to your desktop
8. Unplug iphone then plug ipad
9. Overwrite the documents and library folders and then start using whatsapp in ipad
10. Im using this in my ipad air now so it works
Install WhatsApp On iPad And iPod touch Without Jailbreak VIDEO Redmond...
May 24, 2014 | iPhone Apps
Itunes knocks out DVD/CD driver whenever I update Itunes.
Solution 1
Check with your manufacturer to see if there are updated software drivers for your optical drive. For more information about updating the firmware of your CD or DVD drive,
Solution 2
Launch Windows Explorer.
Navigate to C:\Windows\system32\drivers\.
Check to see if either of the following 2 files are present. These files from a third-party software vendor are not supported by Windows Vista and can cause driver conflicts with optical drives:
afs.sys
afs2k.sys
If either of the files in Step 3 are present, move them out of the system32 folder. You should keep these files stored somewhere on your hard drive, as some of your older peripherals may require them. If you find that they are required in the future to use a device, you may move them back into the system32 folder temporarily.
Reboot Windows Vista.
Solution 3
Quit iTunes.
Manually remove the GEAR driver software using the steps found here.
Remove any stand alone GEAR software installers from the Programs and Features control panel, if present.
Install the updated GEAR driver.
Mar 06, 2010 | Toshiba SD-R5272 DVD±RW Burner
ITunes stopped working.
Search for a folder called iTunes Library - if you find it, click directly on the file inside this folder called iTunes Library.
If you find more than one, select the one you prefer and later you should be able to delete the others ..
If you open iTunes by clicking on the library, instead of just opening iTunes, it should set the library for you in the iTunes Preferences and it "should" stay that way ... just to be sure, close iTunes and then reopen the normal way, just by clicking on the program ... see what happens ...
Be careful not to delete any "extra" libraries that contain music that is not in the library you select - ideally you should have only one library with all the music, videos, etc, in it ...
If this doesn't work, go to Preferences in iTunes and look at the "advanced" tab - look at what it says for iTunes media folder location - make sure this is where your library is ...
This process can be a bit complicated, particularly if you have more than one library, so it's important to find the one library you want to keep, make sure all the music and other things are in it (copy everything in if you have to) and delete any additional libraries ...
Let us know what happens, how it works out. If you have more questions come back!
Once you get it set correctly, don't move your iTunes library if you don't have to, because it is a little confusing to get iTunes to show all your music correctly again ... if you have to, search on Google for "how to move iTunes Library" for help before you do it!
For help with Sound System Feedback, rexark.com
Mar 02, 2010 | Apple iTunes
I have a classic iPod 80Gb. I have just loaded iTunes v8.1 onto my laptop using Vista home. When I try to ope iTunes the following message comes up:"The folder iTunes cannot be found or created and is...
Uninstall the egzisting itunes by following steps. Start menu> Control panel>click on the Control Panel home on the upper left side>same windows you will see the programs and under Unisnstal a program waith for list of programs refreshes highlight Itunes and press the Uninstall tab and reinstall the Itunes
May 01, 2009 | Apple iPod MA446LL/A MP3 Player
Can't get itunes to work
The error message “The folder iTunes cannot be found or created”. It was referring to the My Music directory that is usually located in the My Documents folder on the partition containing the operating system. The iTunes software creates an iTunes folder in the My Music directory on first start and if that directory is not accessible it will throw the error message and fail to load.
Since this error is related to the My Music folder it is important to check the directory path of that folder in the Windows Registry. This is best done by using the shortcut [Windows R], typing [regedit] and hitting the [enter] key.
The fastest way of location the two locations that contain path information for the My Music folder is to use the search by pressing [F3] and entering [My Music] in the search box. A click on [Find Next] will start the search and reveal the two locations.
The test computer system did not have path information listed at all. This can be changed by double-clicking the My Music key in the Registry and changing the path to an valid path manually.
The two Registry locations that list the My Music path are the following two:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
Make sure both point to a valid path on the system. Once the path has been changed iTunes will create the iTunes folder in that location and start up without this error message.
Please back up your registry before doing this. messing in the registry can make your computer stop functioning.
Make sure you follow the correct registry entry.
Apr 26, 2009 | Apple iTunes
ITunes won't open
Go to "Preferences" in iTunes and change the music folder location to the location on your new disk drive. Click the boxes as shown below:
image.tiff
Dec 28, 2008 | Apple iPhone Smartphone
Disk is Locked Error
If the My Music folder is in the wrong location or incorrectly assigned in the Windows registry, you may see one of the following error messages:
  • "The folder iTunes is on a locked disk or you do not have write permissions for this folder."
  • "The folder iTunes cannot be found or created and is required. The default location for this folder is inside the Music folder."
If you see one of the above errors, follow these steps to troubleshoot this:
  1. Verify the location of your Windows XP My Music folder. The default location for this folder is
    C:\Documents and Settings\username\My Documents\My Music
    If you do not have this folder at the default location and have not moved it to another location, consider creating one inside your My Documents folder.
  2. Download and install Tweak UI from the Microsoft PowerToys website at http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx Note: This utility is for Windows XP only. Please review the system requirements before installing.
  3. Once you have installed Tweak UI, open it from the Start menu.
  4. In the column on the left, click on the plus symbol (+) next to My Computer and select Special Folders. ht1866_01.jpg
  5. In the right pane on the Folderlist, click My Music.
  6. Click the Change Location button. You may see a warning message appear with precautions for changing this setting; after reviewing the message, click Yes. ht1866_02.jpg
  7. In the resulting window, browse for the My Music folder as described in step 1, and click OK. ht1866_03.jpg
  8. Reinstall or open iTunes.
Oct 13, 2008 | Apple iTunes
Itunes transfer of music
hi there,
you can use software to do this task which takes less time to get done :-
http://www.transfer-ipod-to-itunes.com/showproduct.aspx?t=a
or
Follow the steps outlined :-
1. You need to connect the iPod without iTunes doing the auto-sync.
  • Hold down the Shift and Ctrl keys while connecting the iPod to your computer.
  • Don't let go of Shift+Ctrl.
  • If iTunes doesn't open automatically open after connecting the iPod, open iTunes.
  • Wait until the iPod comes up in the Source list under DEVICES (it may take a while, but don't let go of Shift+Ctrl)
iTunes may pop up asking you to choose an existing library or to create a new one. Click Create a new one so that it can just open.
Once it shows up, close iTunes.
2. Now find the songs on your iPod and copy them to a folder on your computer.
  • From the Desktop, go to My Computer and click once (or select/highlight) on the iPod, (usually drive E:, F: or G:)
  • Go to Tools > Folder Options.
  • Click View tab > scroll to Show Hidden Files and Folders and select it. Click OK.
  • Look in the iPod drive, and find a folder called iPod_Control and open it.
  • You'll see the Music folder. In it will be folders and files named F00, F01 and so on.
To see the original name of the song/file, just mouse over it.
  • If you need all the contents of the iPod on you computer, copy the whole Music folder.
  • If you only need some of the files, look through the Fxx folders until you find the files you want and copy.
  • To copy:
    • Click once on the folder or hold down the Ctrl button and click once on each of the folders you want.
    • Go to the Edit menu and select copy.
    • Minimize all windows, right click over a blank area of the desktop, select New > Folder (name it Songs).
    • Right click over the Songs folder and select Paste.
      • Depending on the number of songs, this may take a long time to complete.
All the hidden files that are on your iPod are playable on iTunes once you transfer them to your computer's iTunes.
3. Now have iTunes import that folder to your music library
  • Open iTunes (if needed) and go to File > Add Folder to Library.
  • Select the folder you want to import and click OK.
Apr 13, 2008 | HP Pavilion dv6000z Notebook
ITouch & iTunes
Firstly you will need to create a folder in 'My Music' and Rename it iTunes.
Write Back And i Wll Tell You The next stage.
Feb 20, 2008 | Apple iPod touch
Connecting ipod to a new laptop
You can actually (or could have) transfer the songs from your
Laptop & iPod by using you iPod like a removable
Hard Disk Drive
Here is the Apple sanctioned method:
Note: While you can use the Transfer Purchase From iPod option under the File menu to copy iTunes Store purchases from the iPod to another computer you can't transfer songs from other sources from the iPod library to iTunes
So you'll need to follow the steps below to use iPod as a hard disk to transfer music files from one computer to another. This process will require the use of iTunes 7 on all computers. Any computers running iTunes 6 or earlier will need to be updated to follow these steps.
Once you have the files transferred, you'll need to authorize any iTunes Store content. If you won't be using your old computer, you'll want to deauthorize it.
Important: Windows operating systems don't recognize Mac OS-formatted disks (HFS or HFS Plus formats), so you can't use a Mac-formatted iPod to move your music to a Windows PC.
Switch the iPod to manual update and enable disk use The first thing you need to do is make sure have configured your iPod to enable disk use. To do this:
  1. Open iTunes on your old computer.
  2. Connect your iPod to your old computer and wait for it to appear in iTunes.
  3. Select your iPod in the Source pane under the Devices section to display your iPod preferences in the main library window.
  4. Click the Summary tab in the main iTunes window.
  5. Click the Manually manage music button. Changing from automatic updating to manual puts a check mark by Enable disk use. A message says:
"Disabling automatic update requires manually unmounting the iPod before each disconnect."
If you need to copy from old computer:
Copy iTunes folder to iPod To copy all your music files (including the library file that holds all your playlists and other settings) to your iPod:
  1. Quit iTunes.
  2. Locate your iPod:
    Mac OS X: On the desktop
    Windows: In My Computer
  3. Locate your iTunes folder:
    Mac OS X: /Users/username/Music
    Windows: \Documents and Settings\username\My Documents\My Music\
  4. Drag the iTunes folder to the iPod. This can take a while if you have a lot of songs.
OR
  • When the copy completes open iTunes.
  • Click on the iPod in the Source pane
  • Click the Eject button in the lower right corner of the iTunes window.
  • Disconnect the iPod from the computer when the "Do not disconnect" message no longer appears on the iPod screen.
Now:
Copy music to new computer To copy all your music files (including the library file that holds all your playlists and other settings) to your new computer:
  1. Locate your Music folder (Mac OS X) or your My Music folder (Windows) on your new computer:
  2. Drag the iTunes folder in this location out to the desktop. 300173_10.gifFrom the My Music folder to the Desktop on your new PC
  • Locate the iPod on the new computer:
  • Mac OS X: On the desktop.
  • Windows: In My Computer.
  • Double-click on the iPod to open it.
  • Drag the iTunes folder from the iPod to the Music folder (Mac OS X) or My Music Folder (Windows) on your new computer. This can take a while if you have a lot of songs.
  • Open iTunes
    There you go. All your music, playlists, and other information like play counts and ratings have all been moved from your old computer to your new one.
If that doesn't cover it fully..... wow!
Feb 12, 2008 | Apple iPod nano
Computers & Internet Logo
David Payne
David Payne
