Question about Photography
My problem is part need part can you help
My problem is part need part can you help the part I need is the support to hold the camcorder in place
My HDR HC1 is showing moisture condensation alert every second time I turn it on for shooting. Also, in the playback mode on a shot tape I cannot find any video on the monitor...
- remove all from camcorder.(battery,tape and accessories and place the camcorder in a dry storage(ive tried placing it inside a rice container for a while and it helped because rice grains will absorb moisture) make sure to put the camcorder on a platform(cardboard or anything flat to place your camcorder) if you're going to place it in a rice container.its worth a try and its safe but if the problem persists i would recommend you to have you're camcorder checked and cleaned by a professional.
Jun 05, 2011 | Sony HDR-HC1 Mini DV Digital Camcorder
Hi i have a sony dcr-pc55e and when i go to use it the lcd screen falls down and doesn't hold in place, do i need a new hinge or bin the camera?
Sounds like you need to have the hinge assy replaced. This should probably be done by an experienced technician. Amazon is still selling this camcorder for $585 so it is probably worth repairing...unless there is another camcorder with more bells and whistles that you have been wanting, then I would recommend putting that money towards a new one.
Hope this has helped.
www.austintelstarservices.com
Sep 04, 2010 | Sony DCR-PC55 Mini DV Digital Camcorder
Camcorder repair in Raleigh NC
hi there, you can try this place, call first to see if they can repair your camcorder:
Triangle X-Ray Company
4900 Thornton Road, Suite 117
Raleigh, NC 27616
Phone: 919-876-6156
Fax: 919-872-3986
Jun 26, 2010 | Sony Handycam DCR-SR40 Camcorder
Sony TRV120 Won't load tape C21:00 code
From the user manual ...
Under self diagnosis display
C21:00
Moisture condensation has occurred.
Remove the cassette and leave your camcorder for at least 1 hour to acclimatize. (p117)
On p117
If your camcorder is brought directly from a cold to a warm place, moisture may condense inside your camcorder, on the surface of the tape, or on the lens. In this condition, the tape may stick to the head drum and be damaged or your camcorder may not operate correctly. If there is moisture inside your camcorder, the beep sounds and the [picture of water drip] indicator flashes. When the [end tape icon] indicator flashes at the same time, the cassette is inserted in your camcorder. If moisture condenses on the lens, the indicator will not appear.
If moisture condensation occurred
None of the functions except cassette ejection will work. Eject the cassette, turn off your camcorder, and leave it for about 1 hour with the cassette compartment open. Your camcorder can be used again if the [water drip] indicator does not appear when the power is turned on again.
Note on moisture condensation
Moisture may condense when you bring your camcorder from a cold place into a warm place (or vice-versa) or when you use your camcorder in a hot place as follows:
- You bring your camcorder from a ski slope into a place warmed up by a heating device.
- You bring your camcorder from an air-conditioned car or room into a hot place outside.
- You use your camcorder after a squall or a shower.
- You use your camcorder in a high temperature and humidity place.
How to prevent moisture condensation
when you bring your camcorder from a cold place into a warm place, put your camcorder in a plastic bag and tightly seal it. Remove the bag when the air temperature inside the plastic bag has reached the surrounding temperature (after about 1 hour).
Dec 06, 2008 | Sony Handycam DCR-TRV120BT Digital...
Hello...
xiii
Dew Formation
What is “dew formation”?
When cold water is poured into a glass,
dew drops form on the glass. This clinging
of water drops is called dew formation.
When dew forms in your camcorder.
Dew will gradually form on the head drum
of your camcorder and make the video
tape stick to the head. This causes
damage both to the head and the tape.
When dew forms, recording and playback
may not function properly.
Dew is likely to form in the following
circumstances:
—When moving the camcorder from a
cold place to a warm place.
—When placing the camcorder in a cold
room which is then heated rapidly.
—When moving the camcorder outdoors
from an air conditioned room or car.
—When placing the camcorder in the
direct path of air
blowing from an air
conditioner.
—When placing the
camcorder in a
humid room.
How to prevent trouble.
When using the camcorder in a place
where dew is likely to form, allow the
camcorder and the video tape to
acclimate to the surroundings for about
one hour.
For example, when bringing the
camcorder indoors after skiing, place it in
a plastic bag.
1Be sure to tightly seal the plastic bag
containing the camcorder.
2Remove the bag when the air temperature
inside it reaches the temperature
of the room.
“Dew” warning feature
If dew forms, the word “DEW” flashes on
the screen, and the power will automatically
turn off in approximately 10 seconds.
Plastic bag
1If “DEW” flashes, remove the cassette,
leave the cassette compartment open,
and wait for a few hours to allow the
camcorder to acclimate to the
surrounding temperature.
2To use the camcorder again, turn on the
power after waiting for a few hours. Be
sure that “DEW” has disappeared.
3Do not insert a cassette while “DEW” is
flashing; this may result in damage to
the tape.
4Since dew forms gradually, it may take
10 to 15 minutes before the dew
warning feature engages.
Oct 22, 2008 | Sharp Viewcam VL-Z7U Mini DV Digital...
Flashing "DEW" Indicator shutting down the viewcam
I don't know if this will help, but when I leave the camera open with no tape in it for a day or so, "dew" goes away. Now I just store it open without a tape in it and have never had this problem again.
Hope this helps.
Feb 26, 2008 | Sharp Viewcam VL-Z7U Mini DV Digital...
Zoom
change the camera operation unit
Nov 16, 2007 | JVC 580136 Camcorder
Condensation Problems?
This is a fairly common problem. It requires solder rework of the fpc cable connector form the loading motor ass'y. The sensor is not being properly detected, normally low resistence, located on the ass'y. It is not an amateur repair. Better seek a pro. Good luck, magic seadog
Apr 16, 2007 | JVC Handycam GR-DX77 Mini DV Digital...
Which Hitachi models use a disc caddy to hold the DVD disc while in the Camcorder?
Current Hitachi Models use no disc caddy for the DVD disc. The 2003 and 2004 line of Hitachi DVD-Camcorders (DZMV350A, DZMV380A and DZMV550A and DZMV580A) utilize a round disc holder to accommodate the smaller design of the newer models. All previous generation DVD-Camcorders use a square cartridge. The actual discs are the same and can be used in all models as long as the disc is placed in the appropriate holder or cartridge.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Photography Logo
29 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Tony
Are you a Photography Expert? Answer questions, earn points and help others
