F5D8235-4V2 will not accept firmware upgrade. From interface the unit finds the update, I download per instructions, save, then navigate to the file and open. The update starts then in a few seconds it says it's not the correct file? Present 2.01.04 to 2.01.07 dated 6/2/09
  • silveryrado Sep 07, 2009
    Update! Mybad. Seems that the update the router finds is at the wrong address. Belkin sent the correct url and the update installed with no problem. FYI here is the link.http://www.belkin.com/uk/support/article...
  • 6,487 Answers
Since you have this firmware update problem it will be better if you reset first the unit and by holding the reset button for 20 seconds and then after that do the update again, but if still not working better you can the manufacturer and have it replace....
Posted on Sep 07, 2009
Testimonial: "I guess it's time for a new unit! I did find a security block by the computer under properties on the update, clearing the block didn't help the prob."
Step by step how to flash gentronpro 2 3500 generater
If you are doing a firmware upgrade:
1. Navigate to the default home page of your router.
2. Look for a setting such as "System" "Updates" "Settings"
3. Follow the on-screen instructions after having selected update firmware (note this feature may try to query the manufacture's website for firmware updates as the first thing it does.)
4. Check for a "browse for firmware file." or "Browse"
5. Navigate to where you saved the firmware upgrade file and select it.
6. Choose a button for "update firmware now" or "apply this firmware" or something of that effect.
7. Let it run but DO NOT unplug the router or stop the update while it's processing it. This could render the router useless.
If your router isn't set up this way. Let me know.
Jun 08, 2015 | Computers & Internet
Can i update camera firmware through a printer dock?
Kodak does not suggest a firmware upgrade through a printer dock. Instead, they recommend using an SD card (memory card).
First:
  1. Click Download, then save the firmware file to your computer desktop.
  2. Double-click the *.exe file. When the WinZip Self-Extractor screen appears, select a folder or accept the default location, then click Unzip. The firmware file unzips to the specified folder.
  3. Note the location of the *.FW file, then close the WinZip Self-Extractor.
Instructions:
  1. If you have pictures/videos on your camera's internal memory or on the memory card, save them to your computer.
  2. Ensure that your camera batteries are fully charged.
  3. Turn off your camera.
  4. Insert the memory card into your computer or into a card reader attached to your computer.
  5. Verify that the memory card has at least 100 MB free space.
  6. On your computer, select the removable drive associated with the memory card or card reader.
  7. If a System folder does not exist on the memory card, create one. From the removable drive window, select File > New > New Folder, then name the new folder System.
  8. Copy the *.FW file from your computer into the System folder.
  9. Remove the memory card from your computer or card reader, then insert it into your camera.
  10. Turn on your camera, then follow the instructions to begin the firmware upgrade. The upgrade takes approximately two minutes to complete.
  11. When "Upgrade was successful" appears on the LCD, select Delete Upgrade File to delete the firmware file from the memory card.
  12. Turn off your camera, then turn the camera on to activate the new firmware.
Feb 07, 2014 | Kodak EasyShare P880 Digital Camera
How to update map
I helped a buddy update his Uniden GPS (Trax350). Simply follow these steps and you should be done.
Uniden's MapTrax350 GPS device accepts voice-command programming and provides detailed audio commands, as well, speaking aloud the map directions that are displayed on its screen. Keeping your Trax350's firmware updated is crucial to keeping it working correctly. Usually, you can go to a company's website and download the latest software, but with Uniden, you must register your product first to access the proper free upgrades. It takes minutes.
Instructions
things you'll need: USB cable
1 Navigate to the link in the Resources section and fill in the required fields. Click on "Register."
2 Turn on your device and connect it to the computer using its USB cable.
3 Log in to the site with the password that was sent to your email address after you registered the device.
4 Choose "Software Upgrades." Select the MapTrax350 device, and the latest firmware upgrade will appear. Click "Download."
5 Select "Save File" and choose a location on your computer to save it to. After it has downloaded, double-click the program icon, select "Run" and follow the prompts to update your Trax350.
Mar 21, 2011 | Uniden GPS
Wire less disconnect very often When i disconect the wireless and connect again it takes time to reboot the wire less
Disconnecting wireless problems can be cause by any number of things. Please click on this link and follow my instruction to identify the problem and fix :-
http://www.fixya.com/support/r3559120-wireless_router_disconnecting
Feb 11, 2011 | NetGear WGR614L Wireless Router
My Belkin router loses strength when I go from the 2nd floor where it is located down to the 1st floor of my houses and sometimes loses connection. What can I do?
Hi i would be glad to assist to jus folow the steps
Click the below links to go to download the firmware
http://www.belkin.com/support/article/?lid=en&pid=f5d5231-4&aid=5128&scid=220
once you download the firmware i have given you the instructions to update in your router
Upgrading the router's firmware
The following steps show you how to update your routers firmware using its web interface. You do not need to be connected to the Internet as this interface is built into the router itself.
Setup Steps
  1. Download the firmware from the above link
  2. Save the file to a location on your computer where you can get to it easily, such as your desktop.
  3. Connect the computer to one of the four LAN ports on the router.
  4. Open a web browser on the computer.
  5. In the address bar of the web browser, type http://192.168.2.1 and press Enter on your keyboard.
  6. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  7. Click on "Firmware Update" toward the bottom of the left-hand menu.
  8. Click the Browse button toward the middle of the screen to search for the file you saved previously.
    Note: The firmware version in the images below is depicted as an example. Your file name will vary depending on your model and version.
  9. Select the firmware file by left-clicking on it and then click the Open button in the lower right corner of the window. This will take you back into the router's interface.
  10. Click the Update button.
  11. A prompt asking, "Are you sure you want to continue with upgrading?" will appear. Click OK.
  12. A second prompt will open telling you the router will not respond during the upgrade and warning you not to remove the power supply to the router. Click OK once more.
  13. Congratulations. The firmware has been updated successfully.
14.once firmware updated on the left under Utilites ->Restore factory Defaults this would give you a Good Connection
Thank you
Jan 08, 2011 | Belkin (F5D5231-4) Router
I'm new in the line of using Archos. I was trying to register it when it indicate a new update available. I did ACCEPT to download the update. Now my Archos 5 is not coming up. Can you please help with...
Hi,to solve your problem please follow the instructions .
Hold down the volume button and the power button for several seconds the ARCHOS goes into a restore type mode.
connect the archos to your computer with the usb cable .next copy and paste the downlaoded firmware .aos file onto the aarchos device .
your archos device will be detected as a mobile device in windows explorer.double-click on the device to see its "internal hard driver.open this internal hard driver icon and you will see the various archos folder inside..paste the update file into this area but be careful not to paste it into any of folders there.
the device will recognize the new update file and invite you to install it.Follow the on-screen instructions.
To download the firmware navigate to this link click HERE
To the firmware ..select your product ..and then click on Download Archos 5 Internet Tablet OS v 2.0.38 (92054Kb) .
Save it to your desktop .
Dec 26, 2010 | Vacuums
5.40 firmware upgrade for model bdp-s300 doesnt finish
I suggest that you install the latest firmware update to resolve the issue. Please click the following link to download the latest firmware update.
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=6170&mdl=BDPS300
The link contains the 5.5 update and it includes the functions providing the 5.4 update. Hence it is not required to install 5.4 before installing the 5.5.
It is recommended to use CD -R disc to create the firmware update disc. I hope you're clear with downloading the update from support page. Once you download and save the file in the folder in the computer, you can double click the file to extract. You will be prompted to save the UPDATE_BDPS300_VER0550.ISO file in a folder. Most of the customers will be making mistake here after... We need to use a burning software which is capable to burning discs from ISO images. ISO image is nothing but a RAW format of burned image. I will give you the instructions to burn using Nero.. Steps will be almost same in all ISO capable software. Open installed nero software from computer. You may locate it under Start Menu programs. Go to File Menu (Some times you will get a wizard where you can select the Image Burning option or burn ISO option) Navigate the extracted .ISO file we saved in the computer. follow the onscreen instructions. Insert the disc when ever Nero asked to insert Hope this helps. If you need any assistance. Please get back to me. I will be more than happy to assist you. Thanks for understanding.
Oct 03, 2010 | Sony BDP-S300 Blu-Ray Disc Player
Please need to find where to download firmware upgrade for the bd-hp21x as it will not play some new blu rays ?? was told to download upgrade and burn to dvd and should fix ?? but cannot locate the...
Follow this step by step guide to download the firmware:
  1. Click here to visit the support page for your player. The following page should open: dbe7eb4.jpg
  2. Click on the "Attachments" tab:9a8a0d3.jpg
  3. Then click on "Software & Drivers" and then on "Go":c072d01.jpg
  4. After that the link for firmware download will appear:eb47827.jpg
  5. After accepting the agreement, download will start. Save this file and update it according to the instructions. If you do not know how to upgrade, just post it as a question and I'll try to provide instructions for that as well.
If you find this helpful, don't forget to rate.
Dec 20, 2009 | Sharp AQUOS Blu-ray Disc Player
Firmware update for netgear router
I was having the same issues too. I followed the steps dotted all over the internet and was getting stuck in exactly the same place. No matter how hard I tried, I just kept getting the 'invalid filename' issue.
Eventually I figured it out - the way that Netgear/Virgin have blocked firmware updating is to break the filename checking page so it doesn't accept any files. What we need to do is bypass the filename checking code so that the firmware upgrade system can then handle the file, and we're going to do this by manipulating the web page using a tool called Firebug.
Here is the solution:
1) If you haven't already got it, install Mozilla Firefox 3 (there is good reason for this - I'm not just shamelessly plugging it! :P).
2) Install the 'Firebug' extension for Firefox from https://addons.mozilla.org/en-US/firefox/addon/1843 and restart your browser when requested.
3) Navigate to your router's admin page, and fill in your login details (if you don't know them, it's likely to be the one written on the bottom of your router).
4) Navigate to the router upgrade page (the one where you select the firmware to upload' and select the location of the firmware file, like you would normally. Now, instead of clicking the 'Upload' button, press F12. This should bring up Firebug in the bottom quarter of your screen.
5) Now, click the moz-screenshot.png2193448.jpgbutton at the top of the Firebug panel and then click on the 'Upload' button. This will bring up the code for the upload button, where it does the filename checking. It'll look like this:
6) It looks like Netgear have actually stripped out the real checking code so it can't be used, so we'll need to fool the page into thinking everything's fine and dandy with the filename so it can update the firmware. Click where it says "return checkData();" and replace it with "return true;".
7) Finally, click the upload button. The router should now accept the file and start updating.
And hey presto! You have a non-nargled wireless router with the latest firmware!
Mar 13, 2009 | NetGear WGR614 Wireless Router
Zen touch stuck in recovery mode and with no firmware the firmware update states that the player is not connecte
Step 1:
The Zen V Plus is an MP3 player that can play music and videos; you can also view pictures and listen to FM radio. Often, MP3 devices require upgrades. Firmware upgrades to the Zen V Plus fix bugs and sometimes upgrade the user interface, which can enhance your user experience and correct problems. You can upgrade your Creative Zen V Plus to version 1.32.01 through the Creative website.
Open your web browser and navigate the Zen V Plus support page (See Below). Click here > h Click "Download" under "Firmware" and choose to "Save" it to your computer. Connect your Zen to the computer using the Zen USB cable. Double-click the file that was downloaded to your computer to start the installation process. Agree to the terms and wait for the files to be transferred and installed onto your Zen.
http://support.creative.com/downloads/welcome.aspx?nDriverType=4 - type_4
Jul 21, 2008 | Audio Players & Recorders
Open Questions:
Computers & Internet Logo
964 people viewed this question
David Payne
David Payne
