Question about Kenmore Refrigerators
Frigerator will not cool , freezer operates, coils cleaned, fan operating
On line diagram of frig and concluded that it was the upper fan (motor) in the freezer. Air was not being transferred to the bottom portion of the frig.
Posted on Sep 06, 2009
The fridge side of my ge reg is not working
The first thing you want to do is check the freezer side to see if you can hear the fan running. This fan circulates air from the freezer over to the fresh food side to cool it. If its not running then your fan is bad, but if it is then look at the freezer wall to see if you see a frost build up. If so your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute.
May 14, 2012 | GE Refrigerators
My side by side refrigerator and freezer is not keeping cooling temperatures. Freezer had frost in ice dispenser, then began dripping water-had a few ice-sicles and then noticed food defrosting and...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
uiot45
Apr 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
IT WILL NOT COOL OR FREEZE, DIGITALPANEL IS SHOWING 52 TOP AND 39 IN FREEZER. FANS ARE GOING BUT NO COOL AIR NOR IS THE FRIGERATOR RUNNING. ECH SAYS NEW COMPUTER BOARD IS NEEDED IS THIS TRUE?
I was having the same problem .What I found was the coils were dirty and needed to be clean also the overload relay switch and the capacitor were bad.The overload relay and capacitor are next to the compressor. Replace them and you should be cool again.
Mar 05, 2010 | KitchenAid Architect KBFA20ERSS Stainless...
What is proper operating temp of freezer/refrigerator?
0-5 F in the freezer.36-42F in fresh food.
Check for ice buildup on the back wall of the freezer. Check the freezer fan motor. Check the compressor fan motor.
Sep 06, 2009 | Kenmore Refrigerators
Both Freezer & Fridge compartments not cooling
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath. If that don't work you may be low on freon change fan motor
Aug 12, 2009 | Refrigerators
MSD2756GEB (Side By Side) Runs All the time
I went to the Maytag site and found a similar QA area and found a short article that talked about frost build up and/or blockage of any sort preventing airflow from the freezer compartment to the refrigerator compartment. They said this would impact proper operation of the refrigerator.
I emptied out the freezer after I inspected and found significant frost/ice in the upper right hand corner around the "scoop" that directs airflow into the refrigerator compartment. I took that off and removed all the ice build up (almost 1/2 blockage). I then removed the entire back panel and noticed that my refrigeration unit was completely iced up with significant build up around all the wires and thermostat.
I defrosted the entire unit with the aid of a hairdryer (at a safe distance so not to over heat anything) and then made sure my evaporator coils were all clean in the back and turned the refrigerator back on. (I unplugged it during the defrost operation.) I made sure that the fans worked both above the interior refrigeration unit and at the evaporator unit. Then I waited for the compressor to kick on.
Wallah! Everything so far was working so I put the rear panel back together in the freezer section, closed her up and waited to see what would happen. So far I've had to turn down the refrigerator section to around 5 and the freezer to about 4. The unit now seems to run correctly, shutting off after it runs for a while.
So I guess I'll wait and see how long this defrosting step works. Maybe the self defrost switch or something is not working and the problem will return in a month or so. We'll see..............
Feb 13, 2009 | Maytag MSD2756G Side by Side Refrigerator
Kenmore 253.717941OC Top Freezer - freezer okday, frigerator inop
The missing fan noise is the clue; the fan that is responsible for circulating air between the two chambers has failed. Both may have cooling coils but a fan is responsible for balancing the temperature between the two and is even more important if the coils are exclusively located in the freezer chamber.
Unless it is still under warranty, it isn't necessary to wait on Sears service since they are independent contractors anyhow.
If you are in the US, check your local Better Business Bureau website to find a reliable service company. I'd bet you can find one much earlier than next month.
Sep 25, 2008 | Kenmore 73662 Top Freezer Refrigerator
My frigerator
This will get warm. If very hot check and clean coils in front, underneath. Also check fan behind rear panel. It should be turning when the unit is running. Also check for door not closing properly.
Nov 12, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
89 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
