Question about Nokia N95 Cellular Phone
I have n95, i have disply problem.. on the lower part of disply i found 10-15 thin lining .. please tell me how to solve this
How to correct error code 4 in 10 on Sharp pocket computer pc-1270
I found the answer for the PC1500, and I'm guessing the error codes for the PC1270 will be similar. Here is what the manual says:
This error occurs when there is no DATA corresponding to a READ command, for example:
10 READ X, Y
20 DATA 10
30 END
The display will say, "ERROR 4 IN 10"
The solution is to provide enough DATA to satisfy the READ. For example, change line 20 to read as follows:
20 DATA 10,15
Hope this helps.
May 04, 2017 | Sharp Office Equipment & Supplies
My system has zx i945 lm4 v1.12 mother board 10 or 15 minuts after windows opening it displys vivid verticle green lines then i restart cpu on but no disply in moniter what is the problem?
It looks like your onboard graphics chip has failed. Motherboard replacement is the only way to repair it(Unless you are an electronics engineer.)
Sep 05, 2012 | Computers & Internet
I have nokia 6681 yesterday a line start in disply now i can see that ling in disply from left to right. What i do????
hi,
This may be a problem with display. go to the service center. u will get your problem solved.
Aug 09, 2011 | Nokia Lands Phones
Brown streaks on my clothes after washing them
O.K. Here it is, I solved it. After calling whirlpool who was of no help at all, reading all links about the Duet washer and/or the Duet dryer, I finally solved the problem myself. I too, thought it was the washer but, upon close inspection, found the felt on the dryer had worn out in one spot. The thin brown lines always showed up on whites and more so on anything very thin. I took the dryer apart and found a small burn line on the drum (brown and thin). I replaced the felt ($60) and used Simple Green to clean off the brown. Works perfect, no more thin brown lines. If you can't take the dryer apart, I called for repair and found the price with parts to average $250.
I was ready to sell the darn thing after it ruined about $300 worth of clothes. All in all, it's been three weeks and still working fine.
May 19, 2010 | Washing Machines
Nokia n95 8gb no disply but lights ok
go to a mobile service.the connectors from the display are gone or they moved
Sep 02, 2009 | Nokia N95 Cellular Phone
Not disply HD videos
Friend if your video card has lower memory or capacity especially 256 ram below then you need to upgrade or replace your video card with the higher one. then if it is already above then try to upgrade or update you software on line.
Jul 07, 2009 | Intel Desktop Board D845GLVA...
N95 lcd problem and key pad. lcd is belu and no disply
The most common trouble for this, is the FLEX since it's slide type, most likely broken!!!
FLEX - a ribbon type wire, connecting LCD board and the main board of the unit.
Just replace the Flex with extra care. Good luck!!! Nomde....
Apr 08, 2009 | Nokia N95 Cellular Phone
Puk code for nokia N95
You can get your PUK Code from your service provider. Should be a quick call after they verify your account info. Unfortunately there is not DEFAULT PUK Code and provider is the only one that can tell you what your SIM PUK was set to.
Please don't forget to mark if this solution solved your issue.
Nov 24, 2008 | Nokia N95 Cellular Phone
N95 8GB unlock problem
ok i have read your prblem you should go to the software shope and replace your mobiles software thats it.if not solve the tell me again
Aug 30, 2008 | Nokia N95 Cellular Phone
Problem with Nokia N 95
to solve your problem go to any cellphone shop near you ask them if they reprogram N95 latest ver12.0.14 so it will work agian, don't try to reprogram it to lower version it wil not work unless they have a software that can downgrade N95. ok
peace!
Nov 26, 2007 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
