Question about Kenwood Car Audio & Video
Green light (protection mode) on, NO red light (ready)
I have an Kenwood PS300T amp with 2 10'' MTX subs in truck boxes. Everything is hooked up right but iot does shake the truck like it should plus the green light (protection mode) is on. when you first turn it on the red light comes on for a couple seconds then switchs to green. Whats the deal?
  • 4 Answers
Double check your wires aren't shorting out or power or remote wires aren't grounding. check if speakers are blown with nine volt battery
Posted on Sep 05, 2009
Kenwood amp red light
Red triangle is kenwood power light. Check rcas
Sep 24, 2017 | Car Audio & Video
Tc 8001 red light
on some amps there is a duel light. red and green usually. red means it is in protect mode or you didn't hook up your remote wire. if in protect mode, it could mean a number of things. did you hook it up with speakers and everything?
Mar 01, 2012 | MTX Thunder® TC8001 Car Amp
I have a sony deck with a 200 terminatorand 2 legacy 12" subs. i hook everything up an when i hook up the remote wire the light turns from green to red an it whistles the subs **** up.
Your giving a wrong load / Ohms impediance to your amplifier.
What are the specifications of your subwoofer? Is it SVC 4ohms or DVC 4ohms or DVC 2ohms? Whats the specs of your amplifier?
Apr 08, 2011 | MTX Terminator TN200/2 Car Amp
My amp will go into protection mode when i turn my truck on, it flashes green and beats once,then turnd protection mode on... whats wrong with it??
im not sure what is wrong but i do know if you keep it hooked to subs it will fry them because that happened to my friends jackhammer amp and 2 12" mtx jackhammers
Mar 10, 2010 | Fusion FEW12PK Car Subwoofer
My subs/amp are not working
when you car is running, it charges the battery somewhat. So the voltage problem is not a problem. The red light means the amp is going into ''Protect Mode". This usually happens when something is wrong with the amp. Usually the amp is getting hot. Check all of you connectiong and check the final impedance of the subs. Make sure the amp can handle the impedance of the subs. If you need anymore help, message me.
Feb 12, 2010 | Kenwood Excelon KAC-X621 Car Audio...
My red light on my amp is on and wont go out
Unfortunately I think you need to get it repaired or replaced .When a protection light will not turn off it is generally caused by an internal short and needs one or more replacement parts for it to come alive again.
-Dynami
Apr 03, 2009 | Insignia 600W Bridgeable Amplifier with...
Kenwood kac-7202
Nope it's not a high-to-low level converter problem, it's most likely a problem with one of two things. 1) either you've blown the output stage in the amplifier, or 2) you've hooked up your subs wrong and your amp is seeing to low of an impedance. The amp is supposed to be 1ohm stable, but we had the same problem. When the indicator light goes red it means that the amp has gone into protection mode, now you have to figure out why. If something in the amp goes bad or just disconnects from the board it will cause power protection mode. If you fry something on the board because you are running the amp to hard or at the wrong impedance it will go into thermal protection mode, however there's no simple way to figure out which has happened.
Have you tried hooking up some different subs to see if the problem remains? try this. If the problem no longer happens then you know it's your subs, if it does still happen then you'll know it's an internal problem.
Years ago I had a Kenwood KAC-821; long story short, I melted the main power wire right off of the board, everytime I turned the system up the amp would shut down.
Take you amp to an authorized dealer and have them bench test it for you.
Let me know what you find out.
Jul 14, 2008 | Kenwood KAC-7202 Car Audio Amplifier
I have a dub 4001 amp
Take it step wise.
Unplug the inputs and outputs from the amp (be sure to mark the wires so you can hook them back up), leaving only the ground, +12, and remote wire hooked up. Now, turn it on. If the amp light goes red, the amp is broken. If it goes green, turn if off, plug in the speakers, then turn it on. if it's red, its a speaker problem, if green, do the same with the inputs, and you'll have your answer.
Jan 22, 2008 | AudioBahn DUB Mag Audio DUB4001 Car Audio...
Car audio
hi, your amp seems to be getting power but the cables might be wrong so it's not getting enough power. the light on the amp should be green if everything is going well. are you sure the cables are suitable for your amp?
Sep 11, 2007 | MTX RT202 Car Audio Amplifier
Car Audio & Video Logo
279 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
