York Yankees Bedding MLB Comforter
Problem for York Yankees Bedding MLB Comforter
York Heat Pump outdoor cutoff thermostat wiring.
By d_reed227 on Sep 05, 2009
I have a fairly old York heat pump, model # E1RC030S06A, serial # EEEM176773 that I want to wire an outdoor temp cutoff thermostat into. The wiring diagram on the access door is faded and not readable. The outdoor thermostat is a White-Rodgers type 2B61-186. Can this be wired into the outside unit and how is that done? Does it have to be installed in the outside unit and wired into the air handler with the heat strips? Should I call a professional to do the job?
According to what I have read, some heat pumps can be wired for the cutoff thermostat and some can not. Any advice will be helpful. Thanks.
Best Solution
posted on Sep 17, 2009
Helpful)
hvactrey
Rank: Master
Rating: 95%, 2 votes
You should call a professional in on this one you can damage alot of expensive parts trying to do this on your own without the proper tools and knowledge of the control logic
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" OK...that's what I thought but figured I would attempt it myself, if possible. I will call my local heat/ac guys to install the cutoff switch. Thanks! " - d_reed227
Solution #2
posted on Sep 15, 2009
Somewhat Helpful)
liteswink
Rank: Master
Rating: 75%, 2 votes
2B61-186 Remote Bulb Thermostats are designed for use on a wide variety of heating equipment and appliances, Primary operation when the temperature of the liquid or air surrounding the bulb rises, the switch contacts open to turn off the heat. When the temperature drops, the contacts close to turn on the heat.
Specification:
Switch Action: Open on rise, snap-action
Contact Structure: – S.P.S.T.
Was this helpful?
Yes
No
Popular Solutions for York Yankees Bedding MLB
Questions and Unsolved Problems for York Yankees Bedding MLB
Do you recommend York Yankees Bedding MLB Comforter?
Answer
Answer
coment passer les câbles sur le york multi max 1501 merci
Answer
i have bought a york kompact 800 second hand and don't know how to set it up.
Answer
i need instructions for a york multi gym compact 901
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For York Yankees Bedding MLB...:
Top Sport and Outdoor Experts
Rank: Guru Guru
Solutions: 746
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Sport and Outdoor Experts
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
