Question about B&W Audio Players & Recorders
B&w cc6s2 replacing tweeter
B&w CC6 S2 center channel speaker replacing tweeter
3 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: karaoke speaker,no woofer or midrange working, only tweeter
Hi, it's probably that the 8" woofer and the midrange of the "amped" enclosure is open. One way to test is to remove just one wire from the inside of the enclosure to the woofer or midrange in question and with the use of a continuity tester (or a VOM), check for the resistance of the coil of each the 2 speakers. Both should read anywhere from 4-8 ohms, if there's no reading (VOM needle will not move) then the coil(s) are open. In the absence of a tester, a single AAA or AA battery would do (pls. some would argue that this is not a sound practice, however this should be enough for you to be able to determine the condition of the coil(s)). With the use of the battery and a single short length of electrical wire, apply power from the battery to the terminals of the speaker, if the cone moves, then chances are it is good, if they don't then you would have to replace it. Am not sure if available in your area, but there are some trained people who can rewind the coil should a replacement speaker be not readily available. Hope this be of help. Please let us know how things turn up. Regards.
Posted on Apr 15, 2007
SOURCE: how to connect mey speakers to the amp?
hi,i have 1000w 4 speekers but i have one amp.how do i connect to that?
Posted on Mar 22, 2009
HOW TO SWAP OUT A TWEETER ON DM601 S2
you take tweeter out but be sure not to remove the capacitor its a small can looking piece that stops the tweeter from getting the low and medium frequency and only receives tthe high .
Mar 23, 2013 | Audio Players & Recorders
B&W DM603 S2 Speaker taking apart
i need a pair of tweeters of b&w683,where can i get them?
Apr 29, 2012 | B&W DM603 S2 Speaker
How to install spr-17s
The six 1/2 speakers are your woofers,connect the positive and negative wires from the speaker to the 2 connections labeled on the crossover as W(woofer)+ pos and W(woofer) -- neg,hook the tweeters to the crossover connections labeled T(tweeter)+ pos and T(tweeter) -- neg,then hookup the 2 remaining connections labeled Amp to your amplifier,amp must be 2 or 4 channel stereo capable and give out enough power to properly drive the speakers so they achieve optimal performance.
Mar 05, 2011 | Alpine SPR-17S Car Speaker
Hi, I hope you can help me. I have had the tweeters stop working on two B&W CC6 speakers that I have purchased on ebay. One is Series 1 speaker and the other is a Series 2. I would like to replace...
tweeter burn out is primarely due to too much power input not so much from load music but the amp may be putting out far more than 8 ohms / replace the speakers but install a little device called a polly switch protector they work like a fuse if there is too much power they open and dont allow harmfull power to burn out the coils then when the power reduces they close turning the speakers back on
look them up on the net any goo speaker retailor will know what they are and were to get then they cost about $ 2 lots of money ay makes you wonder why there not stock standered on all speaker enclose ,
merry christmas
please take time to rank this advice
Dec 22, 2010 | B&W CC6 S2 Speaker
Channel 2 crackles
Make sure your speaker wiring does not come close to the 12v power cable running for your amplifier. If your amplifier's 12v power cable runs on the drivers side of the vehicle, run your speaker cables on the passengers side and make sure your tweeters have a high pass filter to stop any pickup of engine sound (When you are driving you *WILL* notice it at high RPM. a HPF (High Pass Filter) will also stop those nasty hissing sounds on S's.
Feb 11, 2009 | Alpine PDX-4.100 Car Audio Amplifier
Center channel sound output
Its not working correctly I have a few different types of center channels and they all have equal sound no matter how many speakers are in them. Connection in speaker box is bad or you may have a blown speaker
Dec 31, 2008 | Pioneer VSX-455 Receiver
Problem with philips Powerhouse AW626 music System
try to invert your speakers cables and connect your right speaker cable to left output if the problem still happened you will have a problem in your amp and ask for help from good service center near you-------if the problem disappear you will have a problem in left channel----cable or speaker.
Jun 03, 2008 | Audio Players & Recorders
184 people viewed this question
Top B&W Audio Players & Recorders Experts
Andrew Taylor
Andrew Taylor
Are you a B&W Audio Player and Recorder Expert? Answer questions, earn points and help others
