Question about Maytag Clothes Dryer Almond Timer Knob Insert
Maytag Gas Dryer Dial-Timer problem
The dial on my Maytag dryer is not working. This particular dryer has 3 settings. The timed setting (which does work), the permanent press setting which goes from more dry to less dry, and the regular fabrics setting, which also starts at more dry and ends at less dry, then off. The latter 2 settings do not count down, meaning the dryer dial stays at more dry and does not move, at all. What is the remedy to this problem?
Yozzer6821
  • 116 Answers
SOURCE: Maytag DE 412
Does sound like the timer, although the clock is moving, the contact for the heater element is burned out inside the timer, you probably have used this timed dry for your normal day to day use and worn out the contact, new timer required.
Posted on Jun 01, 2008
SOURCE: Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Posted on Jul 13, 2008
futureloginn
  • 734 Answers
SOURCE: Dryer knob sticks in one spot- won't move
 Door switch / Door switch actuator leverThe dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Posted on Dec 02, 2008
SOURCE: Maytag Neptune gas dryer sense dry time at 99, little or no heat
If this is a gas dryer, I'd suggest an inspection by the gas company or qualified technician. If the jets aren't firing correctly, you are wasting gas and possibly creating a hazard.
Posted on Mar 21, 2009
TheMobilian
  • 8220 Answers
SOURCE: dryer won't start
Might be a bad motor, locked rollers/ idler, or worn out glides pinching the drumd43e4a0.jpg
Posted on May 24, 2010
Gas dryer dries sporadically. dial for automatic dry doesn't move
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ...Replaced outlet, cord, and moved the outlet so we don't have the same ... Whirlpool LER4634EQ0 110 v timer motor, when timer contacts TM .... David Villa 7 months ago ... 3 years and now thedryer won't heat and the timer doesn't advance, ...Missing: cu
Nov 17, 2015 | Whirlpool Dryer. Gas Dryer. 7.0 cu. ft. in...
My Maytag Neptune dryer doesn't stop unless I open the dryer door.
You will be needing to replace the timer assembly, which is the part that has all the wires attached and is found inside the top of the machine. It is what the dial is fastened to.
Be blessed.
Jan 08, 2014 | Maytag Neptune MDG5500AW Gas Dryer
Lpg conversion
cover dial settings?
Sep 19, 2013 | Maytag Dryers
Dryer is working but does not turn off, when it reaches OFF. It goes passed it. No matter where the dial is set, even the timer section, the dial goes passed the OFF marker.
This model does not have a timer, so what model do you have? This is a electronic panel with push buttons. Is the unit still heating when this happens, or is it just running like anti-winkle (air fluff) setting?
Good Luck
Aug 28, 2011 | Maytag Neptune MDG5500AW Gas Dryer
My maytag dependable care plus electric dryer doesn't shut off
Does the timer move when it's almost ready to shut off if not most likely need a timer. Can you turn it by hand to finish the cycle and shut it off. If not must be timer.
Hope this helps
Apr 24, 2010 | Maytag MDG7600AW Gas Dryer
It takes hours to dry the clothes. The dial moves
sounds like a bad timer. if it sticks every time replace they are expensive
Mar 25, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Maytag Clothes Dryer Almond Timer Knob Insert Logo
258 people viewed this question
Top Maytag Hardware & Accessories Experts
Hippy_dd
ray gallant
Are you a Maytag Hardware and Accessory Expert? Answer questions, earn points and help others
