I get a clicking noise when I print on a Dell 3115
  • kurtcostanti Sep 05, 2009
    The printer does print okay- it just making a clicking noise
  • 13,433 Answers
The print cartridge carrier could be stuck and clicking agains the wall or gears might be clicking.
If your machine doesn't work at all, open the cartridge cover, take the cartridges out, close the cover, wait for it to call the carriage carrier to the side, then turn it off, unplug wait 2 minutes, plug it back in, turn it on, open the cover, install the cartridges back, close the cover and try printing again.
If that doesn't solve the problem follow these steps
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
If the problem still remains
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
After you have done all the suggestions, whats the status of your printer, are you still unable to print? is the printer still just clicking? are you able to remove the cartridges from the machine or is it just clicking?
If your not able to do the suggestions or the cartridges won't come to the center, your printer has a mechanical hardware problem that will require service.
Posted on Sep 05, 2009
  • Ekse Sep 05, 2009
    Oh, my printer clicks now and then aswell, if it works, then its noting to worry about.
Dell 3115 printer is printing very slowly how to solve it?
Get an updated driver for it from Dell's website.
Apr 15, 2017 | Dell Cell Phones
Removal of paper stuck in a dell 3115 fuser?
It's best to remove the fuser to get access to it. This video will show you how to remove it, and which levers to move to release tension in the pinch roller to clear the jam http://www.youtube.com/watch?v=UjyggtF8d1k After you remove the jam make sure to do a close inspection on the internal roller (use a flashlight). You're looking for any scratches or "dents" in the colored roller (sometimes a deep red/brown color sometimes blue) if there are scratches you are probably going to have to replace the fuser. The imperfections on the fuser roller will show up on your printed pages. If you do need a new fuser you can find them for $160, or the entire rebuild maintenance kit for $375 http://www.fastprinters.com/productdetails.asp?PRODUCT_ID=DELL-UG190
Dec 19, 2013 | Dell Printers:Dell MFP Color Laser 3115cn
Dell 3115 manual feed doesn't work
If this printer is a few years old on the load paper tray there is 2 grey rubber rings they get a flat spot on them. replace and no paper problem till the next time they wear out
May 25, 2012 | Dell 3100cn Laser Printer
Dell 3110 laserjet printer, belt unit close to life
This message is displayed when the pagecount of the transfer belt is 80,000 (ish)+.
The rated life of the transfer belt in the Dell 3110/3115 is 100,000 pages.
After that pagecount the transfer belt 'expires' and no further printing is possible until the transfer belt is replaced.
Feb 03, 2011 | Dell 3110cn Laser Printer
Manual for ipaq 3115
Go to this site, it is HP's site. click on the one you want. there is one for warrenties, and user guides. CLICK HERE
Sep 29, 2009 | Tablets & eReaders
Dell color laser duplex 3115 cn will not print on both sides of paper.
Mascmen7,
although I would still like you to let me know the service tag ( so I can check on your warranty ), I am going to take a stab at what I think you are having a problem with.
I have had several customers that have had difficulty with their Dell printers when in fact there was no hardware defect at all, but simply that the options were not set in their Driver.
One customer couldnt print from tray 2 because tray 2 was not "installed" in the driver.
See the image below. If you go to control panel and then printers and faxes, right click on your printer and then select properties. ( see image )
the last tab ( and i know it isn't easy to see here ) is marked as options.
Click there, and then make sure that the duplexer is either "available" as shown in the above driver properties window, or on some Dell printers, it actually shows a list on the left and the available options on the right. If this is the case for you, simply highlight the duplexer and "add" to move it to the columb on the right.
You would think that just installing the print driver would also insure the printer was added as configured, but sometimes it does not.
Let me know how you make out.
Cory
Nov 07, 2008 | Office Equipment & Supplies
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
