Question about Konica Minolta Dynax 5D / Maxxum 5D Body only Digital Camera
My camera will turn on but will not take pics (shutter won't release)and if I leave it on without activity the red light comes on
    President:
  • 2,761 Answers
Your problem may be due to a buildup of corrosion on the battery contacts inside the camera preventing full battery power from flowing into the camera. Remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during the cleaning, then wipe both ends of the batteries and reinsert them into the camera. This cures the problem about 90% of the time, and I hope it works for you.
Posted on Sep 19, 2009
My canon eos 600d won't take pics anymore is there a lock or something that could be released
Are you getting an error message or any other indication from the camera? Have you checked the memory card to see whether it's write-protected? What exposure mode(s)? What shutter release mode(s)?
Mar 19, 2013 | Canon EOS 600D Rebel T3i Digital Camera
My 645 1000s shutter buttons wont pop back up.this is my 1st mamiya
You might want to check and make sure the battery is still good. If you purchased the camera used and didn't change the battery then this might be the case.
But in the mean time this is what you need to do:
1st-make sure that the shutter speed dial is set to any shutter speed other than the red circle w/red ring. If your camera is set to that it will drain your battery when not in use since it is designed to be an automatic setting. I set mine to 1/125th to do this push in the circular dial on the side and at the same time turn the knob.
2nd- locate the 2 levers on the opposite side of the shutter speed dial. Once you found them then position the back lever all the way forward towards the setting for "MULTI" and position the lever towards the front straight up.
3rd- then wind the film crank till it won't wind anymore and depress the shutter, if it is wound and the shutter release is still stuck then skip to the fourth step, if something happened and you heard a click then still proceed to the next step because no the shutter release will be temporarily stuck.
4th-Once both of these levers are in this position there should be a red button just behind the shutter release button on the top right side of the camera.... drum roll please...."Push the red button" what you should hear is a rather loud click, this click is the mirror releasing allowing you to: 1 wind the film crank and take another picture and 2 this also now allows you to see through the lens again (assuming that you have a lens on the camera).
In Conclusion: without a battery that is fully functional in the camera this is how the camera will operate once you get a battery for your camera then reposition the levers on the side of the camera opposite of what I suggested (this will be the normal operating mode for the camera with a battery) then when you wind the film crank and depress the shutter everything will function normally.
Jul 12, 2011 | Mamiya Photography
Pentax K110d flash trigger problem, I have 2 flash trigger strobes set up and a flash on the hot shoe of the camera, but with shutter release the trigger strobe lights fire but do not show in the pic, only...
Your camera uses a PTTL flash system. That means the flash on the camera fires a "pre-flash" to set the exposure and then the main flash. Your flash trigger strobes are reacting to the pre-flash and firing before the shutter activates. This all happens in a millisecond.
Oct 25, 2010 | Pentax K110D Digital Camera
How do you turn on a sigma SA-7n film camera??
I don't know about the SA-7, but the SA-5 doesn't have an on/off switch as such. Pressing the shutter button halfway activates the autofocus and turns on the light meter. The camera switches off after six seconds of inactivity to conserve batteries, though the shutter can still be released accidentally. Turning the mode dial to the "L" position will lock the shutter and prevent accidental release.
You can find a manual for the SA-5 at http://www.butkus.org/chinon/sigma.htm . It's not ideal, but it should help you get started.
Dec 25, 2009 | Sigma SA-7 35mm SLR Camera
I have M1033 - when the shutter button is pressed half way down it wont focus and shows a red AF on screen. The pics are blurred. Batteries have been changed and lens cleaned.Help please
The red AF is autofocus. If it is red it isn't focused. You will have to hold the button until the red light turns green, then release the button.
Jul 08, 2009 | Kodak EasyShare M1033 - black Digital...
Olympus 1050 SW completely unresponsive to any button
the lens may be stuck ... that is not coming out or not returning in either condition causes it to do something like that ,i.e blingink red light or an error code etc .... solution is that you'll need to open up the camera with a set of precission screw drivers and manually turn in or out the lens to start it back in operation either ways its a bit technical if you never did it before ....could be caused by moisture getting into the camera .....
May 19, 2009 | Olympus Stylus / mju 1050 SW Digital...
Nikon CoolPix S5. Red flashing hand. Camera/Lens on/open.
If the shutter is stucked there is no external way to release it Have to show it at camera shop
Mar 15, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
LCD Display
I was cleaning my CCD and damaged the shutter. Same problem. Click to take a picture and the camera locks up and powers off. Turn the camera back on and the shutter releases and the camera resets and powers on. $281 service call later and Precision fixed it quickly. Replaced the shutter. They warranty their work for 6 months. Priced way too high, but nobody would touch it. As soon as I told other repair services how I messed it up, they turned me down. I had to much money invested in the camera to toss it in the closet.
Nov 24, 2007 | Konica Minolta Maxxum 7D / Dynax 7D...
What am I doing wrong?
This depends on which Autofocus system that particular model uses.  Then manual should tell what is happening there- there is usually a more comprehensive manual on the supplied CD.
Failing that speak to the user support of you particular model
Oct 25, 2007 | GE E1040 Digital Camera
Konica Minolta Dynax 5D / Maxxum 5D Body only Digital Camera Logo
270 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
