Question about Kenmore 22422 Top Load Washer
Whirlpool top loader: very loud pumping sounds when filling
I have a brand new Whirlpool top loader with ATC (Automatic Temperature Control). (WTW5300VW model) When it fills with water, it pumps on and off, like pushing your foot on and off the accelerator. THis action makes quite a bit of noise and knocking sounds. It is so loud, it really can't be normal. Could it be due to the metal hoses I had them install ? (these metal hoses seem narrower than the old rubber ones, and are quite long) It happens only when it is filling to wash (on HOT or WARM, I haven't tried a cold wash). It does not do this during the rinse cycle (which is cold water).
If it is the ATC, can it be disabled?
  • Kenmore Master
  • 3,361 Answers
You are experiencing surge pressure due to the ATC. It is increasing then reducing the hot water slow to maintain a pre-determined temperature.
I am not aware of a disable or bypass procedure.
Posted on Sep 05, 2009
  • steve
    steve Sep 05, 2009
    I need to amend the above post.
    On your temp control,if you de-select the ACCU-Wash cycle you will not be mixing water and should stop the surging.
How to diagnose a non functing Automatic Temperature Control (ATC)
that will be a dealer service issue.. they can assist with this one..
Dec 23, 2013 | 1994 Chrysler Concorde
Leaks as soon as it begins to fill
Could be several problems first off is bad center tub seal. Possibility of bad pump they are plastic and sometimes develop cracks. Could have hole in hose or possibly crack in water fill valve. Some models have the automatic temperature control function and they have extra hoses and valves for filling to exact temps they could be cracked as well.
Oct 26, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Brand new roper washing machine model # RTW4440VQ2 the cold water is very slow filling hot is fine
This model of washer has something called an Automatic Temperature Control. This means the washer puts water into the tub at specific tempreatures instead of just 100% cold, or 100% hot. Be sure and check that the hot and cold fill hoses are connected to the proper places on the back of the washer. It's possible that the ATC (mentioned above) is causing the washer to fill slowly on the cold setting.
May 20, 2010 | Washing Machines
Only hot water will fill, cold water will not
If it is equipped with ATC automatic temp control turn it off and see if if you can get cold if so its the ATC sensor
Sep 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
The car keeps coming up a code 23 on a 1999 chrysler 300 for the
Code 23= Blend door feedback control
On cars with automatic climate control: To enter diagnostic mode, set the temperature to 75F, press the the off button. Press Floor, Defrost\Floor, Front Defrost simutaneously for 3 seconds until the temperature display begins to flash.
On cars without automatic climate control, set the blower to any speed, turn the temperature control in between warm and cold. Press Floor, Defrost\Floor, and Front Defrost. All codes will flash via the Front Defrost button.
When the test is over all fault codes will be displayed (on cars without automatic climate control, they will be blinked out on the Front Defrost button).
Code Action
23 Blend door feedback control
24 ATC mode door feedback failure
25 Ambient temperture sensor failure
26 ATC in-car sensor
27 Sun sensor failure
31 ATC recirculate door stall failure
32 ATC blend door failure
33 ATC mode door stall failure
34 Engine temperture sense failure
35 Evap temperature sense failure
36 ATC head command failure
Mar 23, 2009 | 1999 Chrysler 300M
Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Roper washer: Slow fill on hot setting
You can really thank the government for this- your washer has a 75/25 split valve (75 cold 25 hot--- so warm is mostly cold) which they mandated for all standard top load machines. In 2010 they are banning manufacting of all standard top loaders. The thermistor is because your machine has a ATC (automatic temperature control) system. It has a computer which monitors water temp for better laundry care. You could possibly have a repairman (this wouldnt be covered under warrany) try to retrofit a older service valve in your machine.
Jan 13, 2008 | Washing Machines
Kenmore 22422 Top Load Washer Logo
232 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
