Question about Whirlpool RBS305PD Electric Single Oven
MY WHIRLPOOL GOLD OVEN DOOR STANDS SLIGHTLY OPEN, AND WON'T STAY CLOSED ALL THE WAY UNLESS I PUT A 1/4'' SPACER BETWEEN THE DOOR AND THE FRAME ON THE HINGE SIDE.
  • trudnandy Sep 06, 2009
    THE PROBLEM IS THE OPPOSITE. IF I PUT A SPACER TO HOLD THE RIGHT HINGE OUT SLIGHTLY (I USE A COAT-HANGER TO DO THIS), THE DOOR STAYS ALL THE WAY CLOSED.
    President:
  • 497 Answers
Sounds like the hinge is bent or the entire door is warped. the spacer idea shouldnt be a problem, although you may need to buy a thicker heat strip to fit around the door for proper sealing.
Posted on Sep 06, 2009
  • Whirlpool Master
  • 19,396 Answers
Ensure that the hinges are well pushed inside the oven frame assembly. Eventually try removing the door and checking the Hinge assembly.
If the model is the one listed in title, click here to get parts and diagrams for your appliance.
Here diagrams:
Click on the diagrams to enlarge picture.
Posted on Sep 05, 2009
Door is locked after self cleaning
Most ovens with self-clean cycles have a door lock to keep things closed when it ramps up the the extreme heat levels for cleaning. Usually, the door will stay locked until the thermostat sensor says that the oven is back down at or close to room temperature. If you just finished the cleaning cycle, you'll likely need to wait a while longer.
Nov 24, 2015 | Whirlpool Gold 30 in. Electric Convection...
Whirlpool Supercapacity 465 Oven (RF396 LXE2) Door Problem
These are the instruction on how to remove and replace the door, be sure you locate the removal pins to being able to put it back
Feb 13, 2008 | Whirlpool RBS275PD Electric Single Oven
Oven door doesnt close well
I'm not familiar with your oven but most oven doors are very similar in operation. When the door doesn't close well it's generally because the hinges have been stretched/bent when the oven door has been open. To see if this is the case, open the door fully. If it's stretched the door will open past 90 degrees (slope down instead of being horizontal). The easiest way to fix this is to bend it back. Place something as a spacer between the door and the oven on both sides (like a spanner handle or anything strong and about 8mm thick) as close to the hinge as possible. Close the door against it carefully and push the door closed. Do it a little at a time and remove the spacers and try the door each time until you are happy that it closes nicely again. It should be spring loaded closed slightly.
Aug 14, 2013 | De Dietrich DOC310 Electric Single Oven
The oven door does not close properly and stays open enough to keep the light on. Whirlpool Gold, Model GR399LX60
If it has a drop down door with hinge on either side, then only solution is to replace both door hinges, as the problem is usually due to weak door springs, and they are not adjustable.
Please rate my solution.
Thankyou.
Feb 01, 2010 | Whirlpool Ovens
I removed the range door to clean oven. Now I
NOTE: The door removal pins you inserted must still
be in both sides of the door.
1.
Grasp the door on the sides with your fingers on
the front of the door and your thumbs on the
inside surface.
2.
Rest the hinge hanger so that it is flat (at the
bottom of the hinge hanger on the bottom of the
front frame slot).
3.
Position the door with the hinge hanger slots
almost parallel to the front frame.
4.
Push up and in until the hinge hanger slots
become fastened to the range. Lower the door
and rotate it slightly from the front to the back
until the slots are fully fastened. The hinge
hanger will be close to the bottom of the front
frame slot.
5.
Pull door open about halfway and remove the
door removal pins. Save door removal pins for
future use.
6.
Close the door.
Dec 25, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
How to remove door for whirlpool oven RBS305PDB2
open the door about 1/3 of the way and lift it off the hinge pins. it helps to have two people do this. when it is time to replace it, put the hinges in that 1/3 open position and slide the door back down on.
Oct 02, 2009 | Whirlpool RBS305PD Electric Single Oven
Daughter stood on door, now it won't fully close (the light stays on). Can I/how do I tighten the hinges? Thanks
Put a broom handle between the door and frame down near the hinge. Close the door on the handle tweaking it to where it will shut all propah. my friend. Good question you should run it by the pros at appliancejunk.com or fixitnow.com
Aug 29, 2009 | Whirlpool RBS305PD Electric Single Oven
KEBS208DSS6 doors wont close compleat
Place a hammer handle between the door and the frame at the hinge location.
Carefully apply pressure on the door to push the door closed.
This will often re-set range door hinges.
Mar 08, 2009 | KitchenAid KEBC208 Electric Double Oven
Oven door stays open
Hi , the oven dorr needs ajustment , lose some attachement bolts ,then close the clearance will shut , so open gently and tightened the bolts.
Jan 06, 2008 | Whirlpool GBD307PDS Electric Double Oven
Oven door stays slightly open
The unit may be out of plumb ( square to the floor ). I suggest you get a level and make sure the stove/oven is level and if it's not, there are some levelers ( where legs would be on the bottom ) that can be adjusted with needle nose pliers or a cresent wrench. If this doesn'e work, you may have some hinges sprung and need to replace them. Good Luck
Ed
NC Electronic
Mills, Wyoming
Whirlpool RBS305PD Electric Single Oven Logo
193 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
