Question about Garden
How do I change the drive belt on cub cadet 1042
The above
  • susandbeau Sep 10, 2009
    thanks, everything went as you directed. question, does the bottom engine pulley [for belt to deck] turn by hand [hard] or do I need to tighten bolt tighter. thanks
    susanandbeau@yahoo.com
    thanks, great advice
    President:
  • 1,723 Answers
Go to this web site and you can get the manual that shows step by step instructions to change the belt.
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10051
Posted on Sep 05, 2009
  • Craig Butler
    Craig Butler Sep 10, 2009
    Do not over tighten. It could load the bearing in the pulley. It will turn by hand, just make sure it is tight and belt tension is good. The belt should deflect and inch or so when you push in on it with a finger.It is important to not over tighten any of these as it will 'pre load' the bearings.
  • 430 Answers
For this, you need to remove the deck, preferably put the front wheels up on blocks or stands, unplug the PTO power (directly under the engine, which can be a pain ), use an impact wrench (you need the speed of the impact wrench because the engine will turn) and a 5/8" socket and reverse the bolt out of the PTO. If you don't have an impact wrench take a spark plug out and push rope into the hole. This will bind the cylinder and keep the drive shaft from turning. Remove rope and replace plug when finished. Battery and/or spark plug wires should be removed for this process for safety.
The PTO may be stuck on there so you may want to tap it with a hammer and a block of wood carefully to release it. Loosen old belt from tensioner pulley. Lower engine pully on drive shaft, below pully "keys". It may be difficult to remove. Spray with "PB Blaster" or similar bolt loosener spray. Remove old belt from engine pulley first, transmission pulley last. Remember how belt goes around pulleys before doing so, draw a map if needed.
You'll need to put the belt on the transmission pulley first then thread the belt up to the engine pulley. Thread your belt back through the pulleys and tensioner (make sure your spring is strong enough to tension the belt or buy a new one).
The PTO is "keyed" on the shaft. Replace bolt and washer. Torque bolt to 38-50 ft. lbs. using the rope meathod as described before. Put your deck back on and you're ready to mow again. Give yourself an hour for this one.
PTO TESTED ON MY CUB CADET LT 1042 WORK WELL BUT NOT ENGAGE .THE BELT NOT SPINNING
pto switch bad or clutch unplug switch look at plug if burn repacs switch if not clutch bad
Jun 02, 2018 | Cub Cadet Garden
Cub cadet lt1042 will not back up a small hill
When is the last time you changed out your drive belt?
Oct 02, 2014 | Cub Cadet LTX 1042 KW 42" 18HP Kawasaki...
Why is my Series 1000 LT1024 Hydrostatic Drive Cub Cadet not pulling?
In most cases the hydrostatic drives are not made by the company tractor or lawnmower.
This is in the owners manual.
Hydrostatic Transmission
The hydrostatic transmission is sealed at the factory
and is maintenance free. The fluid level cannot be
checked nor can the oil be changed. Always keep the
area around the transmission cooling fan free of grass
and debris at all times
Cub Cadet LT1024 Operator Manual
How to Change the Hydrostatic Fluid in Cub Cadet Lawn Mower
https://www.google.com/webhp?sourceid=chrome-instant&rlz=1C1GGGE_enUS385US385&ion=1&espv=2&ie=UTF-8#q=cub%20cadet%20hydrostatic%20fluid%20change
I hope that this can help. Tom
Aug 22, 2014 | Cub Cadet Garden
you need to change thr hydr fliud in the transmission and the filter
Ltx 1042
Sounds like drive belt is broken. How old is tractor? When is last time drive belt was changed?
Jul 20, 2014 | Cub Cadet LTX 1042 KW 42" 18HP Kawasaki...
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Garden Logo
112 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
