Samsung 42'' LE40S86BD WON'T WORK ON DIGITAL OR ANALOGUE BUT WILL WORK WITH SKY OR FREEVIEW BOX,IE ,IT WILL NOT WORK ON ITS OWN.ONE YEAR OLD
  • paddymac Sep 06, 2009
    Ive tried all your information including removing the back cover and checking for anything loose but no luck,maybe i will take your advice and just use the sky and freeview boxes,many thanks for your help,ps if the tuner is at fault can it be replaced,take care
  • paddymac Sep 08, 2009
    I might just use the sky box to watch the tv as it might be out of my depth,someone said that if you go into the service settings it can be repaired.I pressed the info,menu,mute and power buttons on the remote and had a look but don't understand any of it so left well alone.thank you for helping me.regards
    Novelist:
    Champion:
  • 210 Answers
Sounds like the tuner is faulty or if its a seperate module the cables might have worked themselves loose, the video/mainboard is ok as its still able to produce an image.
If your up for it whip the back off and checks the cables as there is not much inside these models and a cable could have worked itself loose.
If everything looks fine inside, reset the Plug and Play settings and if that doesn't sort it out, then I would personally not worry about it as a seperate freeview and sky box is more than work well if not better.
Thanks
Posted on Sep 05, 2009
Testimonial: "Sounds like it might be the problem,how do you reset plug and play,many thanks"
  • xCAUSALITYx
    xCAUSALITYx Sep 05, 2009
    Here you go....
    On your TV, change your source to TV (analogue), now press menu>find "Plug and Play" (Usually in the dish symbol) and select it and it runs through the setup and selct "Home" when prompted and not "Shop".
    It might be that your tuner is in correctly set, this process will sort that out as well, basically its like you have just switched it on for the first time, this was the first screen you would have seen back then.
    Good Luck
  • xCAUSALITYx
    xCAUSALITYx Sep 08, 2009
    Yes you can get it replaced, a word of caution though, if the tuner is the main fault (Personally I think it is) and the tuner is on its own board then you are looking at pounds, if the tuner is intergrated in to the video board then your looking at a fair bit.
    Personally the tuner is not great in this S series, seperate units are far better as their only specific job is to produce a filtered/upscaled digital signal and send it to you TV.
    Thanks
How do I tune sky tv into my new Toshiba television
If the TV set is on the same stand as the Sky box then you don't tune at all. Connect with either a HDMI cable or a SCART. Use the AV input on the TV.
If you mean you have a bedroom set, and Sky is piped around the house on RF, then that's something different.
Make sure your TV has an analogue tuner as well as the digital one used for Freeview. (check the remote for a TV/DTV button). Go in the the TV tuning menu, and do an Auto tune for both analogue and digital.
Sep 13, 2014 | Televison & Video
How do I get my Sky channel back on analogue after re-tuning freeview
Go in to analogue tuning. Tune just the analogue side of the TV.
Sep 05, 2014 | Televison & Video
Sky problem
Freeview has nothing to do with satellite. FreeSAT is the one that uses a satellite dish for reception. FreeVIEW is received through the aerial.
Also, don't fall for the "digital aerial" scam. I install aerials as part of my business. I've been to homes with aerials 20 years old, covered in soot from the chimney and they still pick up Freeview perfectly well. Equally, I've been to homes where the owner has bought some gold plated multi-finned "digital high gain" monstrosity that has awful reception characteristics.
If your TV aerial is okay, then just plug it in to your Freeview receiving TV and do the tuning.
If you do want Freesat then you will need a satellite dish along with a Freesat receiver.
Sep 04, 2014 | Televison & Video
Can you watch the same sky channel on 2 tvs
Yes if you use the rf2 out on the box, cable it to the aerial input of the tv in the other room using uhf coax cable (aerial cable), and tune the tv in analogue mode (not freeview but the old analogue) to the sky box. It's usually on CH68 but if you do an autotune it should find it. Of course you will only be watching in SD not HD on the second set.
Jun 19, 2014 | Computers & Internet
I have a panasonic viera 42 in plasma. It has a built in freeview receiver. It is in the bedroom and receives a signal through a booster from the main sky box. I can get free view channels on it but can't...
switch tv to analogue tv and auto tune on tuning menu making sure sky is on. It should find it around channel 69. If quality poor then change output frequency to a lower channel. You do this with sky menu and instruction book. Info is changing RF output in book, or google it.
Apr 30, 2014 | Panasonic PV-M1349 Combo
Can you show me how to connect up the scart and aerials up to the following so they operate correctly Samsung PS42C450 42-inch 600Hz Widescreen HD Ready Plasma TV with Freeview SAMSUNG DVD-SH893M 160GB...
hello firstly scart lead from sky box to tv1 in) this is at the top there are two AV inputs ,,,on the bottom AV slot this is where your DVD conects too).iff you are using sky you will not need aerial in back of tv as this is for analogue use such as indoor antenna or outdoor antenna or iff using horizon the scart lead will suffice for all goodluck
Mar 19, 2011 | Samsung PS42C91HDX 42 in. Plasma TV
I have a Pioneer DVR5100H which was set up to record Analogue programs - can I change the set up to accept digital programs. I have tried auto setup but it doesn't pick up any programs?
You can't record digital programmes with this recorder unless it is connected to a digital tuner, e.g. a Freeview box or Sky digibox. This recorder has a built in analogue tuner which allows it to record analogue transmissions. Recorders which can record digital transmissions have a built-in digital tuner and usually have a DVB logo (actually looks more like DV3) on the front.
If you want to record digital programmes using this recorder, you need to connect it to a Freeview or Sky digibox, preferably with a scart cable. It is not sufficient to connect it to a TV with a digital tuner or built in Freeview as the player does NOT record directly from the TV, it must be connected directly to the transmission source. A basic stand-alone digital tuner (Freeview box) can be bought for as little as £10-15.
Regards,
BElectric
Nov 18, 2010 | Pioneer DVR-5100H DVD Recorder
42"lcd samsung tv,one year old has stopped working on digital and analogue but can work with a sky box or freeview box,ie it will not work on its own,thanks 42" lcd samsung wont work without a sky or...
sounds like it needs a re set
you need to press the following: (do not hesitate between presses)
s/by
info
menu
mute
s/by
when the tv comes back on follow original installation set up
Sep 04, 2009 | Samsung PPM42S3 42 in. Plasma Television
Will this tv work without a converter box when everything goes digital?
Hi.
If your set only has Analogue tuner you will need either Sky. Virgin, Freesat, or freeview box to be able to watch TV channels.
Jun 22, 2008 | Televison & Video
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
