Question about Philips 50PFP5332D 50 in. Plasma Television
50PFP5332D/37 has sound and no picture.
The power supply went out a few days ago (large board in the middle of the screen). So I replaced the power supply board yesterday and the tv worked for about 5 hours. Now I just have a glowing black screen, I can bring up all the menus but I can't get a picture from any of my componets (PS3, Wii and Cable Box).
  • 4 Answers
Try restting push the menu button in on the side for 5-6 second
Posted on Apr 15, 2010
Philips 50 inch plasma black screen
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 07, 2017 | Philips 50PFP5332D 50 in. Plasma...
Philips tv model number 50PFP5332D 37 wont power up
I have the model Philips 37PF7320A/37 won't turn on and MOST articles on the Internet say it's the Capacitors capictors capictors..I checked all of them. My tv just blinked red lights, had the clicking sound at first power on, but then goes black. No sound. No picture. Nothing. Just blinking red lights.
MINE WAS RESISTOR no. 3318 , a 100 OHM RESISTOR ON POWER SUPPLY BOARD.
I BOUGHT REPLACEMENT FOR .99 CENTS SOLDER IT, AND EVERYTHING WORKED!!!
THAT WAS ALL IT TOOK.
JUST A SUGGESTION..
1. CHECK FOR BULGING CAPACITORS (90 PERCENT OF THE PROBLEM)
2. THEN CHECK FOR RESISTORS WITH MULTIMETER ( FALLS INTO THE OTHER 10 PERCENT OF THE PROBLEM.)
TELL ME IF THAT HELPS..normanw1@yahoo.com
Oct 30, 2011 | Philips 50PFP5332D 50 in. Plasma...
Have picture, still some fuzz. t.v. jost purchase 6/10/2011 less than 24hrs. ago. had sound but no sound now.
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
I hope this will work out.....
Jun 12, 2011 | Insignia NS-LCD37 37 in. LCD TV
I have a philips model 50pfp5332d 37 We turned it on and it just clicks (like it is turning off an on) no picture, nothing. Will not respond to the remote or to the on off switch. Had to unplug to stop...
The tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 28, 2010 | Philips 50PFP5332D 50 in. Plasma...
My Philips flat screen tv model 50pfp5332d/37 I turned my tv on the blue light is on but nothing is on the screen it's making a clicking sound
It could be a power supply problem. In this model at least 2 capacitors, go bad in the power supply I think they're 1000uf/10V. If you look at the power supply board you will notice a bad cap with a blister on the top. The whole power board is from $100 - $200. I fixed a lot of these sometime the Y or sustain board goes bad. Visual inspection then measuring voltages..
Best of luck
Nour Sabre
Nov 03, 2010 | Philips 50PFP5332D 50 in. Plasma...
We were watching tv last night and it the picture just turned off. the machine was on but no picture. i turned off the tv and tried again this am. no picture.
You either need this part (http://cgi.ebay.com/Philips-50PFP5332D-37-LJ92-01401-Buffer-Board-/150501144120?pt=LH_DefaultDomain_0&hash=item230a913638) or this one depending on your dead screen issue (http://cgi.ebay.com/Philips-50PFP5332D-37-LJ41-04216A-X-SUS-XSUS-Board-/170550290208?pt=LH_DefaultDomain_0&hash=item27b596e720)
Oct 20, 2010 | Philips 50PFP5332D 50 in. Plasma...
I was watching Dish Network and my Philips 50 inch Plasma showed a line in the middle of the screen and then it made a snap sound and the picture went out at that time. I already replaced the power supply...
The capacitors in the power supply you replaced it with are probably blown. Take off the back of the TV and check the capacitors... shown in the picture (in a similar philips model). If they are bulging out instead of flat on the top... they may be bad. If you replaced the power supply before with a unit that had the original capacitors in it, they wear out and only have "X" amount of hours of life. (More below pic)
As far as sound... you may replace the sound board. It's shown in the photo in the center bottom right. Not sure on your TV without opening it or checking the model out more. Good luck
Oct 10, 2010 | Philips 50PFP5332D 50 in. Plasma...
Black screen
This denotes a power supply issue. I would venture to say that it is the part of the supply that controls the plasma ignitor if this is a plasma TV or if this is an LCD screen it is called the back-light and inverter circuit. The power supply board would be the chief culprit in this case.
I hope this helps,
Thank you,
Shuttle83
Aug 21, 2008 | Philips 50PFP5332D 50 in. Plasma...
TV's on. No Picture...No Sound
Have a problem with Zenith 37 HDTV. Medel number: Z37LZ5D As wathcing TV, along with 'pop' sound, TV went dead. LG service center gave an advice to unplug the power cord and press ON/OFF power switch about 1 min. Then plug power back and turn on the TV. Well, the green light blink for a while and solid green, but still no screen, no audio. Search the Web and someone suggested to replace Power Supply Board which will fix the problem. Again, search the Web and came out with Power Supply Board. LG Electronics/Zenith 'Power Supply Assembl' with $124.95 from PartStore.com. Is it the right solution? Do I have to replace entire Assembly Board? not just replacing some fuse? Any cheaper way to do? If I have to replce PSA board, any suggestion to how? Comment posted on Apr 22, 2009 I have a basic knowledge of electric and electronics, such as rewiring entire house for renovation and assemble entire computer from scratch.
Actually, the TV belongs to my father and the problem that I stated was based on what he told me.
So the question is based on the symptom that I posted, how sure are you that the problem is the Power Supply Board?
Is it good to order PSB? Comment posted on Apr 23, 2009 Purchased 2 and half years ago. Expired one year warranty. Comment posted on Apr 23, 2009 Zohail,
This is LCD TV.
There is no problem with the wall socket nor current.
I put other appliances on same wall socket and worked.
It has to be internal problem.
As I mentioned on the main post, there was a 'pop' sound while watching and TV went dead.
Turn on remote control, there is blink green light and then green stays on, but no sound, no screen.
Turn off remote control, light turns red. Comment posted on May 14, 2009 I fixed the TV.
Orderd power supply board which cost me $136.51 total.
Replacing was simple.
Just removed the rear panel cover then electronic board housing cover.
Took power supply board with all the connector cables and replaced with new one.
Problem was a transformer connector which got burned and blow up the plastic cover.
But no problem with fuse and capacitors.
Thanks all for advises.
Jan 01, 2008 | Zenith Z37LZ5D 37 in. LCD TV
Philips 50PFP5332D 50 in. Plasma Television Logo
515 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
