Question about Garden
The trimmer head is not engaging when gas is applied. appears that the weedeater attachment is not fully attaching internally. almost like internal mechanism inside is stripped.
boscia
  • 163 Answers
SOURCE: Ryobi TP30 straight shaft line trimmer convertible - drive shaft disconnected from motor
check both ends of shaft, they're usually a hex or torx head. sometimes the can strip or even snap off. if you find noticable damage replace the shaft
Posted on Nov 29, 2008
s_s_m_o_k_i_
  • 162 Answers
SOURCE: Troy Bilt 4 cycle weed eater - trimmer head doesn't spin
rotate attatchment head slightly while inserting driveshaft
Posted on Jul 31, 2009
  • 1169 Answers
SOURCE: Homelite trimmer - tubes into tank came out. One is split
Actually the fuel is pumped in by the carburetor. The carburetor work both vacuum and pressure when operating the pump. There is one line in the tank with a fuel filter normally attached; the other line is a return line is normally just inserted a short distance in the tank. To access the filter use piece of wire with a small hook on the end and carefully fish out the line.
If installing new lines change them one at a time as not to reverse their attachment to carb, When inserting the lines into tank cut them on an angle to help get them started then cut the supply line square before installing the fuel filter.
Posted on Aug 24, 2009
AUTODOC01
  • 216 Answers
SOURCE: I need to know how to load a two string trimmer
most of these use 2 wires coming out of 2 holes on opposite sides roll the firstwire clockwise, then the 2nd counterclockwise so that when the spool turns the string comes out its not hard
Posted on Aug 25, 2009
SOURCE: where do I connect the fuel lines on my ryobi weedeater?
I have Ryobi775r string trimmer with walbro WT526 carb. The fuel lines connect 3 parts eg. gas tank, bulb (mine is a separate bulb not part of carb.) and the carb. The bulb has 2 fittings- a short and a long one. The carb also has 2 fittings- one on top (vertcle) and one on the bottom (L shape). The gas tank has two holes in the bottom one for over flow line and the other for fuel inlet to the carb. This has a filter in the gas tank. Now the connections- connect the long fitting on bulb to the tank. this is the overflow. Connect the short fittin on bulb to the carb top (verticle) fitting. Connect the fuel line (with filter - it is in the tank) streight to the L fitting on the bottom of the carb. Make sure the fuel lines are of right diameter. Too big-and you will have leaks. You are done connecting the fuel lines. just for info. the bulb is there just to pull a vavcume in carb so that the fuel is sucked into the carb and is present there when you start the engine. Hope it helps. Good luck.
Posted on May 10, 2010
How to remove trimmer head on weedeater xt114
the trimmer head is a left hand thread
make like you are doing it up to undo it
remove all the trimmer parts down to a shaft then fit the plastic blade attachment
Jun 21, 2015 | Cars & Trucks
Saw attachment will work but weed trimmer attachment will not turn
check that the trimmer attachment is fitted properly on the shaft as it appears the the shaft drive is not engaging in the head
May 23, 2015 | Poulan Pro PP338PT 8 33 cc Gas Pole Saw...
I own a Troy-Bilt 425cs string trimmer with multiple add-on attachments. The unit works fine for string trimming, brush cutting, and cultivating. However, it will not properly power my edger attachment. ...
The power edger attatchment may have a slightly different coupling size on it than the other attatchments. Also, do a good inspection of the power head unit's coupling at the EZ LINK connector. Maybe the head unit connector is getting hot over time, due to a lack of lube, and expanding internally, causing slippage in the connection to the edger attatchment. Inspect all that you can.
Sep 11, 2011 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Trimmer runs but the head wont turn
It may be that the drive shaft is broken, or not engaged to the engine. Make sure the trimmer attachment is locked all the way onto the shaft coming from the engine. If it still doesn't work, check by seeing if any of the other attachments work when you put them on. If they do, you know the drive shaft in the trimmer attachment is probably broken.
Aug 17, 2011 | Craftsman Convertible 25cc. Gas Line...
Weedeater trimmer not engaging
maybe on reassembly the drive shaft did not align properly.
Jul 18, 2009 | Garden
The motor want turn the attachments i.e. string on the trimmer or blade on the edger
there is definitely a problem in the drive shaft. check to make sure there's nothing blocking the mal and female ends. if there is, clean it out and lubricate it so that the male will attach to the female slot. also check to see that both ends are not stripped. if the motor portion of it is stripped, which most liekly is out culprit, then it needs to be replaced, or you need to get a new trimmer. if you do, i recommend the Ryobi model CS26 gas trimmer.if the atachment shaft is stripped, the the attachment needs replacement. if you replace the motor portion you need not lubricate the attatchment slot. if the attachment is stripped, it needs to be replaced, but im quite sure the female end in the motor shaft is our problem. it could also be broken inside the shaft. make sure nothing falls out if you hold the attatching ends to the ground.
May 31, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
113 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
