Question about HP Officejet 6310 All-In-One InkJet Printer
Brush fell out
Opened to remove a sticker which was jammed, brush fell out...where does it go?
My kyocera KM 1815 keeps saying "paper jam 00 open left cover and remove paper jam but there is no jam
Hi
Check all the paper movement from the tray, left or right cover, front cover, if so then remove jammed paper. Otherwise the paper sensor spring guide missing or fell off from its original position. Check carefully where the sensor locate. paper sensors detect all the paper movement in the machine during copying or printing, so locate the place in the machine which the paper usually jammed, see the screen of the machine, it will locate the place where the paper jammed mostly. Sensor not return to it original position that is why ( remove paper jam keeps blinking)
Aug 11, 2014 | Kyocera Mita Office Equipment & Supplies
Upright dirtdevil roller jammed - how to remove square endcaps for cleaning
The brush roller is secured with elastic stop nuts. Clamp the nut at one end with a wrench or pliers and remove the nut from the opposite end. This will allow the shaft to be removed completely for cleaning
Feb 09, 2013 | Dirt Devil Featherlite Bagless Vacuum...
My printer won't catch the paper to print. It make all the noise, but won't pull the paper through.
You can try the following. Remove all paper from the printer and turn printer off. Try opening the printer as if you were to remove the ink cartridges and check for any paper jammed in the printer. If there is a paper jammed try to remove it. if there is no paper jammed in the printer then try the following remove all paper from the feeder and flip the printer upside down and shake it a little. Sometimes things will fell inside of the paper feeder and will block the paper path thus causing the printer not to be able to pull the paper.
Feb 17, 2010 | Lexmark X2500 All-In-One Printer
Lexmark 5400 printer, paper not feeding, help
Jan 15, 2010 | Lexmark X5470 All-In-One InkJet Printer
Jammed with gummed stickers
Always put stickers in the shredder between two layers of 3-4 plain paper sheets. That's for future.
Now I would suggest getting some "Label Off", "Label Killer" or similar spray product, that will dissolve the glue, spraying the cutters and stuck labels with it several times, trying to remove them with tweezers or thin long-nose pliers. Be gentle, try not to blunt the cutters' edges.
When you get rid of the labels, spray more of the stuff on the cutters and clean them with a brush, to remove glue residue between them. Do it several times, rotating the cutters to remove the glue all around.
Then lubricate the cutters as per manufacturer's recommendations.
Nov 14, 2009 | OfficeMax 0M96431 Shredder
Paper jammed light stays on after removing jammed paper.
Make sure you have opened all doors and pulled out all paper trays. After turning the copier on and off if jam light stays lite then you will most likely have a sensor problem (fell out or broken)
Oct 18, 2009 | Canon PC-940 Black and White Copier
False paper jam
possible solution - I had a similar printer that had small stones that fell into the paper slot at the back and jammed the mechanism. a shelf behind the printer had these little rocks and a child dropped them into the printer. I had to take it all apart, but it worked after that
May 29, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper jam on HP officejet j6450
Diana,
They don't bounce well, i've tried it.
Loon in the rear for an access door.
Jan 08, 2009 | HP OfficeJet 7310 All-In-One InkJet...
False paper jam
Turn it upside down and shake it. then check the input tray. Also, chck the jam switch. it's a microswitch in the paper path. it could be bent of stuffed with a small piece of paper.
Aug 14, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Regarding motorola
open the battery cover of your phone and remove it the battery. Underneath you should see a small circular sticker. If it is red your phone has internal water damage. You may need to get the keypad replaced.
Oct 28, 2007 | Motorola Mobility SLVR L7 Cellular Phone
HP Officejet 6310 All-In-One InkJet Printer Logo
20 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
