Question about Canon PowerShot A95 Digital Camera
Lens open can not shut down E18
I turned on my camera this morning. It made 5 bips and showed E18 on the screen. Now, the lens did not close back anymmore. I took of the card and the battery (new) and I charged them. I put back the charged battery but it did not help, when I turned it on it made the 5 bips, and showed E18 in the screen. I switched it of but the lens is still open! Help!
  • 3 Answers
Sometimes it just gets stuck - With the camera on go to the view mode and give it a little jiggle with your thumb and finger. Also - a can of compressed air can loosen up what ever might be stuck in there.
Posted on Sep 16, 2009
SOURCE: the lens doesnt close and when i turn the camera on it bips three times and the screan shuts off. the lens wont close.
The batteries need to be changed. The digital batteries sold at the stores die out too fast. I had this same problem. In result, I purchased rechargeable battieries.
Posted on Dec 14, 2006
thaurfen
  • 623 Answers
SOURCE: E18 error on Canon ixus40 - lens stuck
The E18 error is an error message on Canon digital cameras. The E18 error occurs when anything prevents the zoom lens from properly extending or retracting.[1] The error has become notorious in the Canon user community as it can completely disable the camera, requiring expensive repairs.
A quick internet search for "E18" + "canon" quickly reveals hundreds of similar complaints.
ConsumerAffairs.com reports that the "lens has a feature called bellows claw, which is a gear that physically extends and retracts the lens. A piece that holds the lens, the barrier plate, is not large enough and can sometimes cause the bellows claw to malfunction, resulting in a stuck lens". The result is a black screen that only contains the error message, E18. Another problem mentioned on the site blames a sticky iris in the lens, caused by grease entering inside from the microphones built into the lens. The buildup freezes up the ability of the lens to open.
Posted on Nov 13, 2008
t00nz
  • 4738 Answers
SOURCE: E18 appears on the camera and the lens won't close
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Mar 28, 2009
  • 4 Answers
SOURCE: my samsung s1065 lens wont shut and anytime i turn
tried above,but 3 beeps and dead camera has shown up on numerous forums from many s1065 owners so got repair under g/tee. if it happens again i'll have a replacement !!!
Posted on Jan 02, 2010
  • 11967 Answers
SOURCE: Canon PowerShot S45 lens is
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 14, 2010
2 seconds after the camera is set off there is an bip-bip sound and "E18" sign on the screen.
E18 error is caused commonly due to dust/sand particles getting lodged in the lens mechanism, between the barrels. Try blowing briskly or tap lightly with your fingers holding the lens down. If this doesnt solve the problem you have to take it to a service centre.
Feb 13, 2011 | Canon PowerShot SD550 / IXUS 750 Digital...
When i try and use the zoom for photos the camera the camera beeps, a message E18 appears on screen then it shuts down?
E18 message means a lens error, lens may can't get back. For most situation you can't fix it by you self, but some friends has fix it by their self. They only shaking the lens and make lens get to the right place.
Dec 28, 2010 | Canon PowerShot A410 Digital Camera
Y Canon Power Shot SD400 digital Elph camera won't shut down
Your problem in your lens...Try to bring service center. Cause, canon lens it for me it not easy to disassembe dan assemble it again...Different with other camera lens, like KODAK and Samsung.
At sony camera "E18" can be "Turn the power off and On again" like my Sony W.35
Aug 22, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
My camra has E18 on the screen
E18 is an internal error, the lens drive mechanism.
Canon has to fix it. If it is not under warranty, it will cost you around $160.
Apr 10, 2009 | Canon PowerShot A75 Digital Camera
Nov 13, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
I Have a Canon powershot A410 and I cant get it to work anymore. The lense will not open and it beeps at me and then E18 shows up on the bottome left hand side of the screen. I can still down load all my...
The "E18" or "Lens" error message indicates an error that involves the lens unit or lens cover.
This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera. Solution
Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area:
  • Hold the camera so that your fingers do not touch the lens unit when you are shooting.
  • Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.
If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service
Oct 21, 2008 | Canon Cameras
E 18 problem
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're still worth a try. Good luck! :
Feb 13, 2008 | Canon PowerShot S500 IXUS 500 Digital...
Black screen, loud beeping when opened, doesn't work
The following blog outlines some simple repair options for a lens error. But please first try the listed Fix #2. I heard that fix particularly works well for a camera who's battery had run down with the lens open. Please post back here with a follow up comment if any of the fixes work:
Dec 23, 2007 | Canon PowerShot S60 Digital Camera
Canon PowerShot SD200 E18 Error
The "E18" error code indicates an error that involves the lens unit or lens cover. The grinding noise you hear-to my regret- means that len's mechanism is malfunction. This type of problem could be fixed by professional only.
Jun 23, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
The lens doesnt close and when i turn the camera on it bips three times and the screan shuts off. the lens wont close.
Nov 19, 2006 | Samsung Digimax S500 Digital Camera
Canon PowerShot A95 Digital Camera Logo
73 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
